Question about DIGITECH Music
Digitech gsp 21 legend error 666 - DIGITECH Music
How can I get instruction manual for digitech xc0430 weather guage ?
Hello!
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
https://manualsbrain.com/en/brands/digitech/popular_categories
Oct 20, 2017 | DIGITECH Music
Digitech mouse 5248 manual
Try Googling (Digitech)(5248)(manual) without parens.
Jun 25, 2017 | DIGITECH Music
Where can I download a digitech D G 4132 manual
ftp://ftp.digitech.com/pub/PDFs/Manuals/D G 4132
Apr 15, 2017 | DIGITECH Music
Im looking for a manual for a digitech gsp 2101 studio tube preamp processor the standard model not the artist model??
Find one here: http://www.manualslib.com/manual/380759/Digitech-Gsp2101.html
Mar 07, 2015 | Music
Digitech 256 manual
This manual is Not available, The 256xl is ? I think if you contact the company they can help you, I have contacted them in the past threw this link.... http://digitech.com/en-US/support
Feb 22, 2015 | DIGITECH Music
Digitech vl3d vocalist
For the best answer, contact DigitechSupport. Here is the link-
Jun 24, 2013 | Music
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a crate cpb150 amp i want to connect it to my digitech gsp2101 via livewire stp-202 cable what is the correct way?
I can understand your confusion... and a lot depends how you are going to use this. There are some caveats regarding the connections,
If you use the 1/4 outputs on the GSP, there is a speaker modeling like function that is NOT available, that IS available IF you use the XLR outputs.
The STP is an "Insert Snake" which is not really what you want as it is intended to send and receive (audio going both directions in the cable.
If you want that speaker function, then you should get two XLR to 1/4 TRS cables and go from the XLR's on the GSP to the Left and Right inputs on the back of the Crate. Your audio or guitar then is connected to the GSP guitar input.
If you connect the guitar to the crate and then use the STP, Plug the TRS single connector into the Left/Mono/send/rtn on the Crate. The Send cable of the Y should go to the Send jack on the back of the GSP and the return should go to the left return jack of the GSP. This connection I would NOT recommend as it will be noisier and you will lose the stereo effect capabiltiy since the effect is inserted as a mono.
I believe you would be happier with using the XLR's to carry left and right to the Crate and run your inout to the GSP. In short, you have the wrong cable to do the best job.
Jan 30, 2010 | Crate Music
Music Logo
18 people viewed this question
Top DIGITECH Music Experts
Michial Gueffroy
rhodesworks
Are you a DIGITECH Music Expert? Answer questions, earn points and help others
