Question about Dryers
Miele t1515 dryer door reversal and faceplate removal
Need to remove the faceplate on front of dryer to access backplates for mounting door hinges
  • 189 Answers
SOURCE: WHIRLPOOL DUET DRYER
I've searched around for DIY instructions, but those are exceedingly difficult to locate. It seems that Whirlpool wants you to buy their Door Reversal Kit for 11.99 in order to accomplish this.
http://www.whirlpool.com/catalog/accessory_product.jsp?parentCategoryId=375&categoryId=376&productId=895
Posted on Jan 07, 2008
  • 163 Answers
SOURCE: Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
dragonsthatk
  • 547 Answers
SOURCE: reversing door
you can not change the way the door opens
Posted on Feb 11, 2009
  • 177 Answers
SOURCE: How do you remove the top of the Miele T1515
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Posted on Apr 25, 2010
  • 83 Answers
SOURCE: Miele T1515 electric dryer -
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Posted on Sep 17, 2010
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
An ring fell out of jacket pocket while jacket drying, can see ring when pull out lint catcher. ring located in "dryer pipe" opening next to a rubber gasket in the front of the dryer unit. How...
You will need to remove the hinges, they lift up and out once screws are removed, the the two white plastic pieces with the screws these are for door reversal, then the front panel lifts off. Good Luck Tim
Nov 06, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Can't find any instructions - can I reverse the door from the left side to the right side?
Hi and welcome to FixYa. I am Kelly. The answer is YES you can reverse the door.
Here is the text of how to reverse the door:
DOOR ASSEMBLY & HINGES
The door assembly is reversible. It contains an inertial vibration damper comprised of a steel plate suspended with springs. The
damper is designed to tune out excessive vibrations generated by the machine during the spin cycle. Replacement inner door liners are
shipped with the vibration damper in place.
REMOVAL
1. Open the door and remove the center screw of each hinge secured to the inner flange of the front panel in the door opening.
2. Grasp the door with both hands and lift the hinge area slightly. Draw the door assembly away from the machine. This will disengage the hinges from the slots in the
front shroud (Figure 5-1). If the hinges bind, press out on the plastic shroud near the hinge toward the cabinet.
Figure 5-1
REVERSAL
1. Repeat the above steps and, remove the corresponding sheet metal spacers on the opposite side.
2. Remove the hinges from the door and relocate them to the other side of the door.
3. Remount the door into the new slots and secure with one screw into each hinge.
4. Mount the sheet metal spacers onto the side where the hinges were previously to cover the hinge slots in the front shroud.
That is the text without the whole service manual pictures.
Thanks for using FixYa.
Kelly
May 21, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
How do you remove the top of the Miele T1515 vented dryer?
hi,
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
Hinge, oven door #822144
Pull up on the door to remove it from the hinges.
Remove the pan drawer on the bottom. Remove the spring from the hinge to be replaced. Remove the hinge mounting screws. Remove the hinge.
Reverse this process to install the new hinge.
Jan 06, 2010 | Amana ACF7225 Electric Kitchen Range
Trying to get the top up on maytag model #mdg7400aww. Need to get some nails out that was left in pocket & dryed. can you help.
For the model washer you have listed, there should be a a couple of retaining clips inside the front seam where the top panel meets the washer front. If you push a putty knife in the seam about 2 inches in from each side, you will be able to depress the retaining clips to release the top panel. With the retaining clips released, the top panel will open up exposing the mounting screws that hold the washer front in place. Remove the mounting screws and the entire washer front can be removed, giving you full access the washer interior. If you have any questions let me know. I hope this helps you.
Nov 27, 2009 | Maytag Dryers
I have bought a new door hinge for a hotpoin wd63p washer dryer but was wonderig do you have to take the front of the washing machine or the rubber
hi from uk easiest way is to turn off/remove water supply hoses disconnect power then remove top screws from rear panel(these also secure top panel if yo look ?) then lift rear of top panel slightly and pull back/then lift off you now have access to rear of front panel where door hing is secured by 2 screws from the front of panel/hing into a metal plate theaded inscrew door from plate whilst you hold plate thenremove door with hinge assy you will now see the inner plastic cover of door is secured remove this cover to access hinge screws renew hinge and whilst door is at this point might as well lift glass window and clean any **** around the edge ? reassemble in reverse to strip down hope this is clear enough for you ? good luck
Nov 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
71 people viewed this question
Top Dryers Experts
