Question about Philips 32PT6441/37 32" TV
Philips tv problem my tv will only display Avi and side and hdmi , I can't get to that regular channels on my television
Can't get the regular channels
3 Suggested Answers
SOURCE: i have a philips 32pf5331/10,
sorted it
Posted on Jul 10, 2008
tthekraut
  • 374 Answers
SOURCE: Philips Plasma TV/Model #42PF9630A/37 Lately my
There are a few other things that can be done. Let me point out a few to try.
Try to tune the the picture in the settings. Look under the visual settings to see if there is a "Temperature" setting and try different settings to see if it helps.
There are updates for this TV available HERE
I would suggest updating the TV with the latest firmware.....this may or may not help but your TV will be up to date!!
I will try and get some calibration settings. These may help get the colors better conditioned. Let me know and I will optain them for you!
Posted on Sep 14, 2010
LG 37LD490 TV. After two years of no problems we now have no picture but sound on Game (Wii) and DVD (all discs) input channels. The main HDMI (Sky) and Antenna inputs are perfectly fine. Changed the AV...
the avi board is separate from the the hdmi board. would say there is a fault with the avi board may need replacing or may be able to fix it.
Oct 01, 2013 | Televison & Video
When I plug a brand new HDMI cord into my Vizio VA26LHDTV10T it says
Have you used the input display ie usb freeveiw hdmi avi ect because your tv will have a input display ?
Sep 07, 2012 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
How do i get regular tv channels no cable or direct tv. I have a 32' magnavox model #32MF338B/F7
Hello
I'm not sure about the model number of your TV, as here it is marked as both "27MS343S and 32MF338B/F7". Anyway I gies this solution as for the first denoted.
Insert antena to the antena socket at the back side of your TV marked as 75Ohms antena input.
[1] Press "Menu" button on the remote control handset to display menu on screen.
[2] Press "Vol+ or Vol--" button repetedly to hilight "TUN" [Tuner].
[3] Press "Ch+ or Ch--" button to hilight 'AUTOPROGRAM"
[4] Press "Vol+" to programming tv channels.
Tv will tune and store channels transmitted channels at that time, through entire bands, and will display the first channel receved after tuning process completed. It may take some minutes. You have to wait it to complete. After displaying the first channel, you can select your favourite channel Using CH+ or CH--" buttons. Ok.
Nov 03, 2010 | Philips Magnavox 27MS343S 27" TV
I need to change the source on my tv to HDMI without my remote
Not sure if yours is the same but Philips codes work with Skyworth and if you hit the TV/AV button on the side of the TV and the table of options should come up. And then with the channel +or- go up and down till you are on HDM1 or where ever you want and then touch the TV/AV again when you are there.
Mar 27, 2010 | Philips 32PF5531D 32 in. LCD Television
I have an DVI to HDMI cable running to my Playstation 3. The playstation reconizies the connection. When I search the tv for the connection I connot find it.. The back of the tv says the DVI input is...
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Dec 03, 2009 | Philips 51PP9100D 51 in. Television
Looking for hd channel
To get an hd picture you have to use a digital input and this cannot be done by simply turning it to a channel. You need to hook up your HD receiver (box) to your tv using either an HDMI or a Component which will be a cable that looks similar to an rca but there are three of them and the colors are bed blue and green. If there is a red, blue and green on the back of the cable box and the tv hook them together with a component cable and then find the input on your tv that correlates to the compnent connections and then even after all of this you need to be tuned into a channel that is offered in high definition and if you have cable like I do the high definition channel will be a seperate channel from the regular one. Comcast in my area puts the HD's from channels 400-500. For example my espn HD is channel 403 but just regular espn non HD is on channel 27 in my area.
Sep 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
"Display connected non-HDCP compliant" error
The HDMI cable was causing "Display connected non-HDCP compliant" error message to appear.
When I reconnected my DVD to TV using regular cable with 3 color connectors(i don't know what is the proper name for that cable) that error message no longer appears on my screen and I was able to watch my movie normally.
May 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
HDMI input
This confused me when I first got this tv. The inputs (HDMI, CVI, etc.) are more like channels. Go to channel 2 and the keep flipping down the channels. You will see HDMI just below channel 2.
May 19, 2008 | Philips 30PW8420 TV
Hdmi issue
This may sound silly, but are you changing the channel to the HDMI channel (one of the AV channels)
Oct 12, 2007 | Philips 42PFL5332D 42 in. LCD Television
Black borders
Check the resolution settings on your cable box, you may have to call your cable provider to find out how to get into the settings menu, there is a stretch function in the settings that should make all the lower channels auto fit your screen, also see if there's a p=size button on your remote control, try pushing that when on the channels that have sidebars.
Oct 26, 2006 | Samsung SP-S4243 Television
Philips 32PT6441/37 32" TV Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
