Question about GE Profile PXCF22RBS Hot and Cold Water Dispenser Cooler
Water not cold
The water is not getting cold but theres hot water.
Why dose my water freeze and dosent come out ....i have to unplug for it to unfreeze then it freezes again after i plug it back in
I am thinking this is not a cellphone you are talking about, but a water dispenser?
The thermostat is set too low. You need to UP the temperature a couple of degrees.
Aug 03, 2016 | GE Profile PXCF22RBS Hot and Cold Water...
Hoover max extract widepath won't spray water
One of your two water Inlet valves (either Hot or Cold) is not working and need to be replaced
Mar 14, 2014 | Hoover Max Extract Pressure Pro 60 FH50220...
Vaillant turbomax vuw gb 282e hot water problem
Check for a control on the gas valve. Has this unit ever been hot? How long installed? Is it jetted for the right gas?
Dec 01, 2013 | Air Purifiers
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
Lasko blower fantype DTB E20739 PM7331
to clean your fan from dust
Jul 02, 2013 | Air Purifiers
Where do I connect the copper tubing line to on my refrigerator to pipe the water from the wall to the freezer so I can make ice and get cold water.
On the bottom of the back of the unit there should be a valve with a threaded fitting on it. you connect the water to this valve. make sure you put a filter in the line also.
Jan 02, 2012 | Air Purifiers
How do i clean black honeycomb filter inside fan area?
Put filter in bathtub, or sink if it'll fit, and swish it in the moderately hot soapy water, use can use dish soap. Then rinse off with moderately hot water but not scalding, then tamp it off onto a towel to get as much water off of it as you can. Your supposed to then let it dry for a while before reuse.
Mar 05, 2010 | Brookstone Pure-Ion UV Air Purifier
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Water Cooler Problem
you might try a strong solution of vinegar and water and then flush it later till it tastes right
Mar 09, 2008 | Air Purifiers
GE Profile PXCF22RBS Hot and Cold Water Dispenser Cooler Logo
26 people viewed this question
Top GE Air Purifiers Experts
Are you a GE Air Purifier Expert? Answer questions, earn points and help others
