Question about LG Washing Machines
Leaks from an over flow at the rear of the drum then sprays everywhere when being used
Lg wtr107 3 years old just out of warranty all hoses and pumps are good well it is 3 years old but at the rear of the drum there looks like an overflow pipe intergrated into it and it seems that the leak is coming from there lg wont give a technician to talk to without paying a 140.00 service call just wondering if any one knows anything about this issue
    Prodigy:
    An expert who has answered 500 questions.
  • LG Expert
  • 517 Answers
Have you cleaned the filter
Posted on Feb 11, 2014
  • 26 Answers
SOURCE: beko wmb1ow leaking cant see where from
Have a look at the hose that runs from the dispenser to the tub front.
They can leak when they rub against the shell.
Hope that helps
Posted on Nov 26, 2008
futureloginn
  • 734 Answers
SOURCE: washing machine leaks when not in use
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
futureloginn
  • 734 Answers
SOURCE: Maytag Atlantis Top Load MAV6250AWW Drum Leak?
During fill only
All the time
During fill only
All the time
SOURCE: Haier XQB55-10 : water leakage from inlet hose jointer
Inside the connector is a flat washer and a mesh filter. one side of the mesh filter has a strip/bar across it, this filter goes into the base of the connector with the strip/bar upwards, make sure it is seated in the connector properly.
Then fit the flat washer ensuring that it is clean/undamaged and lying flat at the base of the connector, the mesh filter strip/bar has at either end a small lip, the washer goes underneath the two lips, if it is placed on top of these lips it leaks!
99% positive on this, if not buy another hose!
Posted on Mar 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Posted on Mar 24, 2009
1998f1504.6wtriton runs fine but getting codes 401,171and174check all vacum lines,dpfe sensor,sprayed carb cleaner everywhere,new egr ,egr tube,took off elbow and throttle body cleaned it up no blockage...
Some of these intakes have a channel under the throttle body that supplies flow to the EGR. The channel is below the mounting plate for the air horn. Also clear the computer of old Codes.
Code 171 and 174 mean lean condition. It means more air is getting into fuel mix than is metered through air intake. Try using water spray bottle on all seams and Vacuum lines while engine runs and opening will draw in water and affect RPM.
Use water spray on Brake booster while engine runs. Bad diaphragm will leak Vacuum.
Finally, rear metal tube to DPFE has 2 short Vacuum lines which DPFE fits on. The metal tube goes to Exhaust. Some have a metal ridge on this tube. The ridge can leak Exhaust flow and affect the DPFE readings. Sometimes rust can build in this tube and it may need to be cleaned to restore flow.
Sep 28, 2013 | 1998 Ford Explorer
Leaking radiator fluid under hood, sprays everywhere i belive from hose, not actually coming from radiator. What its doing is causing the engine to over heat burning oil eventually leading the car to
You have three hoses on top, one from rad to engine, and 2 for the heater. You have one hose on the bottom rad to the engine. Given the car is 10+ years old, I would replace all of them.
Aug 13, 2012 | 2002 Ford ZX2
There is a light mist of water spraying up around the serpentine belt and the power steering. Car was overheating with not heater working. Now not overheating (after radator leak stop) but spraying water...
still leaking.. it sound like a hose has a hole in it. i dont think stop leak will fix it. look for where it is coming from and replace it. if it is spraying near the serpentine belt it is probaly the water pump. or a hose connecting to it.
Nov 05, 2010 | 2002 Oldsmobile Intrigue
Blue hose on back of referigator cracked and leaking when pumps
try to buy 2 couplers and length of hose if remainder of hose looks good
Oct 22, 2009 | LG LSC26905TT Side by Side Refrigerator
Water Everywhere
Look for loose, cracked, pinched, broken hoses to and from the water pump or leaks from the water pump itself. The outer drum could have a rust-through that leaks. This can be repaired with epoxy, but the inner drum must be removed to access it. The cabinet top is opened by using a putty knife or similar tool to push straight back under each front corner which releases a spring latch. Sometimes, the drain hose outlet is pushed from the house drain by high water flow. Tie the hose to the drain with tape or cord. Fill the tub with water, then stop the cycle and watch for leaks.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
Upper rack sprayers not working on LG ldf7811 dish washer
Check the pump out. Even though the Hose is and tubes are clear it does not necessarily mean that the pump is not pumping water to the top sprayer. One way you can do this is take off the upper spray tube and lay it in a glass or bowl and turn on your machine for a minute or so to get the water flowing if it flows then I would take off the spray assembly itself and make sure that there is no blockage on the bearing race
Apr 08, 2009 | LG 24 in. LDF 7811 Built-in Dishwasher
Washer Leaks from Detergent Compartment
Two things might be wrong with this unit.  One problem is there is a blockage inside the hose that sends water into drum.  Make sure that's clear.  The other problem is the dispenser assembly may have a leaking problem and will spray water at an angle that will cause it to leak through the dispenser drawer.  My recommendation is to have the dispenser assembly inspected and possibly replaced.
Apr 24, 2008 | LG WM-2277HW Front Load Washer
LG REfrigerator - water line connector
Try closing the water valve slightly to reduce the water pressure to the unit.
Sgt 48
Jul 31, 2007 | LG LRSC26980 Refrigerator
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
Washing Machines Logo
27 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
