Help: Huawei EchoLife HG8245: Port 80 Not Open
So I needed to portforward my router so I could have an Open NAT type on my Xbox 360. Before you continue reading you should know I really am new to this stuff and I don't plan on doing anything about being a noob at this, I'm just trying to get an Open NAT type. Anyway, the website said to open the ports 53, 80, 88, 1863, 3074 on my Huawei EchoLife HG8245. I followed all of the instructions and then I tested it. ALL of the ports were open except port 80. I tried removing all the virtual servers and adding them again but the same results. 53, 88, 1863 and 3074 work fine and are open, but 80 is still NOT. I used PT official program or app or whatever with guaranteed results. Like I said, all ports except 80 appear to be open. I also went to a game of COD to check my NAT type and it was Moderate.
    Filmmaker:
    Uploaded 5 video answers.
  • 9 Answers
Well there is NO need to go live. this is a simple matter your ISP is Blocking Port 80 for whatever reason and there is probally nothing that can be done besides get a new ISP one that does not block port 80..
You can try giving them a call or check their website and see if the Block port 80 as ALL the other Ports you Forwarded are Open.. I am Highly leaning to your ISP as the culprit..
Posted on Feb 14, 2014
  • Ad Huanetwork
    Ad Huanetwork Feb 14, 2014
    HG8245 Price and Specification Huawei Echolife GPON Terminal HG8245...
3 Suggested Answers
  • 4 Answers
SOURCE: Open Port 81 on Netgear Switch
Actually you need to open the port on the cable modem / router. Switches just pass the packets along.
Posted on May 22, 2008
  • 9 Answers
SOURCE: Linksys SD208 8-port switch
you have to lay it on his back and pull a screwdriver under the dark front plastic and click it off by turning and then the above metal part.
Posted on Aug 31, 2010
How to fix NAT Xbox 360 problem on Huawei - Echolife HG520c (Vodafone) ? How to open prots on Huawei - Echolife HG520c (Vodafone) ?
In these situations, its almost always a firewall setting that is issue. Here's what I'd do:
  1. Read instructions and find out which 'ports' are needed to be open on your firewall. A port will be a numerical designation like '4567'.
  2. Find the instruction manual, and learn how to visit the Modem's configuration page. You will likely need to get the administrators password or re-set it. Each modem is different, you'll have to read the instructions on how to do that.
  3. Find the configuration page that mentions 'firewall' and 'port numbers' and 'open' that port which you found in step one.
  4. Save the configuration and try your game again.
Remember, each game could have its own set of port numbers in addition to any 'standard' X-Box port numbers are required. I would NOT recommend disabling the firewall entirely - just open up those port numbers that are need and nothing more.
Good Luck!!
Mark
Nov 11, 2013 | Vodafone Computers & Internet
My netgears nat type needs to be set from moderate to open so i can talk with friends and play games on my xbox 360's live connection
To do this you need to open Ports on the router, called as Port Forwarding
To achieve this you have to open ports 3074 and 88 (TCP/UDP)
Go to http://portforward.com/ Select your router model and you can forward ports on your router with the help of Screenshots on this Website
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614v9/Xbox_Live_360.htm
Hope this helps
Jul 07, 2011 | Computers & Internet
Xbox 360 nat type is strict, how do you fix it
In your Router's administrator configuration, find the UPnP setting and make sure it is enabled.
If this does not fix it, you will need to open ports in your router. You'll need to open the following ports and forward them to your Xbox's IP Address:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
Jan 24, 2011 | Microsoft Xbox 360 Console
Hello. I need to change my NAT type on my Xbox 360 from moderate to open using a Westell Versalink 7500 router.
Hello
Your router does not have moderate or open nat options.
Options that it does have are Public Lan - nat type and Private Lan -nat type.
Your router also has a DMZ feature and port forwarding options.
User manual for your router is available at http://www22.verizon.com/ResidentialHelp/HighSpeed/Networking/User+Guides/User+Guides.htm
To get your xbox live working properly, you can try using the public nat type, if that does not solve the problem, turn on DMZ for the address of the Xbox360. Now if that still does not solve the problem, then you would need to set up port forwarding for all the ports that xbox live uses.
I would personally recommend that you enable port forwarding for the required ports.
Ports that need to be open are
TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Together with the user manual and xbox360 portforwarding guides that are available here http://portforward.com/english/applications/port_forwarding/Xbox_Live_360/Xbox_Live_360index.htm
You will be able to get it working.
But since that is a lot of information for anyone that has not used port forwarding before I'll write down step by step how to get started.
First get on your computer, You need to connect to the routers own configuration page. By default this is http://192.168.1.1
So, open your internet browser and write HTTP://192.168.1.1 and press enter.
Now you get a a user and password prompt. the username is admin and the password is password. all lower case.
Now on the top menu, click on Firewall settings.
Now select Port forwarding. more information and pictures on the user manual page 98 and forward. You need to create a new rule or rules that forward the above ports - allow them to be open to the internet for the xbox 360.
Looking at page 112. You would create a new port forwarding service, you need to add all the ports one by one. And the host device would be the IP address of the xbox.
Now the DMZ option will be simpler, that is on page 118. You just need to find the xbox ip address from its network options and put it there, and turn on the DMZ. That will allow all traffic for that machine.
Let me know how far you get. I'll help if you get stuck, sorry if this post is a bit unclear, this is a very small box to write in, I can't easily see everything I've already written here.
Sep 27, 2010 | Computers & Internet
I have a Linksys WRT160N wireless broadband router. When I get on Xbox Live it says that I have a strict NAT type and I want an open NAT type. I have already enabled the DMZ, UPnP, and put in the proper...
try this :
1. Log into the router using 192.168.01. or 192.168.1.1
this is done using a browser window such as Internet Explorer or Firefox.
2. go to Application & Gaming
3. In the box on the right column us wan to enter the device ( example: Xbox)
4. you need to enter the start and end port next ( example: 88 and 80
5. then your protocol ( example: tcp ,UDP, or both
6.the IP address if next
7.check enable
8. then save
9. here is the site with an example page to configure your router.http://homecommunity.cisco.com/t5/Wireless-Routers/Xbox-360-NAT-issues-solved-WRT160N-v3/m-p/310658?comm_cc=HSus&comm_lang=en#M163159
Aug 21, 2010 | Linksys WRT160N Wireless Router
U Torrent port is not open since changing from a modem to a router its a Huawei Echolife HG520b type router.Torrent page is showing a red symbol,not green for faster downloading.The fire wall has U Torrent...
See the link below.
You should find this page on your router configuration where you can configure which port is open for which computer.
Its virtual server for your router. Look for NAT under Basic settings.
http://portforward.com/english/routers/port_forwarding/Huawei/EchoLife-HG520b/BitComet.htm
Jan 11, 2010 | Computers & Internet
My nat is moderate. how do i fix it to make it more open
You can simply forward ports. I believe you are using XBOX 360. Here are the ports that you need to open
3074 TCP
3074 UDP
88 UDP
80 TCP
53 TCP
53 UDP
You can open those ports using your router's Port Forwarding feature. To know more about portforwarding, you visit www.portforward.com
Oct 23, 2009 | SMC Barricade SMCBR14UP Router
How do i portforward a hauwei echolife hg520s router for bitcomet
Plz follow the step by step instructions given in below tutorial:
http://www.portforward.com/english/routers/port_forwarding/Huawei/EchoLife-HG520s/BitComet.htm
Thanks for contacting Fixya.
PLZ GIVE RATING BY CLICK ON YES or NO.
Mar 21, 2009 | Computers & Internet
How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
I assume you know the ip adress of your xbox.
First of all check on your router to see if UPNP is enabled.
Then go to Portforwarding/Port triggering.
Then add custom service
service name: the name of how you call it. doesn't matter really
service type is UDP
start port 88
end port 88
server ip is the adress of your xbox
then apply and make another custom service
name it how you want
service type tcp/udp
start port 3074
end port 3074
server ip adress of you xbox
this should work
Jan 03, 2009 | NetGear WGR614 Wireless Router
Computers & Internet Logo
219 people viewed this question
David Payne
David Payne
