Question about Integra Dtr-20.3 THX Select2 Plus AV Receiver
When I use hdmi to plug my laptop into my Integra 20.3 receiver, network control of the receiver shuts down. I can't even ping the receiver unless I shut down the laptop. Can this be fixed?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Integra DTM 3.5 AV receiver. The
Do more triage first.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Posted on Jun 11, 2011
Cant get ps4 to pass signal thru avr to projector.
Possible PS4 HDMI Handshake Output Problem - AVS Forum ' Home ...
www.avsforum.com/.../1508885-possible-ps4-hdmi-handshake-output-p...
Dec 31, 2013 - 20 posts - ‎15 authors
Nothing seems to make the PS4 pass a signal through the AVR. .... can output videothrough the Integra, why can't Sony get the HDMI working? PS4 - 3D Playback Not Working :-(
Aug 12, 2014
Run HDMI Directly to TV or A/V Receiver?
Dec 19, 2013
AV receiver problem with Xbox One
Nov 23, 2013
Solution to HDMI @ 1080p receiver/display HDCP ...
Dec 14, 2008
More results from www.avsforum.com
My Denon AVR-X4000 won't output video signal from attached HDMI ...
forum.blu-ray.com > Audio > Receivers
Dec 21, 2015 | Denon AVR-3311CI 7.2 Channel Networking...
Picture flashes 5 or 6 times when changing channels on LG 4k. Using 2.0 HDMI cable from Fios set top box to Integra 60.5 pre/pro and out to TV. Works fine if I bypass processor and go direct to TV
Try to check with any other HDMI input of the Integra to input the set top box. Even if facing the same problem then you have to check both the the HDMI cable. Better replace it. Always remember that do not plug or remove the HDMI cable when the system are ON. Yo have to turn off before making any connection.
www.electro-medical.blogspot.com
Oct 31, 2015 | LG Televison & Video
The internet light on my Acer Aspire laptop wont light up
Hello
Check if the the network connection is working. or if your don' have drivers for it.
Check if your Network card is working or Not.
1: you can check the driver if you can the driver install for the network card.
2: open CMD (Click start and search CMD)
3: write: Ping 127.0.0.1 (This will check if your card is working or no)
4: you will see the pinging 12.0.0.1
5: you will see at the bottom Ping statistics for 127.0.0.1:
6: if is says that received 4 and lost 0 then the network card work. If your see received 0 and lost 4 then the network card is faulty.
To Check the connection with the router try this.
1: open CMD (Click start and search CMD)
2: write: Ping 192.168.0.1 or 192.168.1.1 (This will check if your card is working or no)
3: you will see the pinging 192.168.0.1 or 192.168.1.1
4: you will see at the bottom Ping statistics for 192.168.0.1 or 192.168.1.1:
5: if is says that received 4 and lost 0 then the network card work. If
If you want to find everything about the connection:
2: write: ipconfig
3: IPV4 is your laptop IP (Internet Protocol)
4: Gateway is your Router IP (Internet Protocol)
5: Subnet Mask : 255.255.255.0 (Make sure its like this if different your need to contact some one)
5: Ignore the rest
Feb 07, 2014 | Computers & Internet
How do I set up an Integra DTR 7.8 for 3D display and audio
Your DTR-7.8 receiver is not 3D compatible. It does not support the new 1.4 HDMI. You have to have 1.4 HDMI and 1.4 cables for the 3D format.
You can bypass your receiver for the video though. Simply run your HDMI cord (1.4) from your Blue Ray to your Projector. Your audio can be ran from your Blue ray to your reciever.
May 17, 2012 | Integra Audio Players & Recorders
HDMI ports do not work on my panasonic th50pz77u
I had the same problem with my integra receiver. You can use RCA plugs which will do the same thing and not use HDMI the fix is cost prohibitive from what I was told.
Jul 24, 2011 | Panasonic TH-42PX500U 42 in. Plasma...
My laptop shuts down and won't start up
check temp, then virus check control. alt. del. on how hard the mashin e is working if mashine is ful of hair in the fan......clean.
Jun 14, 2010 | HP G60-230US Notebook
The reciver dosnt get a signal from the hdmi inputs both ps3 and blu ray have the same problem it is a dtr 5.9 integra
what you should do is make sure that your HDMI is cord is not in an awkard position, which like mine i have to unplug and plug back in to get a signal
Mar 01, 2010 | Integra DTR-5.1 Receiver
I'm not sure what's wrong with my laptop, my HP tx1000. My computer is just not recognizing the adapter in the device manager.
See if you can ping your NIC.
Start -> Run
Type in cmd
In the command box type:
ping 127.0.0.1
If these pings fail try turning off your computer, unplugging it, removing the battery, and holding down the power button for 20 seconds. This should make your computer recognize your NIC.
If this solves your problem please leave feedback.
Jan 24, 2010 | Broadcom Computers & Internet
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Actiontec router Outbound Traffic Blocked - NAT out failed
k first delete all temp files and cookies and clear history>and change teh dns to global one>i hope that u pinged with the web site have u tried ping with the ip address of teh web site>then here the way to change teh dns to static
start-->control panel-->and network connection-->right click on local area conn-->properties-->and high light the TCP/IP-->and click properties and u can see a dialog box>in that look @ the left side down u can see obtain DNS sufficx>and use the current following DNS select that and the DNS range is
4.2.2.1
4.2.2.2>and apply and ok>and reboot the pc>and check with teh web site iam sure its a dns issue>and rate me solved if its help full thx
Nov 04, 2007 | Computers & Internet
Integra Dtr-20.3 THX Select2 Plus AV Receiver Logo
16 people viewed this question
Top Integra Audio Players & Recorders Experts
Electro Med Services...
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
