Question about Building Materials
I have a Centurion D5 Gate Motor. It has just stop working.
The fuses looks ok and the light on the battery is on. There is no click sound if i press the test button also no led light that comes on on the test button. How can i fix this?
lobsterman72
  • 91 Answers
SOURCE: Opener wont open makes clicking noise
Your opener has been hit by lightning or power surge.
If it's not too old you can replace the 'back board' (the computer board on the back of the opener.) Also If the opener has safety sensors one or both of them may be burnt out too, and if it was really bad then the rpm sensor will go too. So you could be looking at paying half the cost to repair or just get a new opener. Up to you, and get a surge protector. Lift master has a good line of products and makes thier own surge protectors for thier products.
Posted on Jun 27, 2008
  • 3197 Answers
SOURCE: I have a 1995 Sear garage door opener that stopped working
The trolley (the part that moves back and forth and is connected to your door) of your opener is most likely jammed against the bolt just in front of the motor unit. You can remove the bolt or loosen the chain until your unit will run. Once the door is closed find the 'up limit' on the side of the motor unit and turn it about 3 turns in the opposite direction of the arrow printed on the cover. Now replace the bolt or tighten the chain. Whichever you first did.
Posted on May 28, 2009
  • 3197 Answers
SOURCE: My sears craftsman opener just stopped working all
I would remove the logic board and check for loose or missing traces on the printed circuit board. Electrical storms love that logic board.
Posted on Nov 11, 2009
Testimonial: "Great advice thank you."
  • 3197 Answers
SOURCE: My liftmaster pro started to open and then stoped.
The LED flashing 5 times is the code for RPM sensor or motor overload. The RPM sensor is a small circuit board just in front of the motor.
Posted on Nov 17, 2009
Testimonial: "This is the same helpful information I found on the internet. The internet went further to the SOLUTION is to pull the power cord to reset "
  • 3197 Answers
SOURCE: i need to programme extra
You can call the Technical Support Hotline at 0860-236-887 or you can e-mail at support@centsys.co.za.
Posted on Nov 01, 2010
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
How to program a ET BLU MIX remote on a older type centurion d5 gate motor
Ask the shop what to do when their suggestion does not work.
Oct 02, 2014 | Televison & Video
Centurion d5 troubleshooting
Check the antenna at the gate for corrosion at the connector and make sure it's not bent. Water can get in and make the connection intermittent. Also tighten the screws on the main control board where wires from the receiver connect.
Aug 28, 2014 | Building Materials
Centurion gate motor
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
I got my centurion gate motor D3. the problem is when i press the remote an LED lights but the gate does not open, i opened the motor cover and there is no light nor sound from the motor. the gate can be...
Try to reprogram your remotes.... or replace the batteries even if the l.e.d. still works (it only takes half a volt to make the l.e.d. work but almost the full charge of the batteries are needed to send a working signal.
Oct 18, 2013 | Televison & Video
I need to know how to programe extra remote for my centurion D5 moto gate
If you Google Centurion D5 moto gate you will find a video listed that shows how to do what you need.
Jul 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi, I have a centurion d5 motor on my gate,but recently the gate only opens sometimes halfway or quarter way,othertimes it opens full. I checked the wheels and the tracks, there are no stones or any...
I have the same problem, i have replaced the bevel gears twice and that solved the problem for a short time. Take a look at the play on the bearing housing where the beve gear goes in. It most probably is worn.
Oct 19, 2010 | Clarity Televison & Video
Need to program Nova remotes on a Centurion D5 Motor.
Hi
Have you managed to program the remotes
Sep 07, 2009 | Televison & Video
Building Materials Logo
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
