Question about HP LaserJet M5035 MFP Printer
Hp 5035 cleaning glass scanner inside
Dust inside
SOURCE: Haze on INSIDE of HP 2610 AIO scanner glass - how to remove glass?
with the 2610, on the right side remove gently the coverplate and then slide the under panel down. There are four places it attaches to the printer case one at each corner approximately. you can try to do what I did and use a greenie flathead screwdriver to pry it free, or do the not so obvious but much easier and kinder to the machine version of pushing it down to get the L shaped plastic pieces to release from the upside down L underneath. then there are three size T10 hex or star shaped screwdriver screws to release three of the four sides. I never could get the front silver fitted piece off, but was able to remove the glass. DO NOT CLEAN WITH WINDEX...IT LEAVES RESIDUE. USE VINEGAR. ALSO, USE WHITE GLOVES AS any dust you get on it cleaning it will leave small fibers on both sides. I used a special glass cleaning rag and then gently replaced it. note which side the black strip goes when you remove the glass!
Posted on Jan 03, 2008
SOURCE: How do you clean the INSIDE of the scanner GLASS???
Here is the step-by-step for taking the glass out of the printer. I think I will take mine to a shop to have it done!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553775&lc=en&cc=us&dlc=en&product=421999
Posted on Jan 10, 2008
  • 93 Answers
SOURCE: Cleaning the Flatbed Glass
We cannot clean inside the flatbed scanner glass, it is not a removable part.
Posted on Jun 06, 2008
  • 14 Answers
SOURCE: clean inside of printer glass
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu01831&cc=ca&lc=en&dlc=en&product=79499
NOTE: The underneath side of the scanner glass cannot be cleaned on any product. This is unlikely to be necessary and should only be done by an authorized service provider.
This note is found on that website. For an authorized service provider near you: http://hp.infonow.net/bin/findNow?CLIENT_ID=HP_LOC_CAN_SRV (in Canada)
http://hp.infonow.net/bin/findNow?ONE=1&CLIENT_ID=HP_LOC_USA_SRV&PAGE=Search.html&LANGUAGE=USA_ENGLISH
(in USA)
Posted on Jun 13, 2008
SOURCE: how can I clean the inside of the glass? It has a
Official solution for inside and out ;
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00553775&tmp_track_link=ot_faqs/top_issues/en_us/c00553775/loc:10&lc=en&dlc=en&cc=us&product=303753
Posted on Jul 25, 2009
WHAT IS LASER WHAT IS SCANNER INSIDE HP LASERJET 5035
The scanner is a small mirror that rotates at high speed, allowing the laser beam to scan, hence the laser whining.
Feb 12, 2015 | HP Office Equipment & Supplies
Tip
How to Clean Scanner Glass
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
When I try to copy a letter or anything, a black line shows up down the center of the printed copy. How do I remove this?
look at the scanner glass. It probably has some dust specs on it, clean it . Also clean the small glass toward the left of the scanner glass. If the dust specs are under the small glass, you can carefully remove the glass and clean it.
Jun 28, 2011 | HP Photosmart Premium C309A All-In-One...
White spots on scanned images
First thing you should do is to check whether the original image is clean and no dust or anything.
The next one is to clean the scanner glass. Use a clean cloth to wipe the scanner glass to make sure there is no dust or anything that might reflect the light from the scanner that can cause white spots.
Please give us update regarding this issue.
Thank you,
Jack
Feb 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Jul 03, 2009 | Epson Perfection 3490 PHOTO Flatbed...
Dust inside my HP All-in One show up on scanned pictures
Get a can of compresed air, open up you machine and blow it out. Also don't froget to clean your scanner glass.
Oct 29, 2008 | HP PSC 1610v All-in-One Printer
Streaks on prints
Lines/streaks at the same location indicate either a speck of dust stuck on the glass or the glass may be scratched.
S. Mohan
Aug 19, 2008 | HP Photosmart s20 Film Scanner
Jun 06, 2008 | HP Photosmart C6100 All-In-One Printer
HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Apr 16, 2008 | HP LaserJet 2840 All-In-One Printer
Glass Dirty on the Inside
unless the warranty of your scanner has expired, you have to disassemble your scanner and clean the dust inside.
Sep 01, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
HP LaserJet M5035 MFP Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
