Question about Sony DCR-DVD708E DVD Camcorder
Dismandeling open for service
WT960 hotpoit washing machine shows F10 and stops
* F01 - Short circuit motor traic - Book a service engineer.
* F02 - Motor jammed or fan blocked - Book a service engineer.
* F03 - Front thermistor open/short circuit - Book a service engineer.
* F04 - No pump piloting - Book a service engineer.
* F05 - No feedback from the pump - Book a service engineer.
* F08 - Static heater relay with contact welded closed - Book a service engineer.
* F09 - Eeprom is not programmed or not functioning - Book a service engineer.
* F10 - Common of heater open or one shot open - Book a service engineer.
* F11 - No pump connection - Book a service engineer.
* F12 - Communication error between boards - Book a service engineer.
* F13 - Rear thermistor open/short circuit - Book a service engineer.
* F15 - Dynamic heater relay with contact welded closed - Book a service engineer.
* F-17 - Master relay welded closed - Book a service engineer.
Apr 06, 2015 | Washing Machines
I have received from http:mms.live.vodafone.in my msg key is msg.77.9156 how can i open on my net..?
To Open or to send MMS , your Phone should support MMS function and if your mobile set support it then your service provider should enable MMS service for you. If your MMS service is not enable then you can contact VODAFONE customer care and ask them for enabling MMS service for your mobile phone. if Your MMS service will activate then you can open it just by clicking Open or Read option.
Jul 28, 2012 | Cell Phones
This is locked up on opening page, i have tried all the suggested solutions, i.e. press reset for 15 seconds, them on /off 3 times !!,, I have now removed the back and disconected the battery, but the...
HELLO JOHN
ITS GOOD YOU HAVE A E-READER SONY IS A GOOD BRAND AND THE PROBLEM WHICH TYOU ARE FACING IS A NEW ONE.
BUT ONCE YOU REMOVE THE BATTERY THE DISPLAY MUST TURN OFF BUT IN YOUR CASE ITS REVERSE SO JUSTY TRY DISMANDELING THE READER COMPLETLY AND THEN INIDE THERE WILL BE AOCKET FOR THE DISPLAY REMOVE THE SOCKET AND REPLUG IT AGAIN. AND SCREW THE READER AGAIN. THIS WILL WORK UP
THANK YOU
Mar 22, 2011 | Sony Reader Touch PRS-600
I was surfing on net by connectting my samsung c3510 to my pc,and at the same time i want to open gmail java application on same device (samsung c3510).at the movement of opening java application my...
hi just remove the cable connecting to your computer and dismandel the mobile just remove your mobile battery and again replace it as it was and then switch it on the mobile will work as normal
Feb 26, 2011 | Cell Phones
My mobile is samsung cdma mpower sch f-699 not open wap in tata
my mobile is samsung cdma mpower sch f-699 not open wap services and i am custmur tata indicom.
it say please upgrade the R-UIM in order to obtain data services.
Feb 16, 2010 | Samsung Cell Phones
How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Dec 21, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
A05 code
Indesit Error Messages and Error Codes Indesit Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level. Book a service engineer.
  • F20 - Temperature under range. Book a service engineer. .
  • F21 - Temperature over range. Book a service engineer.
Fault codes for Indesit LCD Dishwasher Models
  • A01 - Float switch operated - Book a service engineer.
  • A02 - Open/Short circuit heater relay - Book a service engineer.
  • A03 - Short circuit on thermistor - Book a service engineer.
  • A04 - Unable to reach or sense temperature within 70 minutes - Book service engineer.
  • A05 - Pressure switch has not been reset - Book a service engineer.
  • A07 - Open/Short circuit wash motor triac - Book a service engineer.
  • A08 - Open/Short circuit auxiliary wash motor triac - Book a service engineer.
  • A09 - Open/Short circuit with main wash traic - Book a service engineer.
  • A10 - Open/Short circuit fill valve traic - Book a service engineer.
  • A11 - Half load valve traic or alternating motor action - Book a service engineer.
  • A12 - Open circuit heater rely - Book a service engineer.
  • A13 - Open/Short circuit dispenser traic - Book a service engineer.
  • A14 - Drain hose too low causing syphoning. Check drain hose and re-adjust.
  • H20 - Check tap and pressure of incoming water.
_uacct = "UA-1207243-4";urchinTracker();
Sep 14, 2008 | Indesit 24 in. DE73 Evolution...
How i open my vx900 lcd monitor
sir
give full detils about your Product and copany plz after then i give ans Mail : uday_uday2004@rediffmail.com
Apr 02, 2008 | Samsung SyncMaster 152 B 15" LCD Monitor
Hotpoint FDW80( A10 Appears ondisplay half way through cycle)
here are the fault codes for your machine...
Fault codes for LCD Dishwasher Models
  • Hope this helps?
    Jan 06, 2008 | Hotpoint 24 in. FDW60 Free-standing...
    Sony DCR-DVD708E DVD Camcorder Logo
    16 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
