Question about GE JGSP28CEK Gas Kitchen Range
Oven starts to heat but then turns off
Set oven to preheat, it seems to reach 425 VERY fast, like two minutes, then it seems to shut off completely. If I reset it, sometimes it will come back on and cook, sometimes not. We haven't tried using it much, so I can't consistently replicate the problem. But in general, it seems to shut off in the middle of cooking. It appears to start, then quickly reaches temperature, too quickly and then we watch a pizza sit in there for 30 minutes until we realize it's off.
SOURCE: GE Spectra XL Oven does not maintain oven temperature
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
Master_Tech
  • 770 Answers
SOURCE: ge spectra xl44 Preheating Issues
bad oven sensor
Posted on Jan 26, 2008
textonor
  • 130 Answers
SOURCE: Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Posted on Feb 04, 2008
SOURCE: GE Profile Spectra JGBP85WEB5WW Taking Too Long to Reach Temp
GE use and care manuals
Posted on Dec 06, 2008
Oven preheat times
It gas not electric. There is NO hidden element. It a bad sensor.
Mar 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Maytag advanced cooking system oven does not preheat to correct temperature and fails to reach the correct temperature
Once you put the desired temperature, select a cook time and it should solve the heating issue. Atleast that what worked on mine.
Jul 25, 2008 | Kitchen Ranges
Reaching desired temperature
one of your elements has burned out or where your incomming wires hook to the range has come loose ans shorted out check there
May 22, 2008 | KitchenAid KERC507 Electric Kitchen Range
Preheating Oven
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Preheat issue with a new kenmore electric range
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
