Question about Orion HCCA-D2400 Car Audio Amplifier
Esp light comes on first and then the protect light comes on
What is the esp indicator for on a car amplifier
I found this
when illuminated (yellow) indicates ESP®
functionality and
is used to diagnose ESP®
features. The LED flash characteristics will assists in diagnosing the type of fault (see Appendix).
NOTE: The LED on top of the amplifier may also illuminate and flash with the ESP®
LED
indicator, if this option has been enabled by your installer (requires Bitwriter®
12. ESP®
Port - connection port for Bitwriter®
or ESP2 security system.
I googled it but all i came up was people with a flashing light and mine was solid so i figured id askk!!!! but i think i figured it out i took the sub out and pulled the box terminals and tightened them cause i noticed they were loose and viola it worked.
To further confuse I found this, but don't believe it.
ESP ties the amp into your vehicle's alarm system. If the amplifier is working normally you can ignore the light. Note that this is NOT the protection LED for the amplifier.
Aug 24, 2015 | Cars & Trucks
ESP light comes on and then engine cuts out?
ESP stands for Electronic short protection you need to get it into a shop
Dec 22, 2014 | 2006 Volkswagen Caddy 1.6
Audi a4 camshaft
take to a audi garage befor you do some expensive damage
Mar 26, 2014 | 2004 Audi A4
2002 audi a4 esp light comes on a few minutes after starting? any help?
esp light comes on after driving for few minits and goes out when i slow down can any one help audi a4 2.5 v6 tdi 2002
Feb 24, 2011 | 2002 Audi A4
I havea 2009 tuscon sx. the ESP OFF light comes on occassionally affecting the gearbox & not allowing the car to get out of gear. the ESP OFF button on the dash doesn't do anything. We have taken it...
Whenever that ESP/ESC warning light comes on, there is a diagnostic code set (DTC). This code tells the technician which component in the system CAUSED the ESP/ESC control module to turn ON the warning light!
Did the technicians SCAN for any DTC's? Since the vehicle is a 2009, the service department is supposed to have Hyundai's GDS (Global Diagnostic System) available to do this. If they don't have this equipment, find a service department that DOES!
Feb 08, 2011 | 2009 Hyundai Tucson
ESP/BAS WARNING LIGHT COMES ON AND STAYS ON SOME TIMES. HOW DO I KNOW IF THE ESP IS WORKING
If the ESP light is on, the system is not functioning. have your dealer look at and replace your Brake Light Switch
Dec 06, 2009 | 2006 Jeep Grand Cherokee
I have a Directed D2400 amp and my red ESP is on
Nov 04, 2009 | Directed 2400d Car Audio Amplifier
Jetta beeps 3 times while ESP light is on
Probably one of the ESP sensors have faulty connection.These sensors measure the speed of the wheels ,if they are not connected then ESP cannot work.For safety reasons the system will not start up and gives you this error message.
Jul 07, 2009 | 2003 Volkswagen Jetta TDI
My brand new ESP 5 will not print red letter on a
It seems to be a problem with the colour ink cartridge ,did you remove the protective tape that came with it?
you should return the colour cartridge and get it replaced or buy another one.
If that doesn't solve it then return the printer since it's under warranty.
Jun 15, 2009 | Kodak ESP 5 Printer
Orion HCCA-D2400 Car Audio Amplifier Logo
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
