Question about GE Kitchen Appliances - Others
Toaster will not toast
Toaster does not toast bread and elements will not heat. There is no reason why it does not toast it just is not functioning
  • 71 Answers
SOURCE: My toaster is hung up on '2'...and flashes. I just want a peice of toast!
Certainly seems like it's last day has gone!!
It did give you good reliable service didn't it !!!
Posted on Jun 04, 2008
SOURCE: Digital Display no longer showing, lever won't stay down
jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5934BGvirtualkey58410000virtualkey863-1N5934BG" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5359BGvirtualkey58410000virtualkey863-1N5359BG" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Posted on Jan 31, 2009
ukvacfan
  • 328 Answers
SOURCE: The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Posted on Apr 05, 2009
  • 30 Answers
SOURCE: Russell Hobbs RH2T toaster bread won't stay down w/o hold handle
Hi, most new toaster have a selenoid that hold down the handle while toasting then release when done so a spring bring the toast up. Possible problem with the selenoid, the electronic circuit that controls it or the plate that the selenoid holds. When you lower the handle you close the contacts of the AC line inside the toaster so if the handle is raised there is no power.
Posted on Aug 05, 2009
espressonist
  • 1711 Answers
SOURCE: Our 4-slice toaster (model 4cbc) is only toasting
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Posted on Apr 02, 2010
Toaster BTA830XL only toasting bread on one side the outside elements only. Not using bagel setting.
There are tow issues here: Bilateral elements (heating strips) of course are necessary for two sided toasting, and you mentioned the Bagel Setting. Are you saying the Bagel setting works with both sides in operation and inoperative when in normal mode? Obviously is in both modes, should only one side function, the element is burnt out.
We need more information.
Jan 16, 2018 | The Kitchen Appliances - Others
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
My calphalon toaster oven will not toast top of bread? Why?
The upper heating element may have failed or the toasting function may not have been selected.
Oct 06, 2014 | Calphalon Convection Oven, Extra Large
Black & Decker FC150R heating element needed
go to http://www.blackanddeckerappliances.com/
God bless you
Jun 22, 2012 | Applica Kitchen Appliances - Others
Toast cooks corrctly on one side and hardly at all on the oher. I have cleared all the crumbs out. It is the same whichever opening I use.
it means the other side has no heat to toast the bread!
The heating element might have been disconnected already, worst of all it is already burned!
try to contact the manufacturer to get the HEATiNG ELEMENT part or repair and replace the said part!
That'll solved ur probs!
Dec 01, 2010 | Prestige Appliances 50973 Toaster
Our 4-slice toaster (model 4cbc) is only toasting part of one side of the toast, as if a heating element has burned out.
Good Luck
Aug 05, 2009 | Dualit Kitchen Appliances - Others
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Kitchen Appliances - Others Logo
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
