Beocenter 7007 goes off - Audio Players & Recorders
3 Suggested Answers
  • 6771 Answers
SOURCE: beocenter 7007 lights but no power
It is likely the audio output ic has failed, check the speaker wires for shorts, if okay! you will need a professional to take care of this.
Posted on Mar 22, 2012
junglebeat
Hi evreybody!
Is there anyone who can point me where to get any Bang & Olufsen tutorial for Beocenter 7007? I need to know how to open main case for replacing some components
Thanks in advance!
Posted on Nov 28, 2014
How do i remove platter on Beocenter 7007
From the Beocenter 7007 manual:
"If you ever want to remove the platter, lift the record spindle and then insert your fingers under the rim of the platter."
Sep 19, 2014 | Audio Players & Recorders
Beocenter 7007 lights but no power
Mar 21, 2012 | Bang and Olufsen Beocenter 9300 Shelf...
Can i get a wiring diagram for model 7007-00 i dont know what all these terminals do thanks jason
Wiring diagrams
http://waterheatertimer.org/images/4PST.jpg
http://waterheatertimer.org/images/4PST-example.jpg
Paragon 7007-00 timer has 120Volt clock motor, and 4 switching relays.
All 4 switching relays are NO and turn on-off at same time.
Connect 120V Hot and Neutral to terminals A and B.
Terminals 1 thru 8 are dry, and receive no power when 120V is applied to A and B.
There are two terminals for each relay.
Terminal 1 is for Hot wire and terminal 2 goes to load.
Terminal 3 is for Hot wire and terminal 4 goes to load.
Terminal 5 is for Hot wire and terminal 6 goes to load.
Terminal 7 is for Hot wire and terminal 8 goes to load.
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
Aug 15, 2011 | Paragon 7007-00 Electromechanical Indoor 7...
I have the 7007- 00 > 24 hr 7 day timer, but only have 1-off and 1-on timing wheel tripping set screw . I need 6 more of each type (on/off for each day) I'm using the timer to operate a 1 hp pool...
Paragon 7007-00 120Volt 7-day timer with 4-NO terminals uses X4299 tripper.
Paragon is no longer making timers and parts, except for defrost timers. 7000 series is not defrost timer.
Patriot supply shows the X4299 tripper for $15 per pair July 2011.
Open following link to identify timer:
Intermatic cross-over timer is T7401B
Jul 14, 2011 | Paragon 7007-00 Electromechanical Indoor 7...
Radio only owkrs with amp hooked up
Amp ic is out or there is an open signal ground in the receiver.
Mar 28, 2010 | Kenwood KDC-7007
B&O 7007 beocenter. need belts for tape deck,
belts are long since discontinued.cartridges are expensive look for mmc20s mmc20e mmc20en
Nov 23, 2008 | Audio Players & Recorders
Trying to change speakers from B & O to BOSE
All you need to do is to measure or look up the impedance of the speakers on the Beocenter 9000. Most speakers are either 4 or 8 ohms. Now measure or look up the impedance ot the Bose speakers. If the Bose speakers are the same or a lower number than the Beocenters, you are good to go. But, if the Beocenters speakers are a lower number than the Bose, then you should not switch speakers.
Nov 20, 2008 | Audio Players & Recorders
Hey, got a problem with a Kenwood KDC-7007..
Tray this:
In the code request mode,press and hold CLOCK and VOL UP key for aprox 3 seconds to enter the code cancellation mode.
You will noticed on the display after CODE the lines will disapear.
You need to enter "KCAR" from the remote control as follow:
1)press 5 twice K
press>>
2)press 2 twice C
press>>
3)press 2 once A
pres >>
4)press 7 twice R
pres>>
display may show APROVED and is ready to play
Any questions, my email is electroxpress@peoplepc.com
Nov 27, 2007 | Kenwood KDC-7007
24 people viewed this question
 Grubhead
Grubhead
