Question about Canon PTCH DECDR 6050/7550/9550-INST REQ 4009B002
What to do when drum heater does not work
Sir, in my copier drum heater is not working. In this case what should I do to main the proper function of the copierl.
    Habit-Forming:
  • 54 Answers
You need to replace the drum and power suply as well
Posted on Jul 02, 2014
Konica minolta 7272 error codes sc50-5 & 29-4 ....... what can I do......... any solution plz
Mam/Sir,
SC 50-5 is that main drive motor can not turn properly, the second code is that you drum sensor is not reading the drum, For both codes you will need a tech that has some legacy Konica experience might need a a new drum when was last time developer was installed? Might need a new motor or worse case a main control board. Both codes require removal of the drum/developer assembly. Sensor for the drum is under the drum and requires drum removal. Will also need a new cleaning blade which might be the reason the drum can not turn. Developer for the developer section. Try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 14, 2016 | Konica Minolta Office Equipment & Supplies
Xerox c2424 error codes
Drum disconnect. The drum heater is not drawing the expected
power from the supply.
AC power supplied by power sources such as uninterruptible power supplies (UPS's) or DC-to-AC inverter systems, may not supply enough current to properly power up the printer. In these cases, the printer may report printhead jet-stack or reservoir
heater disconnect, drum heater, or preheater errors (37,002.47 thru 37,012.48).If you do not hav a UPS connected then probably it is the drum heater problem
Aug 05, 2014 | Xerox C2424 Copier
Hooper Assy on off Code
sir/mam
Remove the drum assy. and have the the drum and developer replaced along with having the drum and developer assy. cleaned and the senors that are on the assy, then have the proper procedures run after the developer and drum are installed, ALSO have the counters reset to let the copier know that new developer and drum have been replaced
Apr 10, 2014 | Konica Minolta Office Equipment & Supplies
Error 04,018 48 xerox phaser 8860
The printhead temperature is too low.
Check the air temperature (the room should not be cold)
Test the heaters in Service Diagnostics Monitor. If the heaters function properly, then replace the Electronics Module...if they don't, then it could be a bad printhead, drum assembly, drum heater relay board, or drum temperature sensor.
Jan 29, 2014 | Xerox Phaser Office Equipment & Supplies
Sir, My Nokia 5200 phone's down key right key does not work sometimes, exept them all keys are working properly, plz sir give me a valuable solution that I can easily overcome from the said problem.
Most models slide to open this common problem. The main thing I suggest you change the new ribbon cable. is not about just the keypad will not work if the ribbon cable is damaged, but lcd display is not functioning properly if the ribbon cable is damaged. You are lucky to still be able to use it even can not move left or right, if not berfunggsi menu button, you can only power on mobile but can not use it.
Jul 27, 2010 | Nokia 5200 Cellular Phone
Drum won't turn on my ariston ab1030c. I think the motor is working as it produces heat on the drying function. Tom.
The heater is produced by the heater element. The motor is working if it turns the belt so the drum will turn. Sometimes the motor is still good, but the relay from the push button is bad. In this case the circuit never enables the motor to turn, hence the drum is not turning. Need a service man, or if you are good with the schematic, there is one inside the controller from the manufacturer if you take off the real panel. Good Luck.
Feb 16, 2010 | Maytag HYE3658AY Electric Dryer
SAVIN C36535 SC365 FUNCTIONAL PROBLEM WITH COPIER PLEASE HELP
Hello sir; SC 365 it means megenta TD senser defect or megenta PCU( drum unit).
Feb 05, 2010 | Office Equipment & Supplies
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Main logic board problem
Sir,
Our printer 1410 is not working properly last 2 months because the when printer cable connect the all printers buttions lights are working, but not functioning. my friend said to me our printers logic board are not functioning because the moustiure creat to our logic board, so give me suggestion to next.
Jul 15, 2009 | Zebra 110Xi III Plus Thermal Printer
Blank copy (IR400)
your developing rear gear turns the drum, check that.
Dec 14, 2008 | Canon imageRUNNER 400S Copier
Canon PTCH DECDR 6050/7550/9550-INST REQ 4009B002 Logo
35 people viewed this question
old marine
old marine
