How do i reboot and select proper device on my pendo u1000 notebook
fraywing
  • 37 Answers
SOURCE: When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
Posted on May 27, 2009
  • 57 Answers
SOURCE: When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Posted on Jun 15, 2009
Testimonial: "Brilliant. Thanks so much. It worked a treat. Much appreciated"
  • 10 Answers
SOURCE: computer beeping and saying reboot and select proper boot device
When you reboot, go to BIOS, restore factory BIOS settings. If that doesn't help, you'll need to reinstall your OS.
Posted on Jun 17, 2009
SOURCE: Error message says PXE-E61:media test failure
HELP ME!!! mine says the same thing but hen it says operating system not found.
help help help!
Posted on Jan 22, 2010
  • 39 Answers
SOURCE: How can i reboot my laptop?
It is either not seeing the HDD and/or the boot sector on the hdd has been damaged. Any repair you do will only be possible after you boot to an environment. If you can get a bootable CD made, that would be one option. Bootable USB is another. Once booted, you will then be able to examine the HDD to see what the problem is.
Does the bios show a HDD at all?
Posted on Jun 06, 2010
How to reset pendo pad
Go to settings and scroll till you find reboot your device to factory settings. Or "backup and reset" Under "Accounts" in your settings. Then click on "backup and reset." Every tablet and cell are somewhat different. Be sure to read your manual, very easy to do when you are familiar with your device.
May 13, 2014 | Tablets & eReaders
Restore factory settings for a pendopad
I have resolved the pendo pad hard reset lack of procedure and can factory reset a pendo pad that is locked with a passkey or and password full factory reset
First download you pendo pad firmware from here
http://shop.pendo.com.au/index.php/su...
I used the generic firmware 1 download and it worked fine for the TPC7SlV
Then Extract the . img file to you computer
Then you will need the firmware update too called rktools found here
http://download1942.mediafire.com/le9...
extract the zip file to your computer
Now your ready to flash the firmware
1. Power off your tablet with the switch
2. Turn the power switch Back the the on Position
3. Press & hold Side Button with the home picture also called the back/esc key
4. While holding, connect PC and tablet with USB cable (if tablet boot normally, try again)
5. Install the driver for your computer included in the RKtools Folder
6. Tablet should be recognized as "RK281X Device" in Windows
7. Start RKAndroidBatchUpgrade from rktools folder
8. In the bottom of the batch RKAndroidBatchUpgrade programme there should be a green light in the device upgrade area. * if there is no light in the upgrade area and all the numbers are grey then repeat the previous steps
9. Under the setting heading click and select the image file you downloaded from pendo ( will be a .img file if its a .zip file you need to extract it)
10.Click the upgrade button
11. wait till operation is completed
BAM Your pendo is password free, i hope i have created the best and easiest way to do this
***Please note if your wireless or Mobile network do not turn on then you have chosen one of the wrong firmware types from the pendo download site !!! the wireless and mobile network hardware are the only distinguishing features between the firmwares apparently******
Mar 08, 2013 | Tablets & eReaders
Lenovo Y510 says I need to Reboot so select proper Boot device. Can I downloan something from Lenovo site?
Yes you can obtain recover software from Lenovos' website for your model that should take care of your problems.
Jan 27, 2013 | Lenovo IdeaPad Y510 Notebook
On my pendo pad THE process android.process.acore has stopped working
Hi you will probaslly have to flash the pendo pad, its not too hard to do here are my instructions, - unfortunatly a pendo pad does not have a recovery menu to access on device boot
note - this solution also unlock the pendo pad and restores it to factory settings even if it wont boot the android os
2. Turn the power switch Back to the on Position
Dec 20, 2012 | Cell Phones
Help with reboot message for Asus G1 notebook.
Sounds like its trying to boot from the Optical drive (cd/dvd drive) thats empty or has no disc in it. You will need to get into the BIOS and change the boot sequence. Select HDDR 1st to boot from your C: drive where your OS is.
Dec 15, 2011 | ASUS G1 Notebook
What do I do when I get a reboot and select proper boot device and there is no devices connected?
Hmmm - select a proper boot device - but you probably already tried that.
Anyway, its possible your system has a little corrosion on one of the contacts connecting your
hard drive (a proper boot device) to the PCMCIA or PCI bus on your notebook PC. If so, you
may want to reseat the hard drive, which is to say remove it, and then plug it right back in - just to
try and make the proper connections between the hard drive and its bus.
Also, if you have a bootable CD, then insert it, and boot away.
I assume that this notebook PC was an Xmas gift and you're still getting familiarized, but if not,
happy Xmas anyway.
Dec 27, 2010 | Montgomery Ward Home Mirus Innovations...
Reboot and select proper boot device
Hi, ull need to check the boot device priority in ur BIOS which is accessable usualy by pressing the delete key at the start of the boot process. If everthing is correct there and yet it doesnt boot from ur hard disk, try changing it to boot from cd and check if it boots. If it does then i think either your hard disk is corrupted or your OS.
Jul 08, 2009 | EliteGroup ECS 755-A2 Motherboard
Jun 15, 2009 | MSI M510C Notebook
Hope this helps :)
May 27, 2009 | MSI MEGABOOK M510C Notebook
Acer extensa 5620 notebook dvd-cd rom doesn't read my dvd. i think i uninstalled driver. how can i find dvd writer driver for my notebook?
go to device manager under System Properties. Locate DVD/CD Drives, expand it, select your drive, right click and then left click on properties, select the General tab and check the state of the device IT SHOULD indicate the device is working properly, if so or if not, select the Driver tab unomstall the driver, reboot, see if Windows will reinstall the driver as it should recognize the device as a new drive. If not return to the device manager and reinstall the driver.
Feb 19, 2009 | Acer Extensa 5620-4020 Notebook
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
