Question about Bernina Virtuosa 160
LED DISPLAY LIGHT
NOT WORKING HOW TO REPLACE
LED display is black or very dim. Bernina artista 640 machine. Have researched on line, with no help.
There is usually a way of dimming the LED screen, but if that doesn't work, it's possible a computer component is dying.
Oct 16, 2017 | Bernina Sewing Machines
We replaced the bulb and it doesn't work
If a new bulb does not work, then it is most likely something else, perhaps the wiring or a connection. You can probably have your machine serviced to get it fixed, or go purchase a light that you can place close to your machine to light the sewing area. There are lights available with attachment clips and a bendable neck that well let you get the light in the right spot. There are also strings of LED lights available on eBay that you can attach to the upper part of the throat to light the work area. I replaced my regular sewing machine bulb with an LED bulb and was surprised how much better it lights.
Oct 30, 2015 | Sewing Machines
Can I replace an ordinary light bulb in my Janome machines with a LED bulb?
as far as bulbs they will work fine IF you ever find the proper ones, size wise .
May 05, 2015 | Janome Sewing Machines
Display does not light up on PFAFF 1475 CD
Could be an electronic issue. Take it to your local Pfaff dealer for an estimate on repairing it. The parts may or may not be available.
Feb 01, 2015 | PfaFF Sewing Machines
Led light does not work. how to replace led light on singer 14sh654
I believe the newer machine lights need to be replaced by a technician. You can check on getting some of those LED light strips that can be added to the machine instead.
Jun 24, 2017 | Singer 14SH654
LED display very light
check the instruction manual and see if there is a setting for the lighting
if not call bernina's customer service and ask them if the machine
need to be sent in for a checkup
Nov 03, 2012 | Sewing Machines
Foot pedal doesnt work on AEG 11227 LED sewing machine
First get someone with a multi-meter to test the foot pedal. If it is bad replace it with a new one.
Sep 15, 2012 | Sewing Machines
Pfaff 1475 CD. Intermittant Power On.
The typical rebuild on this board is done by replacing the 22 micor farrad caps. There are 3 or 5 of them depending if it is new or old style. Note: the power to the sew lamp goes straight from the motor to the lamp, the power to the control panel goes from the motor to the main board (base plate) then to the control panel. If you get the LED's on occasion then it is not the transformer or fuses in the base plate but simply the caps. Sometimes you can just scrape off the electrolytic gel that has oozed out of the caps off of their teminals, but replacing them is the best.
A Pfaff dealer can get a core credit for your board if you take it in. You shouldn't have to pay more than $200-$300 for a rebuilt base plate.
Jan 12, 2009 | Sewing Machines
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
