Question about Dell PrintersDell MFP Color Laser 3115cn Driver Version A01
Error code 062-371 dell printer 3115 cn - Dell PrintersDell MFP Color Laser 3115cn Driver Version A01
bunnydawg
  • 5158 Answers
SOURCE: Error Code 004-332
try unplugging it for about 10 minutes and starting it up again... that hopefully will reset it.... have you found out what that error code is
Robert
Posted on Jan 29, 2009
SOURCE: RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Posted on May 18, 2009
I tried this solution but wasn't quite sure how it's possible.
"Pull out the drum. Open the front door. Then close back this door then at the same time, move
the carousel around back or forth. The carousel now is able to be free to rotate. During rotating
you try to pull out the catridge. If it is locked, then adjust it to the position to be free."
Instead i pulled out the drum unit and pushed down with a bit of force on the toner carousel. I heard the gears grind which didn't sound real pleasant but the error went away. Instead I received an error message this time to remove and reseat the Cyan toner. Tried this multiple times w/o luck so i replaced the Cyan toner and it freed it up. Now I'm getting a paper jam message but there is no jam. Stuck again but making progress...
Posted on Jun 24, 2009
drifterK
  • 4924 Answers
SOURCE: Printer Dell MFP 3115 CN we
the Dell 1235CN is from the same category of CD laser printer from Dell ..and the ink cartridges will fit ...cause they have some standards ..by the tip ...ink-jet, laser...etc..but those 2 printers are in the same category ..being both CN and laser based...it will be a little slower but the price is just under 300 what make it a good choice facing the 800 that you should have payed for to end up with a refurbished one ..
take a look here ..
http://www1.euro.dell.com/uk/en/business/Peripherals/printer-dell-1235cn/pd.aspx?refid=printer-dell-1235cn&cs=ukbsdt1&s=bsd
Posted on Aug 27, 2010
  • 32 Answers
SOURCE: how can reset all setting dell 3115 cn
"Here is what I did to reset the Dell 3115cn Laser Printer. In the users manual for the 3115cn in section 6 "Changing System Settings" "Resetting Defaults" refers to page 64 where it says, " For more information, see "Reset Defaults" in the User's Guide. Only I did not get a User Guide with my Dell. So I Googled "3115cn user guide" and downloaded it to my desktop and then went to Resetting Defaults. In the attachment "Initializing NVRAM for Network Settings" is what I did. Hope this helps someone else."
Posted on May 07, 2014
How do I resolve 093-423 error?
web search dell laser printers error codes
Sep 15, 2015 | Dell 5110cn Color Laser Printer 5110 Cn
094-402 error code resolution?
web search dell laser printer error codes
How can reset all setting dell 3115 cn
May 07, 2014 | Dell 3115cn Multifunction Color Laser...
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
My dell 3110cn printer is displaying the following Error code 009 363 reseat k cart how do i fix this?
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
Oct 15, 2010 | Dell 3110cn Laser Printer
Dell color laser duplex 3115 cn will not print on both sides of paper.
Mascmen7,
although I would still like you to let me know the service tag ( so I can check on your warranty ), I am going to take a stab at what I think you are having a problem with.
I have had several customers that have had difficulty with their Dell printers when in fact there was no hardware defect at all, but simply that the options were not set in their Driver.
One customer couldnt print from tray 2 because tray 2 was not "installed" in the driver.
See the image below. If you go to control panel and then printers and faxes, right click on your printer and then select properties. ( see image )
the last tab ( and i know it isn't easy to see here ) is marked as options.
Click there, and then make sure that the duplexer is either "available" as shown in the above driver properties window, or on some Dell printers, it actually shows a list on the left and the available options on the right. If this is the case for you, simply highlight the duplexer and "add" to move it to the columb on the right.
You would think that just installing the print driver would also insure the printer was added as configured, but sometimes it does not.
Let me know how you make out.
Cory
Nov 07, 2008 | Office Equipment & Supplies
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
