Question about Altec Lansing VS2621 Speakers
Speakers take about 10 mins to start - Altec Lansing VS2621 Speakers
Lot of noise make
Seems it is getting bad when speaker heats up
Audio out ic may be partially defective
Cant say exactly the reason without checking
Need to check individual component
Try to investigate
thx
Oct 12, 2012 | Dell WL6000 Computer Speakers
My Yamaha rxv496 switches off after about 20 mins then switches on after about 10 mins.
sounds Like a power supply issue and u should always have speakers connected before u turn on maybe power supply is about done open case an check for any leakage on power supply unit or small cracks on it ...if so its pretty well done
Never good to power up without speakers connected can blow power outputs
Feb 07, 2012 | Yamaha RX-V496 Receiver
Samsung q45 audio cuts out after around 5-10 mins
First thing if you have the latest device driver for the audio please uninstall and reinstall that. Most of the time this troubleshooting works.
If you are using external speaker please try using another speaker.
Or if you are using a built in speaker then try using external speaker and if the issue persist it is a posible issue with the audio port on your laptop. If not then it is an issue with the built in speaker.
Mar 26, 2010 | Computers & Internet
Hello, my speakers hum for 10 to 30 seconds when i turn on my receiver. sometimes they do this even with sound coming from the system for up to 10 min. i tried changing the speakers. moving the power,...
i think ur unit deposits humidity . . try to clean it up with smooth paint brush over the boards and connectors . . better yet spray some contact cleaners i think this will do . . . otherwise resolder is needed . .
Feb 23, 2010 | Onkyo TX-SR304 Receiver
How do we set the clock on Sharp logicook R-7N76?
Press stop/clear pad to remove 88:88 from the display.
Press auto start once for 12 hour clock and twice for 24 hour clock.
Enter hours first using 10 minute and 1 minute pad (i.e. for 12:00 - press 10 min button once and 1 minute button twice)
Press auto start.
Enter minutes as before using 10 min pad and 1 minute pad (i.e. for 35 mins press 10 min button 3 times and 1 min button 5 times)
Press auto start.
Jan 22, 2010 | Sharp Office Equipment & Supplies
Sound problems
Speakers need to be replaced.
i need the brand to be more specific
May 25, 2009 | Televison & Video
Radio blue tooth drops out after 10 min. reset and same thing happens after 10 min
What kind of phone, headset or radio, etc are you using. If you send me more info I may be able to help you with your problem.
Jul 17, 2008 | JVC Car Audio & Video
Turns off 5-10 mins after turned on
One thing to check would be the speaker connections. If this receiver worked before you moved it and only started doing this after it was moved, that could be the source of the problem.
If the speakers are connected improperly it could cause it to go into protect mode after a few minutes.
Also check the speaker wires and make sure you don't have any frayed wire sticking out and touching the chassis of the reciever or shorting together.
The phase control symbol is something I would need to research, I have repaired several of these recievers and do not remember the phase control ever being a problem.
Logic would dictate that something is connected wrong, my first thought is the speakers, but it could be something else. I would go back over every single connection on the back of this unit and double and triple check them all. make sure the positive speaker connections are going to the positive speaker post and negative to negative.
It is also easy to connect the speakers to the wrong jacks on the reciever. You may be bridging a channel or two and that would cause the reciever to get hot very fast and shut down.
If none of this helps you may just have to take it in to a service center. I would reccomend an authorized Pioneer service center. They can at least call Pioneer tech support and talk to Mark, Bernie, or Mike at Pioneer. They are on top of all things Pioneer.
I will be happy to help you further if you need it.
Jun 18, 2008 | Pioneer VSX-D507S Receiver
Samson 65a monitor speaker
If its not to big find a neostick or similar sintetic glue,piece of medicine bandage and black (if speaker is black) mat spray.First put some glue around the rip wait for 10 min and then put the bandage on it.After that again 10 min of waiting and new layer of glue on the bandage.Let it 24 hours for glue to dry an then respray it.If you can do it from the back side its better and repair is almost invisible.
Feb 29, 2008 | Samson Resolv Sub88 Subwoofer
Altec Lansing VS2621 Speakers Logo
32 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
