Question about Pentair Jet - Vac Pressure Side Inground Automatic Pool Cleaner - White - Jv105
Jet vac will not move around the pool - Pentair Jet - Vac Pressure Side Inground Automatic Pool Cleaner - White - Jv105
  • Pentair Master
  • 1,631 Answers
Does pump work?
if not, then it's a pump problem.
If yes, then possibly plugged with debris either in the booster pump impeller or at the finger screen?
It's located at the wall adaptor.
Or... The internal gear assembly is the problem?
Sometimes the get stuck, broken tooth on an individual gear, or foreign debris clogging it.
Posted on Apr 05, 2015
2 Suggested Answers
  • 46 Answers
SOURCE: Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
Posted on May 26, 2009
Pool vac keeps getting stuck in a corner and wont move the rest of the day
Pool vacs sometimes do that. I changed my pump to the next bigger pump because once you hook that vac to it, it reduces the flow rate. the lesser flow rate doesn't seem to be enough to move the vac around and gets stuck easily. Also when the vac starts getting full it reduces the flow rate and will get stuck. Good luck.
Mar 14, 2018 | Pool Vac Pool & Spa
WHEN JET VAC HAS FINISHED CLEANING AND STOP THE LEAVES ETC FALL OUT OFF THE BOTTOM
The bag is supported by the jet of water shooting into it. When the pump stops, the jet stops and the bag should fall over sideways, retaining the leaves. I'm curious, Letro was bought out by Pentair 10+ years ago and the Jet Vac was discontinued. Also the description says that this cleaner runs without a booster pump. Every Jet Vac I have ever met runs with a booster pump. Are you sure the installation is correct?
Nov 14, 2014 | RTO Letro Jet Vac Automatic Pool Cleaner...
Jet vac doesnt move despite pump working fine
Check wall adaptor, there is a filter/screen inside.
Probably plugged with debris!
Mar 30, 2014 | Pentair Letro Jet Vac Pool Cleaner Tire...
Pool cleaner will vaccuum but no movement in pool. plenty of water pressure going thru back hose
Before doing anything, take the Jet Vac out of the pool and set it on the deck. Stand clear and turn it on. It should have enough water going through the blue jet to spray several feet and propel the jet vac on dry land.
What propels the Jet Vac is not the water going through the hose, but the water going through the little blue Jet under the Hose. You can unscrew this from the bottom of the shell and clean out any obstructions. Also, check the screen at the connection where the hose meets the wall. It is located in the white valve with the red button on it right at the pool wall. It will unscrew from the wall of the pool with the system off. Also make sure the booster pump is coming on.
Also, it may be stuck in reverse or neutral. If this is the case there will be jets of water shooting forward of the jet vac when it is on dry land.
Apr 15, 2011 | Pentair Jet Vac Venturi Shell Blue Jv2c
May 26, 2009 | Pentair Jet - Vac Pressure Side Inground...
Jandy pool cleaner will not move around pool
First, check your finger screen and energy filter. If they are dirty on these automatic pool cleaners, this can cause the unit to not move. Clean them if necessary. Next, check to make sure that the backup hydro-timer is not releasing most of the water out of the discharge hole. If it is, the unit will not move properly and you will need to replace the defective jet gear assembly. Finally, check to make sure that the transporter jet is not plugged up and that the debris chambe is not full.
Apr 19, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
Pentair Jet - Vac Pressure Side Inground Automatic Pool Cleaner - White - Jv105 Logo
259 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
