Question about GPX Televison & Video
Avol DVD player's screen is not bright - GPX Televison & Video
Avol TV remote
See this links
http://shopping.rediff.com/shop/productdisplay.jsp?Universal-Remote-Control-for-all-TV,-DVD,-VCR,-VCD,-AC,-CD-Player&prrfnbr=10203960&source=browse&frompg=Accessories
Aug 07, 2008 | Televison & Video
I have the Insignia Dual 7" Portable DVD Player. Model NS-7DPDVD. I'm noticing a yellowish color on the movies. I adjusted the brightness wheels on both but it's not the brightness it's...
Bring up a menu on the DVD player screen (not a DVD menu, the dvd players settings menu). Is this menu also tinted yellow? It probably is, and you probably have a faulty part internally.
Jun 13, 2011 | Insignia Dual 7" 16:9 Widescreen LCD...
Hi, i have a portable dvd player & the battery is 2 hours. now it only lasts 30 minutes. is there something i csn do to boost it or do i need a new battery. thank you, medina
Your best bet is simply to replace it with a more reliable battery. However, starting the dvd player without a disc so that the settings appear should allow you to change the options on the DVD player. This should allow for the brightness and picture settings to be adjusted to preserve battery to the best of the DVD players ability.
Step One: Remove Disc
Step Two: Turn On DVD Player
Step Three: Enter Settings
Step Four: Adjust the picture and screen settings to maximize the battery life (make the screen less bright for an example)
There may be a setting specifically meant to maximize battery life. Hope This Helps.
May 13, 2011 | TruTech PVS12701 Portable DVD Player
I need a remote control for my avol dvd player
Click Here to buy universal dvd remote from Here.
Please let me know if you have any further questions or concerns
Thanks.
Jun 03, 2010 | Televison & Video
Avol tv
Just unplugged a few hours.
Feb 24, 2010 | Samsung 50 in. Flat Panel Plasma HDTV
Screen will not stay bright
That's the battery saver feature of that Philips portable. If you use an A/C power adapter, the light will stay bright.
Hope this helps!
Sep 10, 2009 | Televison & Video
Need Codes for remote!
My search for you would indicate that neither this remote nor a universal remote supports the AVol. Thier support site is here though..you might give them a call..
http://avl21c.com/renewal/surpport.htm
the company and issues were discussed previously here http://www.fixya.com/support/t449578-avol_tv_remote
Jun 19, 2009 | Televison & Video
Avol TV remote
I own an AVOL 19in TV, I just got my comcast cable hooked up; I too was plagued by initially having to use my other remote to turn TV/volume on/off up/down. Being the code is not listed in the Comcast universal remote instructions, in the above answers someone mentioned APEX as a parent company with AVOL; I was able to use a code from the APEX codes listed in the Comcast universal remote instructions to get the controller to work with turning the TV power on/off and volume control. The code that worked for my particular TV was 10765. Try these codes for your TV to see if they work- 10748, 10879, 10767, 10890. Hope this helps.
Mar 17, 2008 | Televison & Video
Eject problem,bright screen
I had the same problem. I suffest you don't manually pull it out if you haven't already because now I can't get disc to load. I say try up dvd and or cd pushing eject on the screen or use the remote, the button should work. As for bright screen go under the settings and lover brightness.
Aug 20, 2007 | Kenwood KVT-715DVD Car DVD Player
Televison & Video Logo
11 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
