Question about Refrigerators
My Tecnik TKR6610/2 fridge not cool even though on 5 but freezer is working fine
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: freezer working fine but fridge wont go cold!
Hi
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Posted on Mar 25, 2009
Freezer doesn't cool to 0 even though it's set at -5
There is a fan that blows air past the coils in the freezer. Either the fan is not working or the coils are blocked with ice. Sometime ice stops the fan from turning. listen for the fan spinning by turning the thermostat down. Defrost the coils and fan and see if the frig returns to normal. Sometimes the drain tube is clogged causing ice buildup.
Feb 13, 2014 | Whirlpool GB2SHKXL Bottom Freezer...
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
Both fridge and freezer are turned up to maximum cooling but they just aren't cold enough even though the weather is mild. Icecream is very soft - barely frozen and fridge temp is about 8 degrees...
Sounds like a failure to defrost.
Look on the freezer rear wall inside the freezer for ice bukdup.
If there is ice the defrost components ,must be replaced.
Dec 01, 2010 | Fisher and Paykel Active SmartĀ® E522BR...
My refrigerator is not getting cold even though I have changed the temperature setting to the highest value. The freezer is working fine.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 11, 2010 | GE GSH25JFR Side by Side Refrigerator
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
Hello, my fridge is not cooling well, but my freezer is working fine, can you identify the problem? There is no ice jam where the cool air comes from freezer to the fridge.
Can you see the coil in the freezer? It may be located behind a panel accessible from inside the freezer. Even though the air duct is clear if the self defrost is not thawing the coil daily it will turn into a block of ice and stop the air flow from the small fan. The other option would be the small fan motor stopped working. Either way its an easy fix in most cases and parts for either job should be under $50.
Sep 15, 2009 | Maytag Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
