Question about Microsoft Windows 7 Professional 64 Bit 3 Personal Computer Company Networks Automatic
Smartcard cannot be forwarded to Terminal Server via RDP
I try to connect to different Termnial Servers from the same client, but it would never forward my Smartcard. It only happens for one Client on every Server I try to connect to. Smartcard-Service is running on the Client and on all of the Servers, and I can use the SmartCard without problem locally on both the Client or one of the Servers, but if I try to connect to the Server via RDP and choose SmartCard as Login-Method, it doesnt forward, and I don't see it on the Server. Also, if I connect the CardReader to the Server and connect to the Server from the Client, I don't see the SC when looking for it from the client, but I see it when I login locally on the Server I'm using Athena IDProtect, but my Support-Ticket at Athena came to the Solution that it's a problem with the SmartCard Service. Yes, SmartCard is enabled in RDP, that was the first thing i checked. If I connect to one of the Servers from another Client, everything works fine. So it seems to be a Problem on the Client
  • EbrithilBowser Feb 11, 2014
    Additional info: The Client uses Windows 7 Professional 64bit, the Servers use different Windows Version, f.e. Windows 7 and Windows Server 2010 R2
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Try re-registering the services on the client computer and see if that fixes it. Otherwise I would consider reinstalling Windows on the client.
Posted on May 24, 2014
I am unable to on my thin client it is based on windows server
check your server RDP policy in terminal server configuration,double click RDP permission tab,add user everyone,set full permission.
Nov 13, 2009 | HP Compaq Thin Client T5300 (dc643a#aba)...
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
Conection to Microsoft Windows 2003 server terminal server
G key reset the unit, or failing that, re-image the device, and then setup your RDP connection from the default desktop.
Jul 09, 2008 | WYSE WT3235LE (902032-68) Network Terminal
Getting connected
Build a Windows server with DHCP and DNS and install Terminal Services. Open config on the winterms and setup the RDP client. Follow the prompts, it's pretty straight forward.
Term Service requires license after 90 days AFAIK, so you better have a plan by then.
Thats the easiest way to setup and connect, it is a far from complete solution, though.
I would suggest you google upgrading the winterm firmware using FTP, the older firmware is poor and slow.
Otherwise, these are great little termianls that will last forever and work well.
Mar 17, 2008 | WYSE Winterm 3350SE Network Terminal
Connection Problems
W2000 Terminal Server used to corrupt the accounts of RDP users every now & again. Wouldn't surprise me if W2003 did the same thing :{ I used to create a copy of the user's account on the server (with an incrementing number on the end of the account name) & change the default account in TS management to that new one when this sort of problem occurred. I then made a copy of the new account & deleted the corrupt one.
Of course there are all sorts of other reasons this may happen but that may take a fair bit of hands-on investigation to sort.
For info on what's actually happening: Have you looked in the TS logs? Or the System and Application logs? Have you looked ta the logs in the client? Can you connect to the same TS server & account using a PC & the MS RDP client? If not, try the solution above :)
Dec 27, 2007 | Compaq Evo T20 Network Terminal
Connect to a Windows Terminal Server
Yes. You need to install the RDP client software which can be downloaded from Microsoft. Procedure to install the RDP client on a MobilePro 880: Note: Steps 1 and 2 need to completed if you have not installed the Service Pack One for MobilePro 780 and 880. 1. Perform a "Hard" reset on the MobilePro 880. 2. Install NEC Service Pack 1: http://support.neccomp.com/kbtools/faq/mobilepro/mp1.asp 3. Make sure the Device Name is set to something other than "Handheld PC". 1. Start-Setting-Control Panel-Communications 2. Change Device Name to a Unique Name that is not currently being used on your network. 4. Establish a Partnership with a Host using active sync. 5. Disconnect the MobilePro from the host. 6. Install "hpcrdp.exe" on your host. It can be down loaded from Microsoft: 1. Go to http://www.microsoft.com 2. Select "Search microsoft.com" under the Search tab. 3. Type "hpcrdp" in the search box and depress Enter. 4. Look for the search results titled "Terminal Server Download for Windows CE". 5. Double click on the article and follow the link and at bottom of the Terminal Server License agreement you will find the link to bring down the RDP client. 7. Establish an Active Sync connection between the host and MobilePro 880. 8. The RDP client software will be installed on the Mobile device. 9. Install a NE2000 NIC (or any NIC that you have the MIPS CE drivers for) into the Mobile Pro 880. 10. Set up network and attach to your existing network. 11. Set up a RDP session: 1. Start-Programs-TerminalServerClient-Client Connection Wizard 2. Enter Description connection. 3. Server Name or IP address. 4. Next 5. Enter user name, password and domain if you want to logon automatically. 6. Next 7. Finish If your terminal server is set up correctly you should be able to connect as a Client.
Sep 15, 2005 | NEC MobilePro 800
Sep 15, 2005 | NEC MobilePro 770
Software on the MobilePro system to connect to a Windows Terminal Server
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Sep 14, 2005 | NEC MobilePro 880
Microsoft Windows 7 Professional 64 Bit 3 Personal Computer Company Networks Automatic Logo
145 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
