Error code 222 on a Linde H25 forklift typically indicates a problem with the lift's hydraulic system. This could be caused by a variety of issues, such as a malfunctioning pump, a faulty valve, or a leak in the hydraulic system.
You can try this:
Check for any visible leaks or damage to the hydraulic lines or components.
Check the hydraulic fluid levels and make sure they are at the proper level.
Check the operation of the lift's controls and make sure they are functioning properly.
Check the operation of the lift's safety features and make sure they are not activated.
If the problem persists, you may need to call a professional forklift repair technician to diagnose and fix the issue. They will be able to determine the root cause of the error code and provide the necessary repairs.
