Question about Zebra TLP 2844-Z Thermal Label Printer
Top try is full of paper remove the paper - Zebra TLP 2844-Z Thermal Label Printer
Shredder bin full
Most models: 1) unplug, 2) put something down to collect paper bits, 3) lift up the shredder top unit off the bin, 4) empty the bin, 5) try and pull out any paper from the shredder top using tweezers - first remove paper that has not fed through by pulling it back out.
Often if the bin is overfull the shredder gets clogged and won't work or beeps. When unplugged, you have to carefully remove all the bits of paper from the teeth to unjam the two rows of teeth. Remedy is to frequently empty the bin.
Jul 29, 2014 | Office Equipment & Supplies
Standard top bin full?
I suggest you remove any sheets of paper from top tray then lift up and release a black plastic flap found under a plastic overhang on paper exit tray. This lever (If its not broken/missing), should be free and should drop down(under its own weight) freely. If not then it will involve using the manual to remove the top cover and find where lever is jamming (usually jumped out of a guide bearing.)
regards
carmike
Feb 17, 2014 | HP LaserJet 5200tn Printer
Standard top bin full remove all paper from bin
there are four black plastic finger type actuators protruding from the exit rollers ( in the catch tray) these help push the paper down after exit from printer - in some cases where damp paper is common the curl generated by the fuser heat is enough to trip these \'Fingers\' into the position where the printer thinks the output tray is full to capacity
do you ntoice when the paper leaves the machine if there is any curling in the paper if this is the case open a new ream of fresh paper and try again
also the output tray full sensor is probably covered in dust/paper debris- removing the top cover will reveal the position of the sensor connected to the actuator arms clean and dust this to cure error ( assuming theres no damp paper)
Dec 11, 2013 | HP LaserJet P3005 Printer
Standard bin full
This error is cause by either having your output paper bin full of paper or the flag sensor out of alignment where the paper comes out of the top. Look at the top f the printer where the paper comes out and you should see a black plastic sensor flag, it should move freely. If it is stuck remove the top cover above it and try to free it so it can move. Below is a picture of the printer with the output sensor flag circled.
Feb 02, 2013 | Lexmark T632 Laser Printer
Check the sensor flag where the paper exits the printer and make sure it is not stuck in the "up" position. This is a small black plactic flap right in the center of where the paper exits. When this flap is up it tells the printer that this area is full. HP says to "flip" the sensor flag up and down to make sure it is not stuck.
Good Luck
Nov 25, 2009 | HP LaserJet P3005 Printer
My printer Lexmark T634 is showing "remove paper standard bin"
What your printer is telling you is that it thinks or knows that the top exit tray for the paper is full. This is the tray that is moulded into the top of the printer.
This caused by two things. It is actually full or the Bin Full Actuator is out of position and forcing the error condition.
Look at the standard bin. Over to the top at the top left corner there should be finger (almost the same as paper clip) hanging down. If it is not there, then it is more then likely that the finger is jammed up.
Don
Nov 04, 2009 | Lexmark T634 Laser Printer
Officejet Pro L7780 will not feed paper from bottom bin. Tries twice then defaults to top bin
Check that the paper path is clear.
Check that the paper is dry.
Check that the paper pick ups and rollers are clear of any debris - Power off the machine at the mains and brush them with a damp cloth or brush and maybe vacuum out the entire area to remove all dust etc.
Make sure that you fan out the paper before inserting it into the tray and that the tray is not over full as this will prevent the paper being collected successfully. Try running with half a tray full instead of a full or near empty tray.
This should resolve your problem.
Sep 12, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Standard top bin full remove paper
Greets!
Firstly, is the exit bin full of paper? If it is, just remove it.
If not, then it's going to be a sensor that recognizes the paper amounts in the exit tray. Check for broken plastics and possibly stuck plastic flaps in the exit tray.
If it's neither of those, try turn it off, unplug, then reverse.
Other than that, if no go, then it's an internal sensor issue. At that point, probably the best bet is to replace as repair costs would outweight a new unit cost most likely.
Feb 26, 2009 | HP LaserJet P3005 Printer
My NEC 870 laser printer has paper jam. How can I fix it?
Open the top printer door by pressing the round release button on the left side of the printer. Remove the toner cartridge (numbered 2) and the photoconductor cartridge (numbered 1) from the printer. This will give you full access to the paper path and you should be able to remove the jammed paper. If you pull on it and it begins to tear or is feels like it is caught on something, remove the paper and paper tray from the front of the printer and try to reach and remove the jammed paper pulling it back out the direction it went in.
With the jam removed, replace the paper tray and paper, re-install the photoconductor (#1) and the toner cartridge (#2) into the printer and close the top door. Make sure you get the door closed firmly and that it catches otherwise you will still have an error light and not be able to print.
That should fix your problem... good luck! :-)
Jan 31, 2009 | NEC SuperScript 870 Laser Printer
Hp 3800dtn standard top bin full remove paper error
top bin full error is hte lever sensor where you see the paper coming out, the lever is stuck in the up position.
It's used to tell you to remove the paper from the exit because it's too full.( Too many copies on the top)
Jun 27, 2008 | HP Color LaserJet 2600n Printer
Zebra TLP 2844-Z Thermal Label Printer Logo
14 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
