-   I have the exact same issue. My unit is all of 2 weeks old now too, so its not a descaling issue. I've made maybe 20 cups of coffee since I got it.-   jcabotl
used the machine for 3 months. this morning it will not **** water from reservoir. the pump runs...
(More)
used the machine for 3 months. this morning it will not **** water from reservoir. the pump runs but the water volume in the tank doesn't lower. I have re-seated tank multiple times.
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles...
(More)
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
After making a cup of coffee you can hear the pump trying to refill the reservoir but does not work....
(More)
After making a cup of coffee you can hear the pump trying to refill the reservoir but does not work. The coffeemeker then cuts off.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
