Question about Saws
Cleaning Armorall off tiles - Saws
How to I clean the grout on my kitchen floor?
There are many ways to clean stained grout. You could try one of the commercial cleaners sold on the market and scrub it with a brush. You can also try creating your own cleaning solution. This way you will avoid using harsh chemicals in your home, which is always a good thing. You could try making a paste of baking soda and some water and use it to scrub the grout with, or you could spread some baking soda on the grout and then pour some vinegar on it. After about half an hour you should be able to scrub off the dirt easily. In some cases the grout is so dirty, that the only option is to remove it and apply new one. You can check the website attached, the professionals there know a lot about tile cleaning and maintenance.
High Quality Tile and Grout Cleaning in Melbourne
Oct 06, 2015 | Vacuums
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
Clean grease off terracotta tiles
There are a couple of things you could try. I recently came across a specific grout/tile cleaner that works well. You can buy it online. It is a type of cream that you spread over the grease and leave for a while. After it has set, you can use a toothbrush (for best results) to scrub off the soap and grease. Otherwise, you can try magic eraser. Those can be used on tiles and get off a lot. Tiles make up such a great aspect of the house, I hope you can clean them up.
Elisa Jed ' http://www.herrmanntiles.net.au
Feb 11, 2014 | Saws
How to use my staem cleaner
Follow the link below to download a copy of the User's Guide.
http://www.bissell.com/searchresults.aspx?searchtext=25A3&searchType=search&mode=userguides
The wood floor cleaner will work on your tile.
Jun 17, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
TURN SIGNALS DON'T WORK, FUSES ARE GOOD, I SPRAYED ARMORALL ON THE DASH TO CLEAN IT AND THE TURN SIGNALS STOPPED WORKING AFTER THAST
TURN SIGNALS DON'T WORK, FUSES ARE GOOD, I SPRAYED ARMORALL ON THE DASH TO CLEAN IT AND THE TURN SIGNALS STOPPED WORKING AFTER THAT
Apr 11, 2010 | 1995 Honda Accord
Need to replace the tile in front of the fireplace
More than likely, you will need a grout saw to remove the grout are the individual tiles you need to replace. the using a flat bar, carefully try to pry the tile up to see if it will simply pop out. I would set a towet or padded object on the edge of adjacent tile to prevent chipping those tiles. If the tile pops out, you will need to scrap out all remaining mortar to create a smooth surface again so when you replace the tile, it will be level with the surrounding tile.
If a large area of tile needs to be replaced, there are automatic scraper machines that can be rented at some Home Depot stores or may be available for rent at carpet retailers that sell tile.
The main point to remember is that all mortar, tile pieces, and grout are removed and the surface is smooth and clean. Even the smallest chip of tile can cause future cracks if the tile is unlevel when pressure is applied.
Hope this is the type of information you were requesting and that it helps.
Sep 16, 2009 | Lenox Ceramic and Tile Cutting Bi-Metal...
Listello resin 3 by 12 : tile;white grout stuck on the tile
yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
Jul 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Saws Logo
35 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
