Just want to know how too hook up the wiring on aiwa ts w5u
Aiwa ts w5u
Service manual for aiwa ts-w45u subwoofer
You might be be lucky and be able to buy (I couldn't find a free download) such a manual at:
http://www.manualzone.com/repair-service-manuals/Aiwa/TS-W45U-TSW45U/RWSPFM-52595262-1 (use manual only)
http://www.eserviceinfo.com/download.php?fileid=23533
27.April.2014
Apr 27, 2014 | Motorcycles
Recently moved and lost the cable that connects from the subwoofer to the receiver,,,Model number TS-W60U..Where can I buy a new one ?
A replacement can probably be found at Radio Shack. Aiwa was owned by Sony until 2004 but has been discontinued. "For service repairs of your old Aiwa appliances, you may call 330-1111 for service inquiries or email customercare@solidservice.com.ph. You may also contact the Sony customer hotline no. 02-8787600 or 09178077669 or email info.sph@ap.sony.com."
http://www.callcenterbeat.com/aiwa-service-center/
Sep 29, 2013 | Aiwa TS-W60 Subwoofer
Aiwa tw60 subwoofer have power but no woof sound
Aiwa isn´t a good subwoofer. The best are Rel, Sonus Faber, etc.
Here is the characteristics:
.1 20 watts, Min. RMS at 4 ohms, from 40 Hz to 160 Hz, with no more than 1% Total Harmonic Distortion
The subfrequencies are below 25 Hz, but TS-W60 work over 40 Hz!.
Bass frequencies (woof) are from 25 to 50 Hz.
Bad, very bad.
Sell it and buy a good subwoofer.
JMG
Jul 18, 2011 | Aiwa TS-W60 Subwoofer
AIWA TS W35U manual >speaker,subwoofer hookup
YOU SYSTEM HAS TO BE DESIGNED FOR A SUBWOFFER, SHOULD HAVE A CONNECTION IN THE BACK RCA JACK THAT STATES SUB WOFFER
Apr 19, 2009 | Aiwa Audio Players & Recorders
Won't take cd
All U can do is cry - no warranty and not cost effective to repair the DOA. Tough break.
Aug 12, 2017 | Aiwa CDC-X227 CD Player
Aiwa CDC-X517M Car CD Receiver . . .
The part you are looking for is called the "wiring harness" or sometimes called the "dc cord"
The best way to buy this (and you do need it to use the radio) is to find a local repair center that repairs aiwa car stereos. Ask them if they can order the wiring harness for an Aiwa CDC-X517M. I don't know what Aiwa charges for them, but it should not cost more than about $30 or $40. Some are cheaper and some are a little more.
I did a search for it on google and could not find anything. Very unusual.
The four spots you refer to are the RCA jacks to connect to an external amplifier. 2 are red and 2 are white.
That thing that plugs in above the 15 amp fuse is for your wiring harness.
The circular thing is a din cable jack and that is used for an external CD changer.
Once you get the wiring harness you should take it and the radio to a place that does car stereo installations and they can do the rest for you.
I hope this helps you out, and if it does I would really appreciate a good rating. Most people we help here never rate your help :( and we do most of this for free hoping for a good rating as a thank you for the help :).
Hope you have a great day,
Dave
Jun 20, 2008 | Aiwa CDC-X517M CD Player
Wiring problems
Most of current AIWA in-dash units are ISO/DIN compliant and therefore conform to the ISO Wire Color Code standard. If your model is ISO certified then it would be following the below illustrated wiring scheme.
You can verify its adherence to the standards by checking that the "Earth" wire reads 0 ohms using a continuity tester as against the ground/body of the stereo unit. Incidentally most current car models also follow the same standard with the exception of later VW / Audi vehicles and therefore would be simply be plug in.
If you suspect any deviation, perhaps you are better off purchasing an original Aiwa two, eight way plugs for your CDC-MP32 CD Player.
Hope this be of some help/idea. Post back how things are or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Aiwa CDC-X155
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
