Tdk nx 4cd
MY CD PLAYER SAYS NO DISK AND WONT SPIN AROUND EVEN FOR ME TO CLEAN IT I DONT WANT TO THROW T AWAY RADIO FINE EVERYTHING ELSE JUST THE CD PLAYER
  • Beverly Paul
    Beverly Paul Feb 13, 2014
    brian murphy can u send me that manual for the tdk NX4CD HOW DO I DO MY EMAIL ON HERE THANKS
2 Suggested Answers
SOURCE: Instruction manual for TDK NX-03 CD Sound System needed.
I have a manual if you want to send me your email I'll will scan to PDF and send you a copy.
Posted on Jan 31, 2010
Everything works on my stereo system,but there is no sound
Car Stereo Head Unit Install ** No Sound ** Amp Not ...
? 10:41
https://www.youtube.com/watch?v=wQ9bSdJGMjg
Mar 23, 2014 - Uploaded by PSYCHOTICNORMAN
Video for those who installed their head unit correctly, but got no sound / factory amplifiers not turning on. ... Car Stereo Head Unit Install ** No Sound ** Amp Not Turning On ** work around. ....Did everything to the letter on a 2001 Chrysler Town and Country and while I do have audio, my audio is cutting in ...
Everything works on my stereo system,but there is no sound ...
www.fixya.com/.../t26059653-everything_works_stereo_system_but_no
1 hour ago - everything works on my stereo system,but there is no sound lxi 4cd canger - Chrysler 2001 Concorde question.
Chrysler Concorde radio works but no sound Questions ...
www.fixya.com > ... > Cars & Trucks > Chrysler
Chrysler Concorde cars & trucks radio works but no sound questions and answers. ... Fixya - Solutions for Everything ... My 2002 concord lxi when ... CAR STEREO HAS POWER BUT WILL NOT OPPERRATE ... Question about 2001 Concorde ... ...sound from radio thru speakers Is there any popping when playing a CD or ...
Jan 19, 2016 | 2001 Chrysler Concorde
No audio output on the speakers of TDK NX-4CD.How do I troubleshoot?
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Dec 02, 2014 | TDK Audio Players & Recorders
NX-4CD CD is read but no audio out
You need to be more specific. What have you tried so far?
Sep 16, 2014 | TDK Audio Players & Recorders
Cd player is not workig.
Sometimes the lazer will get jamed.
Gently move the lazer eye (without touching the lense) to the outside of the disk draw, put in a disc and try.
It might work (has for me)!
If the disk won't spin then the drive is probably stuffed, probably cheaper to replace than repair.
Good luck, new cd/radio players are relatively cheap, so not many people fix them any more.
Throw away society, sorry if this didn't help.
Dec 17, 2017 | GE 7-5290 Clock Radio
My 5 Disk CD player doesn't work. It wont read any kind of CD. The radio and Tape Decks still work though. How can I fix the CD player.
Hello Alison hi, we need to check two parts to see which is the problem section why your player wont read.
  1. Does your CD spins normally, check your player if the cd spins normally, if you can see the disk spinning, take note of the spin, is it to slow? An abnormal disk spin has problems with its spindle motor assembly.
  2. Does your CD spins and then slow down to a stops, did not read the disk. This is caused by two things, FIRST: your CD player lens needs cleaning, you can buy a CD lens cleaner and use it to clean the lens, SECOND: The lens has degraded or worn out due to use and time, this needs a replacement lens assembly.
This things are way beyond a normal user, I suggest you send it for service. Sorry, there are no user serviceable parts here.
Aug 19, 2010 | RCA RS1285 CD Shelf System
Need a new connect main cable for nx 4cd where do i get one one broken pin in cable
So do I. I'd like to find the answer to this question... not even TDK support can help me.
Aug 16, 2010 | Audio Players & Recorders
Dec 16, 2009 | TDK Audio Players & Recorders
Car radio is not reading any cds or dvd
You need to disasemble the stereo and clean the laser lens manually
Jun 23, 2009 | Naxa Electronics NX-662 CD Player
TDK NX-7CD not working
With some of the TDK NX models the 9 pin lead between the subwoofer unit and the control unit gets damaged in careless connection. Its not the most idiot proof connection out there and when the connector is not aligned rotationally with the socket and/or pushed in at an angle, the connection pins can get bent. Sometimes if there arent too many pins bent, the pins can be carefully straightened and when properly inserted, the unit will work perfectly. In most cases however, one, or maybe even two fuses in the subwoofer unit will blow. If the unit doesnt work in your case after correcting the lead issue, open up the subwoofer unit by removing the screws around the outer edge of the back panel of the subwoofer (about 10 screws) and carefully prize the panel away from the subwoofer box. Sometimes this may be difficult as the back panel is glued to the subwoofer box to varying degrees. Dont pull the panel away from the box too far as it is connected internally by leads, etc. You should find the two fuses on the circuit boards attached the the inside of the back panel, one for the input transformer and one for the amplifier circuitry. Replace them (**** Smith or Tandy electronics stocks them) and you should be in business. If it still doesnt work, there may be some additional damaged caused, but this is rare. If you need a new lead, Imation (TDK) will supply you one at a cost. Hopefully you can get it up and running as it is a great little HiFi.
Mar 21, 2009 | TDK Audio Players & Recorders
52 people viewed this question
 Grubhead
Grubhead
