Question about HP Officejet Pro L7380 Laser Printer
Print head Why wont the ink dry on photo quality prints-- HP gloss paper used
jdbouncer
  • 72 Answers
SOURCE: printing photos on hp psc 1215
Are u using the original HP ink ? The HP ink is formalated to dry fast. You might try using a different ink cartridges, but try a couple sheets of HP photo paper to see what happens.
Posted on Apr 21, 2008
SOURCE: photo does not dry
4 x 6 Kodak xtralife paper- Hp ink and the photo will never dry and is all blury.
Posted on Jul 20, 2008
  • 146 Answers
SOURCE: when I print on photo paper the ink doesn't dry
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Posted on Sep 26, 2009
  • 2841 Answers
SOURCE: the kodak gloss paper gets jammed in my hp
You have an HP printer. I highly recommend you use HP photo paper for the best results. This may not solve your jamming problem but it may. HP printers are very touchy as to what photo paper you use.
Posted on Nov 24, 2009
  • 199 Answers
SOURCE: HP 2600 does not print onto photo paper
change the paper type in the printer properties and try.
Posted on Jan 09, 2010
Correct settings for printing on semi-gloss paper. I keep getting smears when printing and photo doesn't come out clearly
Well, it would be good to know why the photos are not good quality... like blurry or bad color or? Are you using a good paper? I have great luck with Canon glossy, and love the matte paper from Staples. Matte is actually easier and all around better color saturation, I find. I guess that you are using too much saturation of ink... see if your dialog box for printer options has a way to make saturation less intense. Also, I assume you are using the same dialog box to choose the type of paper. That is important, since different papers absorb ink at different speeds and amounts. I hope that helps... keep trying!
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Hp photosmart 7760 the prints will not dry
hi
goto the cntrol panel--->printers and faxes--->right click the printer icon
click on the printing preferences and check the print quality ,try to set it to fast draft...this should save the ink as well as dry it faster.
hope this works
Jul 14, 2009 | Office Equipment & Supplies
Hi. my photo printing results is not so good on normal paper. plz tell me vat is the problem. i want to print photo in best resolution on ordinary paper.i.e (Double A paper)
Printing photos on ordinary paper do not come out well because the ink soaks into the paper like a blotter. I suggest you use semi-gloss or high gloss photo paper for best photo quality prints..
Feb 25, 2011 | Epson TM-T60 Printer
Poor printing quality
Dear friend,
Just few tipe.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
Thnks & waiting for your feedback.
Jan 30, 2010 | Canon Office Equipment & Supplies
Why does the printer use one black cartridge and not the other? Is there some way of instructing it to use the left hand one too?
the pixma printers use the large black tank in most modes like text and standard (default) or fast photo printing .. thats most economical when you are using just plain paper .... it will switch to the small black tank only if you select "High" quality mode .. that black matches the nature of the color inks much better and results in really good color pictures if you are using Gloss or Matt high quality photo paper .. you can select the quality level by the following ... when you start to print, a window comes up where you can select which printer you want ... at the right of this window is "preferences" .. click that .. now select the type of paper and "High" quality mode .... now the printer will slow down but will provide really nice results and it will use the small tank black ink instead of the large tank ....the small tank is only used for "high" quality photo prints which is only needed for high quality photo paper .. if you havent tried that yet you might want to get some glossy photo paper (either Canons or Costco has great stuff if you want a lot, like 150 sheets) but most glossy paper will work except colors might need tweeking for some ... print a nice photo in the high quality mode and you should be really impressed .. and you will be using your small black ink tank .. you might want to make the first few pictures small (2x3 inch) untill you are sure everything is the way you want it .. i usually print in the top left corner first .. then reinsert the same paper and try again right next to that .. i do that until i get the colors perfect .. then i print big .. 5x7 or even 8x10 on a new sheet... the high quality mode can be selected for just plain paper and it will use the special black ink but it doesnt result in a better picture .. so no point in doing that unless you want to experiment .. if you never print high quality photos then you will never use the small tank black ink .. it will still be used up eventually because of normal head cleaning the machine does automatically .. ...
grey scaling does not select the special ink unless you select "High" for the quality setting .. then yes you can print using that small tank black ..again it will buy you a lot if you are using High quality photo paper ... almost nothing for plain paper but at least it will allow you to use that ink .. ..
Dec 13, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
Sep 26, 2009 | HP Office Equipment & Supplies
Photos print wet and smudged
all the dx /cx range do this when printed on the high quality settings you just have to let ink dry about half hour or use a lower seting when you print on gloss paper hope this helps
Dec 07, 2008 | Epson CX8400 All-In-One InkJet Printer
Ink not dry when printing photographs
Download the proper drivers from hp.com - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
Nov 27, 2008 | Office Equipment & Supplies
Smudgy Photo orints
Make sure you are printing on the correct side of the paper. Most photo paper is single-sided. If you print on the wrong side, the ink sits on the surface, pulls up into very small drops, and remains wet for quite a while. If you print on the correct side, the image should be dry to the touch within 15-30 seconds.
Jul 29, 2008 | Canon PIXMA MX300 All-in-One Printer
Printing photos on hp psc 1215
Apr 21, 2008 | HP PSC 1215 All-In-One InkJet Printer
HP Officejet Pro L7380 Laser Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
