Panasonic washing machine wont spin. model NA-W68B2
Spin tube not spinning when Spin Timer is on. It only makes the sound tatatata.....
5 Suggested Answers
SOURCE: washing machine
Please check if the drain solenoid is functioning. This may caused the problem.
chris
Posted on Mar 24, 2008
  • 249 Answers
SOURCE: washing machine wont spin in spin cycle ,makes
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Posted on Jan 01, 2010
  • 942 Answers
SOURCE: washing machine drains, wont spin, making clicking
If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jan 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: Panasonic washing machine noisey
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 19, 2010
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
Whirlpol top loader does not spin all the time
Since you did not mention the age of this unit I am assuming that it has been in service for some time. My first thought is that you have an intermittent lid switch. You can test this yourself by setting the timer on spin and then open and close the lid at aout 10 second intervals making sure the tub spins and stops. It should spin lid closed and stop lid open each time. If it does not spin each time then you have a lid switch problem. If it does spin each time then I suspect that your spin tube clitch pads are getting worn. You cna remove the back panel cover and watch this again with the timer in spin. Keep you hands out of the inside rear of the maching and look When the lid is closed the spin tube should be lowering slightly onto the drive plate. If it appears to be slipping quite a bit then the 3 pads are worn out and the spin tube will have to be replaced. On other thing to note is there are 2 solenoids on a post on the top of the transmission. On the one controls the spin cycle you should see the actuator lift and fall as you have some one open or close the lid in the spin cycle. If the actuator is lifting and the spin tube clutch pads are dropping onto the clutch plate then again the 3 clutch pads have worn out. I hope this was of some help in answering your question.
Jan 09, 2010 | Washing Machines
Will wash clothes but not spin them dry
This is a little about how your washer spins. When time to go into a spin cycle, the motor is already running and the washer is in a pump out mode. The timer advances and closes contacts in timer that make electrical circuit through the lid switch to the spin solenoid. This is normally done through a gray wire from timer to lid switch and then a red wire from lid switch to the spin solenoid. A white common wire completes the circuit. This spin solenoid is on a magnet bar with the agitate solenoid also on it. You will see it under the machine moving back and forth as the motor runs. This magnet bar is called a wigwag in the appliance trade. When the spin solenoid is energized, it sucks a plunger pinned to the spin cam bar up into the solenoid. The plunger pin goes to a different level in the cam bar and pulls it in the direction of the motor and keeps it there until spin cycle is over. When cam bar is pulled back, it allows the clutch to drop down and engage the spinning center pulley attached to the spin tube. The spin tube turns, the wash basket is locked to spin tube, therefore it spins. Now for your question. What goes wrong?
1. The solenoid can be open. Watch it and if it doesn't **** the plunger up, check with an ohm meter. If solenoid good, assume no power to it.
2. No power to solenoid. You will need to check the circuit from timer, through lid switch, to solenoid. Most likely place seems to be lid switch. check it.
3. The wires coming to the solenoid are constantly moving back and forth as the machine runs. This puts tension on the wires and they tend to break inside the insulation of the wire. To check for break internally in the wire, read from one end of it to other with ohm meter. Another way is to grasp wire (unplug the washer) about 8 inches back from end and pull hard on end of wire. If broken inside, it will pull apart and stretch insulation. Replace wire. There are mechanical operations that can give problems, but most spin problems are in the area that I just addressed.
Another common trouble maker has cropped up in the last few years. The set screw on the clutch assembly backs out and this will keep the brake on all the time and the washer will either spin very slowly or not spin at all. Sometimes the hole in the spin tube will become damaged and requires the clutch to be replaced, but sometimes the sets screw can be reinstalled. (unplug the washer) You must remove the set screw and line up the holes by slowly turning the inner basket around. I usually use a piece of hard wire pushed into the hole, once the set screw hole and the spin tub holes are lined up you will be able to push the wire in...add some lock tight to the screw threads and reinstall the set screw. Picture of where this set screw is.
Nov 27, 2009 | Kenmore 24902 Top Load Washer
Kenmore top load washer does all the cycles but it will not spin out. Could this be a timer problem?
it could be a timer problem but this could also be a 'spin tube' problem or a motor problem. The transmission spins in two directions. If the motor won't turn for this, then you could be looking at a bad motor. The spin tube holds the basket so that it will spin out, so if this is bad, you are looking at some work to replace this. If it is the timer, you need to find the same one. If this is an older machine it may not be worth the trouble to fix it.
Aug 31, 2009 | Washing Machines
Washer won't spin makes banging sound
remove the agitator. there is a cone shaped block on the agitator shaft and locked to the tub via a large lock nut. spin tube has 2 tabs that lock into slots on top of block. these can strip out and cause the spin tube to spin inside block. watch it and turn machine on spin. tub can also drop and drag on bottom of outer tub. if this is it replace block and gently straighten tabs on spin tube.
Jun 11, 2009 | Whirlpool Washing Machines
Whirlpool washer will not go into spin cycle by itself
if you changed the clutch and gearcase is trying to spin could be possible bad spin tube ..ck to be sure brake is backing off remove gearcase and try turning the brake to back off drum.. tube be be binding against bearing in tub support
Oct 23, 2008 | Washing Machines
Kenmore washer won't spin
This should help you get to the coupler between the motor and the trans.
Good Luck
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Washer not spinning - not timer
I have a Kenmore 80 series mode #2289400. It will wash but will not drain and spin. I have turned the knob to a different spin cycle put it won't spin. I have drained the water out of the tub thru the drain pipe so it's not plugged. When it's ready to spin and it making no noice. Any help would be great.
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
