Question about Samsung HD502HJ Hard Drives Sata-ii 500gb-7200rpm
How to repair samsung HD502HJ bad sector
Windows show hard disk problem. how to solve it? i check this bt Hdd Regenerator it shows bad sector.
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 130 Answers
No way. Try to make it shorter and cut off that area including bad sectors. Make a two partition around and enjoy!
Posted on Apr 12, 2014
4 Suggested Answers
  • 207 Answers
SOURCE: removing bad secter from hdd
there are vaious ways
if u know how to make it slave hdd make it one by one on any desktop and run a disk defrag and scan along wd the consistancy check it is a time consuming process
ill suggest to format them it will take 20 min/hdd
Posted on May 19, 2008
Crankstart
  • 696 Answers
SOURCE: remove the bad sector from samsung sp0411n
Although A format could help it sounds more like you have some bad sectors on the harddrive.
Right click on the drive, select properties, then select the tools menu and initiate a disk check. it will give you an option screen before it proceeds, select the option to scan for a recover bad sectors/clusters. This will write off and mark the bad sectors so they will not be used again. If the problem comes back again soon then your palette media is failing and you should replace the drive.
Good luck and let us know how you make out,
Chris
Posted on Jun 04, 2009
bronk50
  • 27725 Answers
SOURCE: how to repair bad sector of hard disk in a laptop
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now, start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
hope it helps
Posted on Oct 17, 2012
Toshiba 1tb hdd external hard drive not reading
Try using HDD Regenerator to check and possibly to repair the disk. HDD Regenerator allows to repair bad sectors on damaged hard disk drives without losses of the existing data. http://ulozto.sk/xzjZ2Bd/hdd-regenerator-1-71-keygen-h33t-murtajiz-zip
Jan 11, 2013 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Tip
I have tested several programs, but the program below, just really worked for...
Let's try to explain the question that grinds us all when in cams about the hard disk. Can we actually repair a bad block? Before of the answer you must find some information about what is a hard disk, how does it work, what are bad blocks. After that you must identify them because you will need the exact location of the affected sectors. After you have done that you must run a few steps:
- before you try to resolve the problem with the bad sector you must extract the data that was written to that block. To do this you must run a Recovery program that you can find freeware on the net.
- bad sectors are unreadable parts on your hard disk but the nature of them must not be always physically and that part of the platens to be destroyed. The bad sectors can be simulated by some programs. This means that some programs installed on your computer can interrupt the reading process on to another segment of the platens. That is in the most happier cases but the chances that the bad sectors are cause by this is less then 10 percent. In this case is difficult to resolve the problem because even the Scandisk or other identification programs used to discover bad blocks will give a rapport that nothing is wrong with your hard disk. The best way is to uninstall the latest programs applied to the computer.
- lets supposed that you have a 20 gigabits partition on your hard disk that has bad blocks. After the identification program it will indicate you where are the blocks situated on the partition. So this way you can isolate them in to another partition that you must never use again. Another scenario can be created and the bad sectors can be at the beginning of the partition in the middle of it and at the end of the partition. Know it's a little bit tricky because you can't just go on and create three new partitions to eliminate the bad sectors from use. In this case most of the new hard disk has a spare space available just for this type of scenarios. You must access the CASH memory of the hard disk and indicates to the hard disk that instead of writing down on the effected blocks it must write to the spare blocks.
- another to restore the hard disk is to use the low level format option. Many of you think that low level format is a program. Wrong, the low level format option is set for any BIOS and can be easily use if you know some command line programming. The low level format can take to be complete a very long period of time but in the most cases we can obtain marvelous results. Actually the low level option takes every cluster of the hard disk and identifies them again (throw a thermal process) and writes down on the memory of the hard disk what sectors can be written and witch blocks are un-writable. This procedure is the best that can be because it will need no effort from your side to try and avoid the bad blocks that already exists and the hard disk itself know where the bad blocks are.
In conclusion the bad blocks can't be fixed. The problem is a permanent one and we can only try to use the hard disk until it is broken down for good. But if you are having financial problem this is a best way to keep going with your old hard disk.
on Mar 12, 2011 | Computers & Internet
I have a toshiba satelite pro L300 every time i start the laptop i get a message saying bootmgr is missing can this be easily solved
Use software HDD Regenerator Bootable CD. After you have a CD Bootable HDD Regenerator, insert the CD, then boot from the CD Room. Enter choice = 2 Scan, but do not repair (show bad sectors). For more information, you can see the video
Sep 23, 2011 | Toshiba Satellite Pro L300 Notebook
I need some help pleas my harddisc keeps blinkin whats wrong its not workin
There are several types of damage to your hard drive
1.
When the computer is turned on, audible sounds, from hard drive. See the video and
This means, your hard drive optical is damage (heavy damage on the hard drive)
2. Hard drive not detect.
When the computer is turned on, a message appears "Disk boot failure, insert system disk ...." - see the abdulkarimap.jpg
Solution :
Hard drive ATA
move the jumper from Master to Slave, or the other.
Move the serial cable, from ATA1 to ATA2. Or replace the serial cable
Hard drive SATA
Use a jumper, on the hard drive SATA
Move the SATA cable, from SATA1 to SATA2. Or replace the SATA cable
3. Hard drive bad sector. To fix hard drive bad sector,
use the software HDD Regenerator Bootable CD. Create, HDD Regenerator Bootable CD, restart the computer and boot from Cd Room. To repair hard drive bad sector, see the video .
Sep 23, 2011 | Computers & Internet
My hd suddenly does work. In BIOS all settings are good. I scaned my harddisk with HDD Regenerator it shows many many sectors breaked. now what to do..........?
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then defragment your hard drive
hope this helps
May 14, 2011 | Seagate Barracuda 7200.7 160 GB Hard Drive
WON'T LOAD ON WINDOWS 7
Many things can cause that... I'll tell you which things you may have done wrong --->
1.You turned it off while installing an update. Solution: Format it
2.A part of your hard-disk's boot has a bad sector. Solution: Download HDD Regenerator and check your disc for bad sectors (if there are bad sectors, you should back up your files and then buy a new hard disk)
3.There's a problem with your Windows 7 booting files. Solution: Recover Windows 7 from their CD
4.Your PC is affected by a rootkit (a type of malware that loads before Windows). Solution: Format it
Hope this helps :)
Dec 28, 2010 | Ellis Enterprises Maxima Bible Library 6.0...
How to remove bad sector in HDD ???
If you are a professional you can use two programs or softwares to remove bad sector from any hardware.
1. Hard Disk Regenerator
2. Spin Write
100% guaranteed it will work to repair them or some time remove bad sectors from hard disk and your hard will work so better and fast like a new hard disk.
Good Luck
Dec 16, 2009 | LaCie (300770) 250 GB Hard Drive
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Invalid media
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 22, 2007 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Again reloading(restarts)
Sep 21, 2007 | Microsoft Windows XP Professional With...
Samsung HD502HJ Hard Drives Sata-ii 500gb-7200rpm Logo
301 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
