Question about Electronics - Others
Hitachi radio npc fault - Electronics - Others
Large red spots growing in the middle of my 50v500 hitachi projection LCD screen
Hi, you have an Optical Engine fault. Complete assembly needs to be replaced. This page shows the most common Hitachi Optical Engine Faults.
Hitachi LCD TV Light Engine Optical Block Info
Nov 27, 2015 | Hitachi Televison & Video
Trying to find Reebok NPC Insigignia plus men's shoes for men
You will have to find some old stock, as Reebok for some reason stopped making their ORIGINAL classic shoe. Most of the old stock is unusually small sizes, like a 7 1/2, and I've seen some size 13 and 14, but nothing in between for at least 3 years. A similar shoe is available (NPC II), but it is obviously lower quality -- thinner sole, printed rather than stitched heel cap, etc. It has "Reebok" in place of the insignia on the side of the shoe.
Feb 21, 2014 | Reebok NPC Insignia Plus Shoes for Men
Hitachi UR18DSL site radio. works when plugged in, but not when fully charged battery inserted
test the battery with multimer for to see is o.k with the voltage. measure. Otherwise you can put the package with plastic bag(windzip) and put by 24 hours in the freezer from your refrigerator for to revival of your battery. and try again in your radio. ( this is smal secret for revival battery rechargeable.
God bless you
Nov 07, 2013 | Tivo DirectTV Remote Remote Control
Error connecting to samsung account ssl npc
I cannot connecting my samsung app because i see an error on my screen is that ssl npc
Feb 28, 2013 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Hi, i hv upgraded my samsung s5603 to s5600, s5600XEIG1, now problem is tat when i try to conect it to pc studio it says an unauthorised model conected comunication can not proceed. pls help me to get out...
Just upgrade the Samsung PC Studio also
The latest version of Samsung PC studio called (NPC)
Download the NPC (new PC) Studio from samsung website and install it on your PC and connect to
to your mobile.
Jun 02, 2011 | Cell Phones
E 21.3 FAULT DISPLAY
you didn't indicate what model number. ON a L200 for example E21 means over temperature. You need the model number
http://www.clrwtr.com/PDF/Hitachi/Hitachi-L200-VFD-Drives.pdf
For a quick reference on the L200 WHAT MODEL DO YOU HAVE? The .3 would be it's status when the fault occured. 3 means constant speed. Are you overloading the drive?
http://www.clrwtr.com/PDF/Hitachi/Hitachi-L300P-AC-Drives.pdf
This link is for a L300 for example
Sep 30, 2010 | Hitachi Electronics - Others
Namco Ps1 Guns not working (npc-103)
You must be using on a plasma or LCD tv right?
Will not work... Only works on old tradicional TV...
Jul 26, 2010 | Namco Time Crisis: Crisis Zone
Tr51 gets hot
Do you have a "swing kit" or a "swing diode" installed?
This could also be called an NPC ("Negative Peak Clipping") Modification. There should be a 1/2 watt 100 ohm resistor attached on the unbanded end of the diode. If it is a "Kit", It will not have a 100 ohm resistor and can cause TR51 to overheat during long transmissions.
You may want to remove the diode or kit if you have one in there and, as a better choice, change R238 (near VR13) to a 220K ohm resistor.
That will give you Killer loud audio with a stock mic. You probably won't be able to use a pre-amp (Power) mic after changing R238 to a 220k ohm.Back down the carrier power to 3 watts and watch the modulation get violent!
Apr 07, 2010 | Galaxy Radios DX 77HML Base CB Radio
Electronics - Others Logo
62 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
