My broadway xy-360 trd multi tester is not doing well
When i put i select my multi tester on ohm selector to x1 or x10 the hand can not reach to 0 ohms even adjust the 0-ohm knob.
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 82 Answers
Check the 500mA/250 volt 20mm fuse as well as the AA batteries (it takes two). That should get this multimeter working again.
Posted on Feb 11, 2014
FFU14FC4AW3 keeps on running. Will not stop, even it is full and everything is frozen solid.
Try checking the Temperature Control:Testing Temperature Control
Test the control for continuity using a multi tester. Set the multi tester to the ohms setting X1. Place a probe on each terminal. Turn the control to warmest setting or off. The multi tester should display a reading of infinity. If the control does not have an off position, the reading should be near the infinity end of the scale. Now change the control to the coldest setting and retest. The display should read zero ohms. If the control does not pass both of these tests, the switch should be replaced.
Aug 27, 2012 | Frigidaire Freezers
Hi, I have buy nokia 5300 battery BL-5B on last week .but this battery have not standby long time ..I have charge battery morning and mobile have full charge battery 1 hour .then I call to mobile 1...
if you know how to use a multi tester try to check if your phone is shorted, put the range value to ohms x1 and top it to the positive and negative battery connection of the phone.
Oct 11, 2010 | Nokia 5300 Grey Cellular Phone
My multitester doesn't react
there are several reasons why the tester doesn't react..try to check these:
1. Check the safety fuse inside it.
2..The test lead set (the red & black wire w/ pin )
might have cut inside it,particularly in the part of
ends,near the pins/plugs.
3. The bateries might be o voltage and need to be
replaced.,or if the batery is good,just clean the
contact or teminal of the bateries.( a common
multi tester have 3 bateries, composed of 2 size
"AA" & 1- 9volts size.) these bateries are all
assigned to the "continuity"section of the tester.
(these are: X1;X10;X100 ; X 1K & X10K. )
so,if the tester is not functioning only in that
section,the first thing you have to check are the
bateries.Now.if you replaced the bateries with
new one but it is atill not working,then we go
back to my tip number 1 above.,that is to check
the test lead.
3. if you already finish checking the above method
and it still not working,then there is a problem in
the resistors of the system.
But, is your tester is digital? if it has no power: just simply check the fuse & batery..But if it has a power but not working when you use to test,you jst check the test lead or the selector switch becos the contact inside might be loosen.
Dec 03, 2009 | Skil 2100DAF Digital Angle Finder
I have an old Tripp-Lite SMART 500 UPS. When plugged in I get no lights at all, I have tried all switches. I cannot find a manual on line for this particular model. What would cause this? It seems like...
You unscrew the UPS cover to get it open.
1. Find the fuse, see and check if it is alright with a
multi tester. Set the tester at Ohms 1 x 10, and
put the red probe of the tester at one end of the
fuse, while the black probe to the other end of the
fuse. The pointer must be at zero. Otherwise, have
it replaced.
2. Test your UPS, if it is working. It it works, then,
it is a job well done.
3. If not, proceed testing the batteries for voltage
reading. Set the multi tester at DC volts 1 x 25 V
If this will register a residual voltage of 2 volts, try
plugging your UPS to an outlet. Test is after 2
hours. If the voltage improves, say 8 volts, then,
plug this back until the battery reaches the full
voltage rating.
4.Hook it up to your PC, and it's done.
Nov 28, 2009 | Video Game Consoles & Games
Need to replace the fuse for 1998 Explorer brake lights
Check for the busted fuse in the fuse box. This can be done using a multi-tester, Set the tester to 1 x 10 Ohms. Using a multi-tester, put one probe of the tester to one end of the fuse, while the other probe to the other end of the fuse. Good fuse will move the pointer to zero,
while bad ones won't. Check the fuse one by one.
Nov 21, 2009 | 1998 Ford Explorer
2002 gmc abs light is on tested sensors with ohm meter right hand side tested 15 ohms and left side tested 0 ohms where is my problem.
all sensors will read different depending on the wheel. so hookup ohm test again and then spin the wheels the ohm range should vary from 0 to 50 ohms both side should match. the side that remains constant or at 0 is faulty.
Oct 02, 2009 | 2002 GMC Sierra
Tub wont spin to ring clothes out. belt may be broke?
It would be of great help if you would have mentioned the name and model of your washing machine. In the case you have mentioned there several type of fix to this problem. One of these tips is to test the lid switch first.
Test the switch for continuity using a multi tester. Set the multicenter to the ohms setting X1. Place a probe on each terminal. The multi tester should display a reading of infinity. Depress the button on the lid switch and the reading should change from a reading of infinity to roughly zero. If it does not pass both of these tests, the switch should be replaced.
Some lid switches also have a fuse; you can visually inspect the fuse or test it for continuity with a multi tester. If the fuse is bad, replace it with one of the same rating.
The lid switch ensures that the lid is closed before enabling the machine to spin or agitate. This feature was added after serious injuries resulted from people reaching into an operating washing machine.
Test the timer control
Test the centrifugal switch
Test the water level switch
Inspect the motor coupler
Inspect the driver belt (belt drive only)
Inspect under the washer for soot (clutch)
Test the motor
Inspect the pulley
Test the transmission
Thank You for using Fixya.com
Aug 02, 2009 | Washing Machines
Logitech Z340 Power speaker problem
yeah you can fix that one into your own. first thing that you do is get a multi-tester and put the two terminal the red one and the black into the tip of male plug of you wire. then set your multi tester into the ohms selector any ohm selector which found at the right side of the multi-tester. if the arm of multi-tester was moving it means OK... if not open the speaker carefully and reconnect the wire by using soldering iron & lead.
Nov 04, 2007 | Logitech Z-340 Computer Speakers
Dishwasher doesn't stor filling
If the dishwasher's water flow doesn't automatically shut off, the float switch is faulty or the timer is stuck on "Fill" or the water inlet valve is stuck open. To test the float switch, you'll need an inexpensive volt-ohm meter (or multi-tester). 1) Unplug the dishwasher. 2) Reach into the cabinet and lift the dome-shaped plastic float switch. If it doesn't lift, remove the plastic top from the stem, scrub the stem clean, and then replace the dome. If it moves up and down freely, go on to step 3. 3) Note which wires are attached to the float switch's terminals and, using small pieces of tape, label them for later reference. 4) Set the volt-ohm meter's dial to Rx100 and touch the two probes to the terminals. When you lift the float, the tester's needle should show an infinity reading and, when you let the float drop, the needle should show 0. If it doesn't, the switch is broken and will need replacement. Unscrew it from the tub and replace it.
Jan 18, 2006 | Hoover 24 in. DT999 Free-Standing...
70 people viewed this question
 Grubhead
Grubhead
