Question about Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
Upgrading electric motors - Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
    Master:
  • Electric Mob... Master
  • 401 Answers
Cost around $850 for scooter, and a powerchair has two motors! So powerchairs will be more. email me at Strege Mobility
Posted on Jul 03, 2016
Rcvd new pentair 1 hp pool pump replumbed and did the electrical connection. motor get real hot and shut off. i used the correct 12 ga wires and wire it for 115v. do you think i got a bad pump. it did...
Assuming everything is electrically correct, the motor probably has a short in the winding somewhere. The motor should have a one year warrantee on it. Any pool store ought to be able to trade it out for you.
Sep 14, 2013 | AO Smith 2hp Pool Pump Motor Ao Smith...
Reverse and low gear not working. just got done replacing gear selector and wiring harness( upgraded kit ) to fix this and still having same problem. could it be the foot feed switch is going bad?
if the foot pedal wasn't working you wouldn't get any power at all, i had this same problem with a peg perego john deere tractor and it ended up that one of the motors was bad. I would disconnect one fo the motors and then try all of the gears and then try the same with the other motor and see if that works, you'll have to pull the rear wheels off to access the motors
May 01, 2012 | Polaris Outlaw Motorized ATV
How can upgrade my gaucho rock in from 12 a 24Volt
you would need 24 volt motors and the circuit board, and shifter switch, and foot pedal switches
Sep 10, 2011 | Peg Perego Gaucho Rock'in
Refrigerator causes am radio static and tv static interference . what is the problem, and it dangerous?
What you probably hear and see is the AC hum of the electric motor of your refrigerator broadcasting at 60hrtz, and 120hrtz. Normally the ground leads of your electrical system is sufficient to absorbs this rf interference. I suspect that your electrical system is an older system in which the third ground lead was not run in order to tie all of the grounding of the electrical system to each other so as to absorb all of the noise put out by ac induction motors. This was common in the 1950s, and many systems have been upgraded to provide for that third ground lead. It is not dangerous, but a trifiling bit annoying.
Feb 14, 2011 | Refrigerators
THE MOTOR OVERHEATS AND SHUTS DOWN EVEN ON A SIDEWALK WITH ONE SMALL CHILD. THE BOOK SAYS IT WILL DO IT IN SAND? CAN I BYPASS THE LIMIT SWITCH SOMEHOW?
you just need to order the motor upgrade kit, might still be covered under warranty, let me know if you need me to order on for you
Sep 08, 2010 | Polaris 800 Twin Sportsman Ride on Toy
Hsp bruchless
Hi there
I have the same electronics on hsp rally monster pro. 3300kv - but 75A ESC, i upgrade it to 6000kv with 5000A lipo without any programing to the ESC . it worked fine for couple of runs but i faced wires over heating problems after that something wrong went to the ESC !!! . .
Am going back to 3300kv, but need advice of what is the higher ampers/voltage battery can i use?
Apr 10, 2010 | Electric Novatech High Speed Brushless 70A...
Slow after new motor
I can only assume that the new motor had a different gear ratio, this seems to me to be the only reason it would run slower.It should be printed on the motor itself or on the info that came with it.
Mar 18, 2009 | Electric Traxxas Stampede Xl-5 Rtr ...
1994 gmc 4x4 non engaging high range four wheel
I would check to see if it is the Axle Actuator.  On that model truck there is an upgrade available that is electrical upgrade.  Instead of using a vacuum to engage the axle, it uses a small electric motor.  The cost for this part isn't much more than the older vacuum model.  Usually the electrical one runs around $100.  This is a relatively easy change that most any person can do with just about any experience.
Feb 03, 2009 | 1994 GMC Sierra
Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter Logo
80 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
