Question about Miele Novotronic T220 Electric Dryer
Miele t1515 faceplate removal
Faceplate removal
4 Suggested Answers
  • 177 Answers
SOURCE: How do you remove the top of the Miele T1515
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Posted on Apr 25, 2010
  • 32 Answers
SOURCE: Miele T1515 - has started to make my laundry room
check the exhaust hose. it sounds like it has separated from the outlet and is spilling the hot exhaust into the room rather than through the vent outside
Posted on Sep 17, 2010
  • 83 Answers
SOURCE: Miele T1515 electric dryer -
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Miele T1515 - has started to make my laundry room feel like a sauna - why?
Sep 17, 2010 | Miele Novotronic T1515A Electric Dryer
Miele T1515 electric dryer - overheats and laundry room feels like a sauna. What can I do about it?
Sep 17, 2010 | Miele Dryers
My xbox wont turn on
Your console should turn on when the eject button is pressed. Press the eject button on the front of your console.
If the console turns on when you press the eject button but not when you press the power button, the console faceplate might not be attached properly. To make sure that the faceplate is attached correctly, you should remove it and reattach it.
  • Position your console horizontally, as you would position a DVD player.
  • Unplug the power cord and any other cables connected to the back of your console.
  • While holding your console firmly, curl your fingers inside the oval USB door on the front of the console.
  • Push the faceplate away from the console with your thumb until the faceplate comes off.
Note You will need to use some force to remove the faceplate.
Once the faceplate is removed, look at the tabs on the back. If any of the tabs shown in red in the illustration below are broken, order a replacement faceplate by contacting Xbox Support.
If none of the tabs are broken, re-attach your faceplate by pressing it firmly until it clicks into place.Try to turn on your console again. If removing and reattaching the faceplate did not solve the problem contact the xbox support.
Thank you!
Jul 31, 2010 | Microsoft Xbox 360 Console
Xbox wont turn on
Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
How do you remove the top of the Miele T1515 vented dryer?
hi,
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
Remove protective film wrap from under water dispenser faceplate
I have this same model and was facing the same issue. I even emailed Whirlpool but that didn't help.
You can remove the faceplate by removing the spill tray and unscrewing the two small screws in the bottom. Be careful not to scratch the finish while removing the screws.
The faceplate is held on by several plastic hooks around all edges. Carefully grip the bottom of the faceplate (I put my thumbs on the inside where the spill tray was and my index finger below the bottom front of the faceplate). Get a good grip by pinching the faceplate and pull down and out to remove the bottom. Then push the faceplate up to unhinge the top.
You can let the faceplate hang by the wires while you remove the plastic. I'd also use a stainless steel cleaner while the faceplate is off to get rid of any fingerprints you may have left behind.
To reinstall, hang the faceplate on the top 3 hooks making sure there is a snug fit. Then pull down on the bottom and push it in. It took me two tries to get it back on.
The plastic is stronger than it looks but you'll still have to go slow and be careful with it. Good luck!
Sep 09, 2009 | Whirlpool Refrigerators
Tighten the outside faceplate of a qwikset dead bolt.
The inside face plate snaps on. To remove it remove the T handle and use a small flat head screwdriver to genty pry it off. Behind the cover you will find 2 screws to remove the lock halves.
Don't forget to rate
Mar 12, 2009 | Kwikset Professional Door Lock...
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Putting on faceplate for samsung t319
hi you best bet is go to a repair mobile shop if are in doubt to try this .
you'll need a small Philips head screwdriver to complete the installation. To take off original faceplate, remove 2 screws located below the inside display (screws are hidden under stickers). Next, gently pry off the faceplate along the edges between faceplate and phone with a Faceplate Removal Pry Tool. When re-attaching screws, do not over-tighten screws
riz.
Aug 23, 2007 | Nokia 6288 Cellular Phone
Miele Novotronic T220 Electric Dryer Logo
27 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
