Question about Chikka Txt Messenger
Cannot install the latest version of chika messenger
I uninstall the old version then i install the latest version but still cant find the right software
Ym stops as soon as I dial the number. Message says : ym has stopped working and will close. 8.1.0.421, windows 7
you are using old version of yahoo messenger..
you need to uninstall the version from add and remove program and install latest version 10
you can download the latest version from http://messenger.yahoo.com
Apr 16, 2011 | Yahoo Messenger
I cant see text when chatting on yahoo messenger, please help me to fix this problem
Go to start button, control panel, Programs-uninstall programs. Click Yahoo Messenger. Click uninstall. Then go to http://messenger.yahoo.com/download/ and re-instal the latest version following all instructions. If it still does not work after that, you may need to install some updates for flash players, but the Messenger instal will tell you that this is the case, and will direct you to where you can get those updates/programs.
Mar 29, 2011 | Yahoo Messenger
In yahoo messenger i cant able to see what im typing and i cant to see the receive message from anther people
Having the most recent Java application will ensure proper communication between Internet Explorer and the Messenger application. Please follow these steps to uninstall and reinstall your Java runtime environment. Uninstall and Reinstall Java
1.On your keyboard, hold down the Windows key and press the R key. This opens the "Run" command. 2.Type in appwiz.cpl and click OK. This opens "Add or Remove Programs." 3.Select Java and then click the Uninstall button. There may be multiple installed versions, so be sure to remove all of them. 4.Next, download and install the latest version of Java Runtime Environment 5.To ensure the update is effective please Clear the Yahoo! Messenger Cache 6.Restart Messenger to determine if the issue is resolved.
If the issue persists, try Resetting the Browser Configuration.
Mar 07, 2011 | Yahoo Messenger
How i get call option in yahoo mesenger
If I am right, your yahoo messenger has not that feature. I would suggest you to simple download the U.s. version and install it after uninstalling the currently installed.
You can download the latest u.s. version from this link, works for any country.
Yahoo messenger 10.0, u.s. version
(Note: Don't forget to uninstall it before you reinstall the new version)
Good luck.
Thanks for using FixYa
Jun 23, 2010 | Yahoo Messenger
I want to remove a old Messenger and reinstall a new one. When I click on remove or fix it displays a message that says could not open INSTALL.LOG file?
If you are in windows OS then press CTRL + ALT + DEL and click on process and then locate all yahoo process and then right click and click END PROCESS and also go to THIS LINK and click on download and then install it.
IF THIS IS ABOUT WINDOWS MESSENGER THEN
  • Problem: Windows Live Messenger Won't Start / Load / Launch / Open
    Solution:
    I have this problem for a few weeks. Tried everything suggested by everyone who managed to fix their problems. None worked. I tried uninstall and reinstall but to no avail. Somehow if you upgrade it to the latest version, the problem solved.
    I was desperate so I decided to go with an older version. Somehow my problem was solved. I can't guarantee it would work for you though.
    1. Uninstall everything related to WLM from Control Panel
    2. Download an old version from one of these sites (if you are the super-paranoid type and concern virus, try downloading it from Microsoft if it is still available):
    MSN Messenger 8.5.1235 (19.4 MB) from http://www.oldversion.com/program.php?n=msnm
    Other sites where you can find old versions of software
    http://www.filehippo.com/download_msn_messenger/
    http://www.oldapps.com/msn_messenger.htm
    3. Install the old version, but it won't work as Microsoft would insist you upgrade to the latest version.
    4. Go with it. When the installation is done, WLM is back to normal.
    5. I must add that my original problematic WLM was the traditional Chinese version, and when I upgraded/reinstalled I chose the standard English version. My windows is an XP SP2 Traditonal Chinese version.
    So good luck to you all and hope that your end of frustration is in sight!
  • or use this solution 1. Kill all "msnmsgr.exe" process.
    2. Run regedit (be carefull) and go to:
    HKEY_CURRENT_USER\Software\Microsoft\MSNMessenger
    3. Select all the values on the RIGHT SIDE of this window.
    ie: (Default) REG_SZ (value not set)
    AppCompatCanary REG_SZ 8.5.....
    AppSettings REG_BINARY 6202..
    4. Delete only that selection and close regedit.
    5. Run "Windows Live Messenger", enjoy!
May 17, 2010 | Microsoft Windows XP Home Edition
I cant install the YMessenger after uninstalling it...
Greetings.
I had the same problem, I think the new version is buggy. What i did was download the old version of yahoo, version 8+ then install it and now it works.
If you need further help pls. let me know.
Jan 06, 2009 | Yahoo Messenger
Cant get yahoo messenger to open
uninstall yahoo messenger and download and install the latest
make sure you have the latest version of drivers on your computer using the win update.
Oct 23, 2008 | Yahoo Messenger
"Could not open INSTALL.LOG file"
u can simply install old version again and uninstall it or u can try directly to install new version it will work dude.
Ahmad rabbani
Aug 21, 2008 | Microsoft Computers & Internet
Computers & Internet Logo
15 people viewed this question
Top Chikka Computers & Internet Experts
David Payne
David Payne
Are you a Chikka Computer and Internet Expert? Answer questions, earn points and help others
