Question about Canon imageRUNNER 2520 Laser Multifunction Printer
Xerox 2520 copier when machine start some part lose there that, s why sound is coming out & only half paper is come out from output side.what can i do?
Tell me why sound come & paper jam inside in half part.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
First check the paper size of casset detecting properly, if ok, check your fixing unit film...maybe the sound comes from the fixing film
Posted on Feb 17, 2014
  • 12 Answers
SOURCE: paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Posted on Feb 06, 2007
SOURCE: Canon MF4150 Duplex Printing Paper Jams
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 148 Answers
SOURCE: How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Posted on Jan 05, 2009
  • 153 Answers
SOURCE: canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Posted on Apr 09, 2009
supersaiyan1
  • 5 Answers
SOURCE: Canon MX700 - Error - Paper Output Slot - Paper
Try this link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651
Posted on Nov 07, 2009
My copier says there is a paper jam but there is no paper in it.
ir 2520 is a single cassette copier if it has more cassette then you have to look over the side cassette doors. u will find some actuators over there. mainly there are 3-4 actuators in the basic machine.
1. pick up assy
2 bottom of registration roller
3 fuser unit
4 exit section
u have to look over these actuators and their springs. if these are not working properly then the jam message will display.
Mar 12, 2015 | Canon imageRUNNER 2520 Laser Multifunction...
Xerox 6330 loud clicking sound
Check the rails the paper tray sits upon. see if the one on the right side is damaged or dislodged. You didn't say if the noise happened when you printed from the 2nd paper tray.
Apr 01, 2014 | Xerox Phaser 6360 Laser Printer
Xerox phaser 3200 MFP paper jam remove & reload
There is a sensor in the upper portion of the paper feeder, its above the paper in the tray, it falls out of the mounting.
Easiest way to get to it is take your print cartridge out and lay the machine on its side, it is under the metal plate. I am sure it has come out of its mounting slots.
Dec 29, 2009 | Xerox Phaser 3200MFP/N Laser Printer
Area where final copies come out of machine making
Sounds like the output clutch. Take the top off the fuser area and clean the clutch.
Dec 04, 2009 | Xerox WorkCentre 432 ST Copier
Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Nov 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Xerox Phaser 8500 Add Magenta Ink will not go out even though all inks are full. Will not operate at all. Xerox wants $325.00 for first half hour of maintenance. Can't afford it. Have downloaded 8500...
it sounds like a sensor has failed in the ink cradle, to have a look you want to undo the two screws as the back on both sides then with the output flap & front cover open, you can gentley pull the plastic arround the display off, this will allow you to remove both the sides, the the ink cradle and melting units will jest lift out from the top, (make sure the printer is cold at this stage!!!!!!!!) then there are a few screws to remove then the unit will be in bits where you can test the bottom 'ink out sensor' & replace is needed.
Oct 23, 2009 | Xerox Phaser 8500/DN Printer
Powering Up My Xerox Phaser 8200DP
I assume no codes are coming up after leaving it on for a long time.
Most likely problem is the electronics module.
With the price of it you could buy 2 new dry ink phaser printers.
But what you are describing sounds like an electronics module issue.
May 27, 2009 | Xerox Phaser 8200DP Thermal Printer
Problems with my MODI XEROX 5216
It can not copy. When I power on after 30 seconds the copier show U4 in the screen and do not work.
Mar 13, 2009 | Xerox Office Equipment & Supplies
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Canon imageRUNNER 2520 Laser Multifunction Printer Logo
54 people viewed this question
old marine
old marine
