Question about Jura Capresso Impressa F9 Espresso Machine
Touch-screen control display - Jura Capresso Impressa F9 Espresso Machine
TOUCH SCREEN
Initial Mode Function Setting Procedure
1. Remove the Compact Flash Cover [1].
2. Press the Warm Restart switch [2].
3. When "." appears at the center on the left-hand side of the screen, enter "3" from the
10-Key Pad.
4. Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Initial Mode: Total Clear
Touch Panel Adjustment
Marketing Area
Image Data Clear
Clear FAX Setting
Date/Time Setting
Trouble Reset
• To adjust the position of the Touch Panel display
• Make this adjustment if the Touch Panel is slow to respond to a pressing action.
• When the control panel is replaced.
1. Touch [Touch Panel Adjustment] from the Initial mode screen.
2. Following the arrow mark, touch the four points (+) sequentially on the screen using a
pen.
NOTE
• Be sure to touch the very center of each point.
• Use care not to damage the screen surface with the tip of the pen.
Feb 12, 2014 | Konica Minolta Office Equipment & Supplies
Disable the Key counter on my Konica 7130
HI,
Please refer the manual by clicking on the below link.This will solve your problem.
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Oct 07, 2008 | Office Equipment & Supplies
The touch screen on my minolta 350 can't be displayed whenever i press exactly on the written box but below the written box it can normal be displayed, i figure out it must need some adjusts to put it...
10-Key Pad.
Functions • To adjust the position of the Touch Panel display
Use
Adjustment
Procedure
pen.
NOTE
Turn off touch screen dell
If you are referring to touch screen feature, you may look into control panel for touch screen settings.
a. Click on Start>select Control Panel.
b. Check if you can find dell touch screen settings applications.
c. If you find one disable the touch feature from there.
If not, you may contact Dell for further support.
http://support.dell.com/
Hope this helps.
Sep 25, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
The touch screen has stop responding. All the other buttons on the control panel work and change the display on the panel accordingly, but you cannot select any options from the touch screen. Any...
PROBABLE CAUSES:
1. The control panel adjustment is incorrect. This adjustment will shift the position of the touch sensor of the LCD unit. Perform the following steps:
a. Hold the Help key and turn power ON.
b. Touch selection #10 (control panel adjustment) on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching #10, the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
Two + (plus signs) should be visible on the screen.
c. Touch the + at the upper right lightly with a touch pen (something with a round tip which is made of resin is recommended as a touchpen). Check the coordinates displayed in the top line at the top of the screen.
d. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
e. If the values are not within the acceptable parameters, repeat Step 3 until the values are acceptable.
f. Touch the + at the lower left lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
g. As verification of a correct adjustment, touch the CHECK keys at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
h. Turn the machine OFF to store the adjustment. Turn the machine ON normally and check operation of the touch screen.
Dec 09, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
How do i change the number of rings for xerox workcenter 123 to pick up for receiving fax
  1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed.
  2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen.
  3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen.
    NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
  4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed.
  5. Select [System Settings] twice. The System Settings screen will be displayed.
  6. Select [Fax Mode Settings]. The Fax Mode Settings screen will be displayed.
  7. Select [Fax Defaults]. The Fax Defaults screen will be displayed
You wll then see locations to set the amount of rings to answer, ECM mode etc.
Jul 23, 2010 | Xerox WorkCentre M128 Copier
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
Calibrate touch screen
Actually, the red cross's movement is part of the calibration. Continue clicking each individual red cross until you get a confirmation notion notice.
In order to calibrate the touch screen, the DS needs to know where certain areas of the touch screen are relative to the actual display. Basically, you're not really controlling the display. You are interacting with a hidden interface, which is the touch screen. But in order for you to "interact" with what you are seeing, the touch screen is laid across the display.
Dec 07, 2008 | Nintendo DS Console
How do i activate scan to email on xerox 7132
The Scan to E-mail feature provides the ability to scan and send a document as an e-mail attachment.
NOTE: The Scan to E-mail Kit is required to enable the Scan to E-mail feature. The kit contains a License Agreement, installation instructions, and a password.
To enable the Scan to E-mail feature:
  4. Select [Confirm]. The System Administrator Menu screen will be displayed.
  6. Select [Common Settings]. The Common Settings screen will be displayed.
  7. Select [Maintenance / Diagnostics]. The Maintenance / Diagnostics screen will be displayed.
  8. Select [Software Options].
  9. Select [Keyboard].
  10. Enter the password contained in the Scan to E-mail Kit using the keyboard on the Touch Screen, and then select [Save].
  11. Select [Reboot]. The machine will automatically power OFF, and then power ON.
  12. Enable the Scan to E-mail port settings. See the Related Items below. After the port settings have been enabled, the E-mail option will be displayed on the Touch Screen.
Jul 30, 2008 | Xerox Office Equipment & Supplies
Jura Capresso Impressa F9 Espresso Machine Logo
23 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
