Question about Canon NP 6050 Copier
List of error codes in canon np 6050
Sir, I want list of error codes of canon NP 6050 copier.
saderach
SOURCE: NP 6050 Languge
how to fixed canon np 6050 copier because i dont have manual book
Posted on May 10, 2008
  • 134 Answers
SOURCE: Canon NP 6050 copier Error
E020 is a toner hopper motor error. This means that not enough toner is being sent to the developer box. It usually is a hard error, meaning that the part has to be changed.
Posted on Jun 30, 2008
  • 67 Answers
SOURCE: replace canon np6050 toner
Shake your toner jug well, on the the top right side of the copier is where the toner empties into a toner hopper. The cover lifts from the right and pivots open to the left. The cap on the toner jug is square the one side has 2 points on each end that stick out, that side angles in toward the left until it seats flat, then on the right under the toner is a door that slides out to the right, then there is a second door on the toner jug that pulls out to the right also. Just lightly tap on the sides of the jug until it empties. then push the door on the jug back to the left then do the same with the door on the toner hopper you may hsve to press very hard to get the jug to release.
Good luck and let me know.
Bob
Posted on Apr 27, 2009
SOURCE: i have an error in my machine canon np 6050 error
"E004" Abnormal fuser temp. (fixing heater, dc controller, ac driver)
http://rapidshare.com/files/161024133/NP6050sm.rar
That link above is for a service manual. Copy/Paste that address to address bar..
Posted on Apr 23, 2010
SOURCE: problem with my copier Canon np 4050 Error code: 540
my xerox mashine is create problem Eror
E203 ?
pls
Posted on Oct 07, 2010
Code erorr photo copy canon np 6050
What is the error code the copier is displaying on the control panel???
Nov 08, 2011 | Canon NP 6050 Copier
Canon np 6050 E013 problem
This is an error code for the waste toner assembly. Most likely the toner auger has jammed and will now have to be replaced. This should be tackeled by a qualified tech. Several assemblies will have to be removed and the auger system be replaced or repaired. Best of luck.
Sep 26, 2011 | Canon NP 6050 Copier
CANON NP 6050 ERROR CODE I55 PLEASE HELP MY PROBLEM NOW
check the lens motor maybe the gear of lens motor is broken
Dec 05, 2010 | Canon NP 6050 Copier
I have an error in my machine canon np 6050 error
Apr 23, 2010 | Canon NP 6050 Copier
When i turn on my canon np 6050, it turn off in 4 seconde
try to turn it on again and you will see a error code display
Feb 02, 2010 | Canon NP 6050 Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 error code is a main motor lock .
Check for jammed paper in the Fixing unit.
Pull transport/Fixing Unit tray out and rotate large knob on left side to check Fixing unit for obstruction/turnability. Other than this, it could be main motor failure.....
Jun 08, 2009 | Canon NP 6050 Copier
CANON NP 6220 ERROR "E000"
replace the fuser lamp or the thermofuse.
E000 fuser problem.
Dec 12, 2008 | Canon NP 6050 Copier
Canon NP 6050
Did you try a different out let? Also, when it turn "ON" & "OFF" did you see a Error code on the display sceen on the control pannel...? It could be a few different problems. We need a little more info on the error code it displays....
Nov 19, 2008 | Canon NP 6050 Copier
NP 6050 Languge
May 03, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
21 people viewed this question
old marine
old marine
