Question about Miele CVA2660 Stainless Steel Coffee Maker
Miele CVA6805 doesn't make milkfroth and hotmilk anymore!
Hi! I have a miele integrated coffemachine CVA 6401, it is one onth old and it doesn't make hot milk and milkfroth anymore. It doesn't say any errors, just won't make them. I have cleaned and rinsed the milk pipework, still nothing. I don't know what to do ....
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
SOURCE: display message - brewunit block - can not undo to
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Posted on Jan 21, 2010
espressonist
  • 1711 Answers
SOURCE: HI THERE! I HAVE A MIELE model CVA 615 and no more
You can remove the end tip of the steam pipe and clean it dry milk can block hose. If you litlle steam pressure you can boil water in a glass and keep it allnight long so the dry dirt milk can be soften and the pressure of the same steam can spit all the dirt out so the steam hose can be clean again.
Posted on Feb 13, 2010
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
Hi. I need order a descaling funnel for miele CVA 2660. Please let me know how to do it? Thanks. Jim
Page 62 for the instructions Jim
For descaling you should only use the descaling tablets
supplied. These have been specially formulated for use in
this coffee machine. They are available from your Miele
dealer or the Miele Spare Parts Department
Get the funnel there too.
https://www.nespresso.com/ecom/medias/sys_master/public/8842295967774/miele_built-in_user_manual_-_english.pdf
Mar 15, 2017 | Miele Coffee Makers & Espresso Machines
Miele cva 5060 when i press on shows 'insert boiling unit.' And stucks there any solutions pls .
any chance you could put up a photo of your brew unit ? something has fallen out of mine and i can't figure out where to put it !
Aug 20, 2015 | Miele Coffee Makers & Espresso Machines
Cold coffee. Real programming mode Miele CVA 4085?
Hi Pepijin,
I do have this site where you can download manual for you to review it by yourself in case you encounter some issues as well. Hope it helps.
Miele CVA 4085 Operating And Installation Manual Page 50 Setting The...
Apr 25, 2014 | Miele CVA4070 Coffee Maker
I need a replacement milk flask for a miele cva4062
These are very hard to come by! You will want to check with your local Miele dealer for part 7271552. No one makes suitable replacement parts and replacing this will run you about $300-400 + shipping (likely come from Europe). I have yet to find this part readily available in North America.
Suitable for CVA506x Miele Accessories Miele UK
Feb 26, 2014 | Miele CVA 4062 Stainless Steel
Milk and milkfroth clogs up after about 4 to 5 cups
It can be several things .. but the first to check is that the milk pipework is not clogged and also that it is fully cleared of milk residue. In other words it may be partially blocked. You need to buy some 'milk line cleaner' ... Miele make it but there are after market products that are cheaper. I use the Cafetto product called 'Pulatte' and it works well but others will do. You need this product for general maintenance anyway. If this does not solve problem then you need to provide specific details on the precise nature of problem.
Aug 16, 2013 | Miele CVA 4066 Stainless Steel
I have a Miele CVA 615 coffee system and the pump does not work. Miele wants $800 for the replacement part alone, and I read on the internet that the part is actually a SAECO pump. Does anyone know which...
Hi Saeco uses 2 different pumps in their machines. The most common is the Ulka EX5, and the other is the Ulka EAX5 The only difference is the wattage. EX5 is 41w and the EAX5 is 52w. Need to know what wattage your pump is.
Jul 06, 2011 | Miele Coffee System
Where can I buy a Miele CVA 615 Expresso Watertank?
The only Miele spare parts are direct from Miele or through a Miele service agent. Have a look on the Miele website for your nearest Miele branch or service agent in your country.
I work for Miele and they only sell parts this way. if you call the Miele spare parts number off the website and tell them you have a cva615 they will be able to mail one to you.
Hope this helps.
Mar 23, 2010 | Miele CVA615 Espresso Machine
I have a Miele CVA615. I think I should replace
Hello Phickok,
It sounds like the perculator may need to be replaced (The entire unit with the 'O' rings on it). As I recall the plunger is an integrated piece that cannot be replaced on the CVA-615/620 models but you may want to contact Miele technical services on this. These first generation coffee systems are very complecated to troubleshoot
Sep 05, 2009 | Miele CVA615 Espresso Machine
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
Miele CVA2660 Stainless Steel Coffee Maker Logo
113 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
