Question about Acer Aspire One AO532h2588 Netbook
Need to re-install the operating system to a netbook that doesnt have a CD-ROM.
How do I re-install Windows 7 from a USB flash drive?
    Prodigy:
    An expert who has answered 500 questions.
  • Acer Expert
  • 510 Answers
All you have to do to reset (as long as the HDD is intact) is when unit is first powered on press Alt + F10 together about once every second and it should state "windows is loading files"...It may take a few attempts, but should work ok, follow onscreen instructions to run a factory default recovery, good luck.
Posted on Feb 11, 2014
4 Suggested Answers
nassimjd
  • 104 Answers
SOURCE: \Windows\System32\Config\System; Repair w/CD-ROM; NO CD-ROM
if you can get an external cd/dvd drive from a friend, then you could solve the problem.
other solutions would mean that you will reinstall windows again. This takes more time and has a few tricks to be done from a flash drive.
Posted on Mar 24, 2009
  • 40 Answers
SOURCE: get an error message that windows would not start missin or corrupt windows\system32\config\system
you can use system restore to solve this problem .
try to restore your system to an earlier working restore point.
this will fix your problem.
Posted on Apr 22, 2009
  • 236 Answers
SOURCE: Hi, my acer aspire one
The Acer Aspire One Netbook has a hidden partition containing the files required for restoration to the original factory condition. The restoration clears all user data from the C: drive and requires that you have the netbook plugged into its AC adapter as the process takes significant time during which it should not be interrupted at the risk of hard disk corruption. To begun the process....
1. power on the netbook while it is plugged into its AC adapter
2. during power-on, while the Acer Logo is showing, press Alt and F10 together several times
3. Acer eRecovery loads showing the Windows screen momentarily
4. follow the on-screen directions and make the selection to recover the factory default image
Posted on Apr 10, 2011
How do I install windows without a CD-ROM it has USB slots only?
Copy the CD ROM to a 5 GB memory USB thumb drive. Take the netbook into recovery mode and point it to the USB.
DIDNT THE NETBOOK COME WITH AN OPERATING SYSTEM?
Although not sure, if it has no CD-ROM the OS would be on a hidden partition within the netbook.
Nov 03, 2015 | Computers & Internet
Tip
Installing Windows 7 to ANY Netbook Using USB Drive
To copy the Windows 7 ISO file to a USB flash drive Before you begin:
  • Make sure you've already purchased and downloaded the Windows 7 ISO file to your PC.
  • Make sure you've copied any files on the USB flash drive to an external location. The Windows 7 USB/DVD Download Tool will erase any data on the USB flash drive.
  1. Click the Start button d49affd.jpg, click All Programs, click the Windows 7 USB/DVD Download Tool folder, and then click Windows 7 USB/DVD Download Tool.
  2. Under Step 1 of 4: Choose ISO file, click Browse, browse to the Windows 7 ISO file you downloaded, click it, click Open, and then click Next.
  3. Under Step 2 of 4: Choose media type, click USB device.
  4. Under Step 3 of 4: Insert USB device, click your USB flash drive in the drop-down list, and then click Begin copying.
  5. If you see a dialog box that says that there isn't enough free space on the USB flash drive, click Erase USB Device, and then click Yes.
  6. When the process is finished, click the Close button 890548ff-eff6-4f93-ba12-92692a835f86.jpg in the upper-right corner of the window.
To install Windows 7 using a USB flash drive If you don't need to start your netbook using the USB flash drive, you can simply browse to the USB flash drive, and then double-click setup.exe to begin Windows 7 installation.
To start your netbook using the USB flash drive:
  1. Turn off your netbook, insert the USB flash drive, and then restart your netbook.
  2. Press any key when prompted, and then follow the instructions that appear.
  3. On the Install Windows page, choose your language and other preferences, and then click Next.
    If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
  4. Follow the instructions to finish installing Windows 7.
on Apr 19, 2010 | Computers & Internet
Tip
How to Install Windows 7 from USB Flash Drive
what if you don’t have DVD-ROM and you are running Windows XP, you might have guessed in this case we can’t install windows 7. Since Windows 7 ISO size is around 2.24 GB so its obvious that you will need to burn windows 7 iso on DVD and another issue is you can’t start windows 7 installation by mounting ISO file on windows XP as Windows XP upgrade to windows 7 is not allowed. In such situation installing windows 7 from USB pen drive is feasible solution.
Here is small guide on how to install windows 7 from USB flash drive or USB pen Drive for Windows XP users.
How to Install Windows 7 from USB Flash Drive Requirement:
USB Pen Drive (Min 4 GB)
Windows 7 ISO (32 bit or 64 bit)
MBRwiz Download and Extract it on your hard drive (Diskpart utility for Windows XP doesn’t detect USB drive as Disk hence we need to use this free utility to make bootable USB drive).
1. Connect your USB Flash Drive to your computer Format USB drive
2. To Format USB Flash Drive Go to My Computer -> Right click on USB drive and select Format from context menu.
3. Now go to Start Menu->run->cmd (Open Command Prompt) and Type following command
convert i: /fs:ntfs (Where “I” is your USB drive latter)
4. Mount Windows 7 iso as drive (You can use Freeware MagicDisc download from here).
5. Type Start->run->cmd
Now dir to directory where you have extracted MBRWiz and run following commands
mbrwiz /list (note down disk number of your USB Pen drive)
mbrwiz /disk=X /active=X (X is Disk Number of your USB Drive)
exit
6. Now open another command window and type following command
J: (Drive letter of Windows 7 iso mounted with demon tool)
CD boot
bootsect /nt60 Y: (Y is drive latter of your USB drive )
7. Now copy all files from drive where you have mount Windows 7 iso
8. Now reboot your computer and press F9 to get your BIOS screen and select USB drive as your boot drive.
9. If every thing goes fine, Your Windows 7 Installation should start from your USB drive.
on Jan 10, 2010 | Computers & Internet
I would like to know what CDRom Drive is compatible with Sylvania Netbook 7"
1. if the cd rom is usb then the netbook should detect it immediately unless it is too old for the Windows 7 Operating system
2. you can check the manufacturers site of the CD ROM and see how old it is.
if it is too old it will not mount .
3. you can check the compatibility mode for the device and see if it will load under another OS ( operating system ) such as Windows XP or Vista.
4. check windows update for latest drivers
5. Here is a link for Windows compatibility:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Jul 14, 2011 | Sylvania G-Netbook
Is it possible to fix a notebook that has a message with load needed dlls for kernel. It's for a notebook. I've looked it up and it tells me to put the cd in and restore it. I have a notebook and...
Hi.
Yes it is possible to fix the netbook. All you need to do is reinstall the operating system. You will have to get hold of an external DVD/CD drive or install Windows through a USB drive.
With a DVD/CD drive all you need is the XP installation CD. Connect the drive to the power outlet and then plug the USB lead to the computer. turn the netbook on and hit the F12 key or the key it tells you for "Boot Options". Select the "USB CD-ROM" device and follow the on-screen instructions to reinstall the operating system.
If you haven't got an XP installation CD then you'll have to purchase one.
You can also install XP from a USB flash drive. Click on the link I have provided below for an in-depth explanation for how to install Windows XP from a USB flash drive>>>
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
If you decide to install using the USB flash drive then to get the system to boot from the USB flash drive just follow the same instructions for the DVD/CD drive.
Hope this helps and please post back if there is anything else.
Regards.
May 23, 2011 | Computers & Internet
Upon startup before anything else happens (except asking me if I want to press f2 for setup) my aspire one netbook says: For Atheros PCIE Ethernet Controller... v1.0.0.5(1/22/09) check cable...
This means you should install an Operating System.
If your notebook doesn't have a dvd drive you can install the Operating System with an external drive (dvd, USB flash drive or hard drive). and press F12 when it starts to select the booting device.
Follow the link below to find out how to create a USB flash drive bootable (also works on hard drives):
http://forum.bstdownload.com/how/55-how-create-bootable-usb-stick-when-using-windows-vista-windows-7-a.html
Feb 01, 2011 | Acer Aspire One PC Notebook
My pc is not booting so is their any solutions for that. i need instructions for making a bootable XP without nero. becoz i dint have a blank cd wih me right now, to write a cd
You can't boot Windows XP from a floppy disk the way you used to be able to with DOS. One handy way to easily boot XP is by using a USB flash drive. Here's how to make it work. Boot Windows XP from a USB flash drive
Aug 24, 2010 | Computers & Internet
I have just bought a Lexmark S405 printer, however I want to install it on my netbook that does not have a cd drive. Can a printer be installed without the CD?
Click here Click on above link download driver for your printer for your operating system. Then copy it to usb flash drive then you can install driver with that usb flash drive so you don't need cd rom. Let me know if you need further assistance. Thanks for using FixYa.
Aug 14, 2010 | Lexmark Interpret S405 Wireless All-in-One...
How to repair mini netbook
You need an External CD Rom or a Pen Drive.
If you can get access to a pendrive which is not less than 4 GB storage capacity.
Back up the files before creating a USB-Based Installer.
Download "WintoFlash", you can download it from the link below
http://wintoflash.com/download/en/
Here is the page link on "How to"
http://www.downloadsquad.com/2009/08/27/make-a-bootable-usb-installer-for-windows-xp-vista-7-with-wint/
Dec 28, 2009 | HP Pavilion dv6000z Notebook
Installing windows xp
You will have to purchase an external dvd rom drive. Then select the external to boot from in system bios. You can copy win cd to usb stick and install from that but it is a little tricky. Good Luck.
Nov 23, 2009 | HP Mini 1000 Netbook
Acer Aspire One AO532h2588 Netbook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
