Question about Mitsubishi WS-55805 55" Rear Projection Television
How do i reset my a/v on the mitsubishi ws-55805
Slinteriors
  • 8617 Answers
SOURCE: my remote control for the mitsubishi ws 55805 broke
Heres a link to the replacement remote for your model. It controls all the functions and doesnt need programing since its the replacement for your remote.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-290p080a60-replacement-remote
Posted on Jun 15, 2009
  • 8457 Answers
SOURCE: my bigscreen TV Mithsubishi model WS-55805 just
This problems,the 2 STK convergence ICS are dead,u discribe the problem before the picture is gone that great.That how I came to this conclusion.Must know how to solder,have tools relating to soldering to fix this problems.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Posted on Apr 28, 2010
asnowman
  • 788 Answers
SOURCE: Mitsubishi WS 55805 has green, red, and blue
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT’s in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jul 26, 2010
SD Tech
  • 14553 Answers
SOURCE: 11 1/2 year old Mitsubishi WS-55805 - 55 in rear
This model should use two of the STK392-040 convergence IC chips.
Parts cost on Ebay for a pair of these is under 35 dollars.
Repair does involve soldering and removal of middle board in order to get at the parts.
I have step by step instructions for a similar model that is available.
If you or someone you know can do the repair you can save a lot of money and the set.
These sets are much more reliable than the Plasma and LCD type sets.
Here in San Diego most shops get about 200-300 for this repair.
It can be done in your home, I have done hundreds of them in homes.
If you want to see the instructions let me know and we will find a way to get them to you.
Before you rate this information let me know if you have questions.
SD TECH
Posted on Jul 21, 2011
SOURCE: Mitsubishi WS-55805 turns off before it is
My WS-55805 set gave me an error code of 2 blinks followed by 3 blinks. What does this mean?
Posted on Oct 04, 2011
Mitsubishi WS 55805 nothing but blue screen and black square in middle
A full service manual is available online---I will presume you tried to unplug it for a while and then power back to see if will reset itself.
This set has three hidden menus---one is the OPTION menu--in that menu with the Mitsubishi remote you can do a hard reset of the entire set= sets all back to factory except convergence adjustments which are stored in another area--cures all kinds of oddball issues.
I can give you a link to the manual and the page numbers for the OPTION menu.
Note: the other two hidden menus are Convergence and adjustment--do not go into adjustment menu as one wrong move and poof!
SD TECH
Apr 20, 2012 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 turns off before it is completely on
please do the following:
When green light comes on and then goes off, ON the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and release both buttons.
Power light should blink a two digit error code; most common is:
2 blinks, 2 blinks, a pause and it will repeat the error for a total of five times.
Let me know what error you find and I will tell you what it means.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Aug 16, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 CRT projection TV with
This problem is most likely caused by damage in the convergence output amp IC's; this model uses STK392-040. Fairly common for various fuses that protect the DC supplies for these amp IC's to open as well.
Mar 03, 2010 | Televison & Video
My remote control for the mitsubishi ws 55805 broke
Jun 15, 2009 | Mitsubishi WS-55805 55" Rear Projection...
2004 Mitsubishi WS-55813
You need the V23 Chassis DM repair kit which has the replacemnt capacitors and the instructions on how to do the repair. Heres the link to the kit. You also get the full service manual on the instructional CD as a bonus.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Jan 16, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Online repair manual for mits 55805
Good Day, TraderGordo;
I will E you the info.
Good Luck, big IRISH.
Aug 14, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Parts and repair
go to www.ptscorp.com and send the board in
Dec 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
My ws 55805 yr. 2000
check this site first
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
if you dont have this in your set then
check convergance amp ic.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Tv works, DVD, Xbox or anything requiring a different input
I had the same problem- i forgot wht caused it but it had something to do with the type of inputs i was using. try using the normal RCA inputs or S-video input for the DVD or Xbox
Feb 17, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
