Question about Dell (6F858) Cooling Fan
Fan Noise on Dell Dimension 8100
I have a Dell Dimension 8100, was new in 2002. I bought it used. It's in good shape, but the fan is making a lot of noise, so I probably need to replace it.  Question: It has only ONE fan doesn't it?  And it is variously referred to as "Cooling Fan" and "Processor Fan"?  What are the specs for replacing the processor fan in my computer?
  • fixya1992yaf Apr 07, 2009
    The Dell Dimension 8100 has a shared 92mm case fan with a plastic shroud to the processor heat sink, so there is no separate processor fan. It uses a non-standard flat 3-pin plug with a clip. An off-the-shelf fan with standard connectors will not work without modification. I am guessing this is yet another attempt by Dell to make you buy everything for your computer from them. From what I have read, if you try to power the fan from the power supply, the BIOS will give you an error at post. It should allow you to continue, but A. if the new fan stops turning or slows, you will have no way of knowing without turning the case around to look so if you did have a problem, you may as well kiss your processor goodbye and B. this is just annoying to have to tell your machine to continue booting every time you turn it on.
    Also, if you have to replace the power supply for this machine (as this is another source of fan noise), DO NOT attempt to use a standard, off-the-shelf power supply. The main connector for the motherboard does match up perfectly to a standard 24 or 20+4 pin ATX connector, but the wiring is different and the board has a separate non-standard plug that a typical supply will not have. I would not even suggest plugging a power supply tester into your power supply unless you want to buy a replacement. Again, not a nice move on Dell's part.
  • 24 Answers
All computer fans have a general design.  The name in front of "fan" really refers to the designation.  You'll see case fan, processor fan, CPU fan, cooling fan, etc.  In the case of CPU/Processor fan, some are sold with heatsinks (the metal block sitting on top of your CPU).
The first thing you want to do is make sure the fan is clean.  Chances are dust buildup is causing the excess noise.
If that's not the case and you're looking to replace the fan, then you first need to find out the size of the fan. General sizes(diameter X width in mm) are listed on this page:
http://www.svc.com/case-fans.html
Generally, you're looking for something that will match the size of what you're replacing & push enough air at a reasonable noise level to cool the heatsink/CPU.  You want to stay in the area of 30dBA max for noise.  You also want to see if it has a 3-pin or 4-pin connection.
For example, if you have an 80mm fan, I would suggest something like this:
http://www.svc.com/saf-b82-19.html
It's pretty quiet with good airflow.  Also, it has a 3-pin connection, but includes an adapter for a 4-pin connection.
Z
Posted on Oct 27, 2007
How do I remove and replace a CPU cooling fan on my Dell Dimension 2400
Make sure u can open the casing well to expose the interior parts without causing any damage. Then by close look at the processor area , that is where the heat sink is located. Normally the dell dimension 2400 has a green channel shaped structure that acts as a passage for the air that enters in and out for cooling the heat sink. It has a locking parts that slides into the casing back by slight pressing to the back of the casing just behind the processor area, be so observant to notice the locking parts. then the fan is just fixed behind that green " channel like" and its fixed on the rear side of the casing, 25275582-o0cuhlgwrl13okm3u3q5444d-5-0.jpg
Nov 08, 2014 | Dell Dimension 2400 PC Desktop
My DELL Dimension 5150 fan is making a great noise, how can I fix it?
Turn the computer off.
Disconnect the AC power.
Remove the side-panel.
Buy a can of compressed-air, and give your computer a "blow-job" to remove dust from "everywhere", including the fan(s).
If you still get noise, then it's time to replace the fan.
Take the computer to any computer-store, so that they can sell you a new fan that matches the current fan.
May 07, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I HAVE CHANGED SO MANY POWER SUPPLIES IN MY COMPUTER THINKING THAT IT WOULD STOP MAKING NOISE BUT ALL HAS NOT WORKED AT ALL. (THE FAN OF THE PROCESSOR DOSE NOT MAKE ANY NOISE)IT IS DELL DIMENSION 8300....
is your fan brand new? you can remove cover of that power supply and take out that fan put some lubricant like f2 oil. that brand i use to lubricant on scanner and printer and in fan also.
Apr 08, 2010 | Dell Dimension 8300 PC Desktop
Dell dimension 4700: top fan makes a lot of
some fans are just loud, they tend to speed up and get louder when the computer heats up, it keeps it from over heating... if it always runs hard and loud the internal thermostat could not be working right.
Feb 23, 2010 | Computers & Internet
The fan in modem makes loud noises at times
Modems don't have fans.
I think you mean your fan in the computer makes a loud noise. Some computers have settings where the fan speeds up if you are doing a lot of things--making the computer work harder.
Some fans make noise just before they fail. Depends on the type of noise. If it's a sound that has a lot of rattling in it or maybe a high screeching sound, I'm thinking you'll be needing a new fan. Probably a CPU fan is the culprit. Also, fans on video cards often go bad--so you'll have to open the case and listen to where the sound comes from.
Oct 25, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
Noisy system fan
Here are a couple things to check.
  1. Are there other fans (other than the one you replaced) in the system? Many times, even with systems that use one main fan to cool the CPU and case, there can still be a fan within the power supply. There's a good chance that the power supply fan is the noisemaker. Also check for a fan on the video card.
  2. Check to make sure there are no wires or debris that could be lying against the fan blades.
My guess is #1 is the culprit.
Mar 16, 2009 | Dell Dimension E521 PC Desktop
Fan/ engine whining sound
If the fan is only making wind noise it is ok. If it is making matalic noise replace fan. It would be a good idea to clean (blow)out the dust and dirt for the inside of the computer at this time.
Jan 12, 2009 | Computers & Internet
Dell dimension 4700 power supply fan has gotten very loud
i'm not sure whats wrong with it put it maybe that the bearings in the fan are bad i suggest that you get a new fan:)
Jan 04, 2009 | Dell Dimension 4700 PC Desktop
Loud Dell desktop
Any fan that is making noise you would need to replace. There is also never a need to use alcohol to clean a fan. Some computer air or a light wipe down will do just fine.
If you have any other questions let me know.
Thanks,
Lee
Jun 26, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5100, power button has turned orange
If under warranty contact Dell? I had this same problem, a new motherboard and fan assembly fixed this problem. Bad capacitors on the motherbard.
Apr 12, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell (6F858) Cooling Fan Logo
2,069 people viewed this question
Clive
Clive
Alun Cox
