Skachat sony pcg 972m
Doesn't turn on...the power light blinks if plugged but does't turn on if pressed the power button
SOURCE: Sony Trinitron KV-32fs120 Does Not Turn On
i have a unvirasal remote how do iget the codes for it
Posted on Sep 29, 2008
SOURCE: blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
Posted on Jan 02, 2009
leecom72
  • 4806 Answers
SOURCE: PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
Posted on Jan 21, 2009
  • 10 Answers
SOURCE: sony vaio pcg-grt170 when I push the power button,
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Posted on Feb 18, 2009
Kaisolo
  • 43 Answers
SOURCE: power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Posted on Feb 19, 2009
Sony vaio PCG-61211M wont turn on and the power button starts flashing on and off
This can be a sign of a discharged battery, and this may be due to a faulty adapter or the connection in the laptop.
Dec 13, 2013 | Computers & Internet
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
Sony pcg-grx52g/b not power ,when the power botton is press later it wil went off back and no more indicating charging.
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Apr 20, 2012 | Sony Computers & Internet
Sony vaio lapto black screen
Please check that they have any LED blinking. If it not blinking it is hardware issue. need to contact local tech. if it blinking. Reboot the computer and taping F10 button while you rebooting the computer and run system recovery and follow by the steps.
Mar 17, 2012 | Sony VAIO PCG-7181L, PCG-7182L, PCG-7183L,...
My Sony pcg-9c1l won't turn on!! When I press the
Could be your adapter, adapter socket - most common issues.
AC ADAPTER CHARGER POWER FOR SONY VAIO PCG 9C1L PCG 9D1L VPCCW14FX... Test your power adapter with a multi-meter. Example below
Hope this works to help you and your situation.
Mar 11, 2012 | Sony Computers & Internet
My Sony vaio pcg 3c2l has locked up. The keyboard stopped responding and now the screen is black, but the power light is still on. The power button doesn't respond when I push it. What should I do?
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 05, 2011 | Sony Computers & Internet
Sony Vaio PCG-K33 will not power up
Hi
Ensure battery is secure, If so try removing it and plugging power supply in.ensure all power supply plugs are very tight and fitted, unplug each one and re-plug in to be sure. Sometimes the power supply lamp can be on but not actually supplying power out the other end.
Aug 17, 2009 | Sony VAIO PCG-K33 Notebook
Sony vaio pcg-grt170 when I push the power button, the green light and 2 yellow lights blink one time but the computer will not turn on. I tried taking the battery out, checked the power cord.
Feb 18, 2009 | Sony VAIO GRT170 Notebook
Won't stay on
IS THIS WITH BOTH AC CORD AND BATTERY
you probably need a power supply
before you run out and buy one start and press f8 then start in safemode see if the same thing happens
also make sure your AC adapter is connecting with internal connection the internal connection can become loose or bent from constant plugging and unplugging
Jan 22, 2009 | Sony VAIO PCG-K35 Notebook
Hi there
post back
Jan 21, 2009 | Sony VAIO PCG-K35 Notebook
Computers & Internet Logo
David Payne
David Payne
