Question about Garden
Can it operate for 10hour non stop - Garden
  • 3,961 Answers
No.
Posted on Feb 11, 2014
After you stopped supporting my epson adobe PhotoDeluxe. why should I buy another for an unspecified time?
we did not do this as we are not adobe !
Are you referring to the very known problem of the non existent adobe activation server for your program that prevents you re-installing your software ?
There is a work around for the non existent activation server
https://forums.adobe.com/message/4919014#4919014#4919014?sdid=KCHDS
Mar 23, 2016 | Adobe Computers & Internet
Sony vaio pcg-71613l - Non functioning cpu
It has failed to load the windows operating system, that why it is showing the DOS prompt.
You need to reload a working operating system such as Linux from disk to see what the problem is.
Oct 01, 2014 | Computers & Internet
Non return isolating valve dripping water tinuously
you have trash in the valve .shut it down take the valve apart clean it . also maintenance on this unit is needed.seal can be bad also. hope it helps.send pictures of the unit and age and model serial number.
Apr 06, 2014 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Dryer won't spin
If you have kids and they over fill the dryer it strains all systems including the heater because it cannot get rid of excess heat. Solution*** Possibly needs a new belt
Dec 07, 2012 | Maytag Dryers
Whre5550k2ww
The motor/inverter on this washer stores fault codes. The LED you see blinking will blink once every second non-stop when in stand-by mode and twice every second non-stop when it should be running. If there is a fault code the LED will blink a certain number of times then stop for a few seconds. Some of the fault codes not allow the motor to operate. Post back the blink code.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE WBSR3140DW Top Load Washer
KithenAid model KUDSo1DL wont operate, clean green light flashes non stop
This is a issue with the way the water is moving & or heating in the unit. There should be a tech mini manual behind the motor kick panel. The manual describs the failure and it's correction. Depending the the model year & run / revision code, this error could be caused by low water level, a bad thermistor, the control board not sensing inputs, bad heater or door interlock switch issues. attached is a couple of help sheets. They are general in scope.
Mar 27, 2012 | KitchenAid Microwave Ovens
Blue screen appears at start up boot screen and restarts again
press "F8" while statrting , and then select "safe mode"
Feb 01, 2011 | Computers & Internet
My Stackable washer/dryer is not operating right
Two things:
1) I would first check your water pump, if something gets in it or the water pump bearing is bad, it makes this kind of a sound.
2) If you can spin the washer drum by hand in either direction, the transmission is bad.
Good Luck!
May 03, 2009 | GE Spacemaker Washer and Dryer Electric...
Electric spark for gas range burner is non stop
Turning any knob starts the spark via a switch behind each which should disengage when the (any) knob is turn further.
One of your switches is stuck.
I think you should be able to remove the range-top for access and find the offending switch.
It is probably gummy from a spill and is no longer in solid contact with the cam that operates it.
A solvent/lubricant such as WD-40 sprayed on the plunger of the switch once you can see it and operating the knob back and forth should free it up.
It might be wise to turn off the gas supply while tinkering with the range - blow your house away and the range won't matter. :-(
Jun 19, 2008 | Viking VGSC306-4B Gas Kitchen Range
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
