Question about BenQ Joybook Computers & Internet
Cannot charge laptop battery
The battery status icon shows my battery is not charging when the AC charger is plugged in. Then i remove my battery, and the icon shows the plugged in status. I have already confirmed that my battery and my charger have no problem. So, what should i do?
  • 14 Answers
SOURCE: Dell laptop (E1705). Battery won't charge.
BUY Dell Inspiron E1705 Laptop Battery, you can go
http://www.notebook-battery.us/notebook-battery/dell-inspiron-e1705.htm
Posted on Apr 01, 2009
fossildude
  • 832 Answers
SOURCE: battery not getting charged-power supply on ac power
hi thanks for using fixya!!
Is your laptop is brand new? Try to remove the battery. Then, try using your laptop and AC adapter without the battery, you will get the power supply directily from AC adapter. If it works properly, then its okay. Now, try to install back your battery then try to charge it. If not charging, perhaps you need to buy a new battery. However, I suggest you bring your laptop to a service technician to further check the error, before you purchase a new battery.
If you need further assistance, let me know!
Posted on May 25, 2009
SOURCE: my eee pc charger wont charge my laptop...
we had a similar problem the ac jack socket burnt out so we got a replacement part from ebay and my husband put it in and hey presto it works it cost 6 pounds for the part whereas a company to fix it wanted 100
Posted on Jul 19, 2009
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
Jan 24, 2014 | Dell Latitude E5520 Laptop Computer PC...
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
ACER 5810T LAPTOP BATTERY NOT CHARGE IT SHOW THE MESSAGE "PLUGGED IN ,NOT CHARGING"
If your laptop computer runs normally on your acer 5810t charger, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
Jan 29, 2013 | Acer Aspire 5810T-8060 Notebook
I noticed that my charging status of my M-2623u laptop shows a "Plugged in, not charging" status. I turned off the system, took out the battery, waited 5 minutes, reinstalled the battery, and...
Similar topic on answers.microsoft.com below, may it would hlep:
http://answers.microsoft.com/en-us/windows/forum/windows_vista-hardware/gateway-laptop-plugged-in-not-charging/6db4fe50-d318-44da-a938-2fc58f4bbe7b
Apr 25, 2011 | Gateway M2623u Laptop Charger...
Will the laptop power up with a bad battery
You dont need battery to power up if plugged into mains charger.
Do any lights com on at all??
Dec 30, 2009 | Compaq Armada M700 Notebook
The battery status indicator does not show on my screen. I can only see it when I first turn on using battery power. It doesn't show me anything when it's charging, or how much battery life I have left.
The indicator goes away telling you that its no longer running on battery power and that its running on the car or AC charger. During that time, its charging the battery. Only when you remove the unit from the charger/adapter will you see the battery icon because you will then be on battery power. 4 green bars mean you are near or fully charged.
- Jim
SHARCNET-USA
Oct 07, 2009 | Garmin nuvi 265 Car GPS Receiver
Dell 14 laptop charging status is not showing when plugged in
if the battery is fully charged, it won't animate. but there will be a little electrical plug over the battery symbol. as long as the plug is there, your good.
Aug 14, 2009 | Toshiba Satellite P100 Notebook
I have an hp pavilion dv9350ea. Over a couple of years the battery became defective and I installed a new one. It showed 30% charge. I disconnected the charger to discharge the battery before re-charging...
I have to agree that the battery is defective or maybe it is NOT the correct one for your system, although it may be similar.
Did you buy the battery direct from HP a third party?
The AC adapter charger could be defective as well, maybe the defective battery ruined the charger.
I hope this helps.
Good Luck.
Mar 10, 2009 | HP Pavilion dv9000z Notebook
No battery status Garmin 760
Went to Best Buy and they didn't know how to get the bar up either but said that the unit should be charged in 3 to 4 hours. So, when i unplugged the unit from the wall...the battery status showed up. I guess it doesn't show when the unit is plugged into the AC charger. Now, all is well.
Jan 17, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Computers & Internet Logo
15 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
