Question about Epson Stylus Photo 1410 Printer
Maintainance its not removing all the colors when printing
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 50 Answers
Clean printer heads
Posted on Mar 20, 2014
How to install ink cartiges
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Aug 27, 2011 | HP Photosmart C4280 Aio Printer
I HAVE JUST REFILLED MY LEXMARK X2550 PRINTER COLOR CARTRIDGE NUMBER 35, BUT A MASSEGE ON MY PC SAYS: "Invalid Cartridge". How do l get it to be recognised so that l can use it?
hello
35 is color ink cartridge .. high yield,
A new color print cartridge needs to be installed.
If available, click the Continue button on your computer screen to print using the
black (or photo) print cartridge. (The Continue button is available only at the
beginning of a print job.)
Note: A variable amount of ink remains in the color print cartridge.
Follow these steps to replace the color print cartridge in your printer:
1 Cancel the print job if not already canceled.
2 Replace the color print cartridge with a new cartridge. For more information,
see "Removing a used print cartridge" on page 35 and "Installing print
cartridges" on page 35.
3 Print again.
To order supplies, click Order Ink on your computer screen. You can also see
"Ordering paper and other supplies" on page 40 in this guide.
Troubleshooting 54
manual = http://www.lexmark.com/publications/pdfs/2007/2500/v3708617_en.pdf
Installing print cartridges
1 If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
1 2
Warning-Potential Damage: Do not touch the gold contact area on the back or the metal nozzles on the
Maintaining the printer
35
list of ink cartridge part numbers
http://www.lexmark.ca/lexmark/product/home/455/0,6970,204812589_653399443_1037657543_en,00.html?tabId=7
Dec 23, 2010 | Office Equipment & Supplies
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
Have changed the black ink in the printer as it was displaying error code 4. It is now displaying error code 5! What does this mean. What should I do?
Error E5.
Cause : The FINE Cartridge may not be installed properly or the Cartridge may not be the compatible with the machine.
Action : Install the appropriate FINE Cartridge. If the lines are misaligned or the resulting output is not satisfactory, carry out the FINE cartridge Alignment.
Replacing A FINE Cartridge.
When replacing a FINE Cartridge, check the model number very carefully.
The machine will not print properly if the wrong FINE Cartridge is used, or installed incorrectly.
Black : PG-40 Black
Color : CL-41 Color
The FINE Cartridge PG-50 Black (High-Yield) and CL-51 Color (High Yield) are also compatible with this machine.
When a FINE Cartridge runs out of ink, replace it using the following steps.
1) Ensure that the machine is turned ON, and then open the Scanning Unit. The FINE Cartridge Holder moves to the left.
Pull the Scanning Unit Support down into place.
2) Remove the empty FINE Cartridge.
a) Push the FINE Cartridge carefully to avoid staining your clothes or the surrounding work area.
b) Remove the FINE Cartridge.
Important : * Handle FINE Cartridges carefullu to avoid staining your clothes or the surrounding work area.
*Discard empty FINE Cartridges according to local laws and disposal regulations.
Caution : Do not touch the transparent film, film cable, ink absorber (sponge part) or any metal parts.
3) Prepare a replacement FINE Cartridge.
Unpack a new FINE Cartridge and remove the Protective Tape.
Important : * Do not reattach the Protective Tape once you have removed it,
* Handle the removed Protective Tape carefully to avoid getting your hands dirty or staining the surrounding work area once you have removed it.
* Once the Protective Tape is removed, do not touch the gold terminals of the FINE Cartridge or its nozzles. The machine may not print out properly if you touch the terminals.
4) Insert the new FINE Cartridge.
Black FINE Cartridge should be installed into the left holder and Color FINE Cartridge should go into the right holder.
a) Insert a new FINE Cartridge on a slight tilt.
b) Push the FINE Cartridge up until it clicks into place.
5) Close the Scanning Unit.
Lift the Scanning Unit slightly and put the Scanning Unit Support back to its original position,
Then close the Scanning Unit.
The FINE Cartridge Holder moves to the right.
Note : IF the straight line is misaligned or the FINE Cartridge position is misaligned, align the FINE Cartridge position.
Important :
* To maintain optimal print quality, we recommend that you use Canon brand FINE Cartridge. Replenishing ink only is also not recommended.
* Replace the FINE Cartridge runs out of ink, replace the FINE Cartridge with a new one immediately. If you replace it with the FINE Cartridge that has previously been removed, the machine may not print properly due to clogged FINE Cartridge nozzles. Furthermore, the Low Ink Warning dialog box which advices when to exchange the FINE Cartridge will be inaccurate.
* To maintain optimal print quality, use up all the ink in the FINE Cartridge within six months of its first use. (We recommend that you note the date that the FINE Cartridge was installed in the machine.)
* Color ink consumption may occur even when black-and- white or gray-scale printing specified.
Color ink is consumed during Cartridge cleaning, which is necessary to maintain the machine's capabilities.
Aligning The FINE Cartridge
If ruled lines are misaligned or a printout is unsatisfactory, FINE Cartridge Alignment is required,
* Aligning the FINE Cartridge
1) Press [Maintainance] repeatedly until <P> appears.
2) Press [Black] or [Color].
The machine prints the head alignment sheet.
3) Beginning from Column A on the printout, enter checkmarks in the patterns that have the most solid image.
4) Load the checked sheet on the Platen Glass.
When loading the checked sheet, place the front side down, and align the upper left corner of the sheet with the alignment mark on the lower right corner of the Platen Glass.
5) Press [Maintainance] repeatedly until <U> appears.
6) Press [Black] or [Color].
The machine scans the pattern and aligns the FINE Cartridge automatically.
Note : If you select <L> in step 1, the machine prints the current FINE Cartridge Alignment setting.
Hope this helps.
Please rate my response
Thanks.
Have a good day.
Dec 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Cant figure out how to put in the ink cartridges
Procedure for replacing Cartridge
When FIne Cartridges run out of ink, replace them. using the following steps.
*Important
Handling Fine Cartridges
-Once the protective tape is removed, do not touch the electrical contacts or Print Head Nozzles on a FINE Cartridge. The printer may not print out properly if you touch it.
-To maintain optimal printing quality, we recommendthe use of specified Canon brand FINE Cartridges.
Refilling is not recommended.
-Once you remove a FINE Cartridge, replace it immediately. Do not leave the printer with the FINE Cartridge removed.
-Replace empty cartridges with new ones. If you insert FINE Cartidges that has been removed once, the printer may not print properly due to some reasons such as clogging of the nozzles. Furthermore, with such cartridges, tlhe Low ink warning may not be displayed properly.
-Once a FINE cartridge is installed, do not remove it from the printer and leave it out in the open. This will cause the FINE Cartridge to dry out., and the printer may not operate properly when it is reinstalled. To maintain optimal print quality, use a FINE Cartridge within 6 months of first use.
-Color ink may be consumed even when printing a black and white document or when black and white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the printer's performance.
1) Make sure that the printer is on, and then open the Front Cover.
The FINE cartridge Holder move to the left.
Cautuion : * Do not hold the FINE cartridge Holder to stop or move it.
* Do not touch the metallic parts inside the printer.
Important : If the Front Cover is left open for more than 10 minutes, the FINE Cartridge Holder moves to the right. Close and reopen the Front Cover to return the holder to the left.
a) Push down the FINE Cartridge.
Important: - Handle FINE Cartridge carefully to avoid staining your clothes or surrounding area.
-Discard empty FINE Cartridges according to the local laws and regulations regarding disposal of consumables.
3) Prepare the replacement cartridge.
a) Unpack a new FINE Cartridge and remove the orange protective tape. gently.
Important : - Handle FINE cartridge carefully to avoid staining your clothes or surrounding area.
- do not re-attach the protective tape once you have removed. Discard it according to the locals laws and regulations regarding disposal of consumables.
-once the protective tape is removed , to not touch the electrical contacts or Print Head Nozzles on a fine cartridge. The printer may not print out properly if you touch it.
-Be careful not to stain your clothes and hands with the ink on the removed protective tape/
4) Install the FINE Cartridges.
a) Insert a new FINE Cartridge all the way into the appropriate slot. The Black FINE Cartridge should be installed into the left slot and the Color FINE Cartrige should be into the right slot.
b) Push up the FINE Cartridges until it clicks into the place.
Important : The printer cannot be used unless both the FINE Cartridges are installed.
5) Close the Front Cover.
Hope this helps. Please rate my response.
Thanks,
Have a good day.
Nov 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Color Ink print bleeding/running
you need to perform a head clean, you should be able to perform this from the printer tools / maintainance
Apr 24, 2009 | Office Equipment & Supplies
Color cartridge does not work - color faded. Just replaced AGAIN today - same problem
Remove it,replace it couple of times.
Run a nozzle and printhead cleaner check,
from your printer's properties, maintainance.
align too, just to be sure your setup correctly.
Check your printer settings for quality of the print.
there are various choices there for you.
Should be good then
Regards
Richard.
Apr 21, 2009 | Lexmark Color JetPrinter Z52 InkJet
Printer wont print in color and i just replaced with all new ink cart.
new cartridges can be defective also.
Remove and re-insert the cartridge, double check them,
( leave printer on )
Check printer's Advanced properties are not set for black only,
switch off at mains, reboot,
Run maintainance on it, head cleaner, nozzles etc...
if the same, swap out, the color cartridge it is faulty.
Hope this helps
Regards.
Apr 16, 2009 | Canon i850 InkJet Photo Printer
Hp 9130 printing blue stripes on photos...
On the control panel, press MENU.
Press (up) or (down) to move to the item you want, and then press (select).
Go to maintainance.
Press - or + to select the value that you want, and then press (select) to save the setting.
If there is no - or + around the setting, the setting cannot be changed.
on the maintainance tab is,
clean heads, align, calibrate, etc..
Hope this helps
Regards.
Apr 16, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Printer will not print with color cartridge in
go to dell AIO center
click maintain/troubleshoot on the top
under trouble aio problems - click ink levels
click maintenace tabs
and then clean print cartridges and align print cartridges. then try printing a test page.
if this does not work, remove the cartridges and install them again.
let me know how it goes
Sep 08, 2007 | Dell Photo 964 All-In-One InkJet Printer
Epson Stylus Photo 1410 Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
