Question about Miele Novotronic T1515A Electric Dryer
Miele t1515 dryer door reversal
How to remove faceplate to gain access to rear of faceplate for positioning door hinge backing plates with pre-drilled and tapped holes.
4 Suggested Answers
  • 177 Answers
SOURCE: How do you remove the top of the Miele T1515
hi,
on each side of the lid at the front there is a plastic white cover. remove this with your fingers or a small knife. then using a T20 screw driver unscrew each screw a few turns and then push the screw heads in with your finger. do not unscrew the screws too far or remove them.
last push the lid back a few inches and it will lift off. once off you will see the locking clips that you just unscrewed which hold the lid down. when re-fitting the lid do the reverse and just tighten up the screws.
Posted on Apr 25, 2010
  • 32 Answers
SOURCE: Miele T1515 - has started to make my laundry room
check the exhaust hose. it sounds like it has separated from the outlet and is spilling the hot exhaust into the room rather than through the vent outside
Posted on Sep 17, 2010
  • 83 Answers
SOURCE: Miele T1515 electric dryer -
is your dryer vented to the outside? Check the exhaust vent to be sure it is still attached to the duct and not plugged with lint
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
How do I reverse the door on my Whirlpool Duet WED9270XW dryer?
George, try the following-- hope it helps!
Things You'll Need
  • Torx T25 screwdriver
  • Phillips screwdriver
  • Large towel
Instructions
    • 1 Remove the four Torx screws holding the door hinge to the dryer. Lift the door up and pull it away from the dryer to remove it. Lay the door face-down on a large towel to protect it. Screw the four Torx screws back into the holes in the dryer.
    • 2 Remove the two Trox screws holding the door strikeplate onto the dryer's door jamb. Remove the strikeplate and install it on the opposite side of the door jamb.
    • 3 Remove the Phillips screws along the inside of the door. Lift the inner door up and remove it from the outer door. Remove the six Phillips screws along the outer window retainer. Rotate the outer window assembly clockwise until the tabs on the window line up with holes on the frame, and lift the outer window retainer up and off of the window's trim ring.
    • 4 Rotate the outer window itself 180 degrees to rotate the handle to the other side. Replace the outer window retainer and rotate it counter-clockwise to lock it into place. Replace the six Phillips screws.
    • 5 Remove the Torx screws holding the hinge and latch plate in place. Reinstall the hinge on the opposite side of the door. Reinstall the latch plate on the opposite side of the hinge. Slide the inner door back into the outer door and replace the Trox screws.
    • 6 Remove the four Torx screws on the hinge slot on the door jamb. Slide the door into the door jamb and replace the screws
Jan 11, 2015 | Whirlpool Washing Machines
Need to replace front door window motors
Electric Window Motor REMOVAL & INSTALLATION Ranger
  1. Disconnect the negative battery cable.
  2. Open the window. Remove the trim panel and watershield and support the window.
  3. Disconnect the power window motor connector.
  4. There may be a drill dimple in the door panel, opposite the concealed motor retaining bolt. Drill out the dimple to gain access to the bolt. Be careful to avoid damage to the wires. Remove the motor mounting bolts and remove the motor and regulator assembly.
  5. Separate the motor and drive from the regulator on a workbench.
  6. Installation is the reverse of removal.
  7. Check for smooth operation before installing the trim panel.
Except Ranger
  1. Raise the window fully if possible. If not, you will have to support the window during this procedure. Disconnect the battery ground.
  2. Remove the door trim panel.
  3. Disconnect the window motor wiring harness.
  5. Remove the motor mounting bolts (front door) or rivets(rear door).
  6. Push the motor towards the outside of the door to disengage it from the gears. You'll have to support the window glass once the motor is disengaged.
  7. Remove the motor from the door.
  8. Installation is the reverse of removal. To avoid rusting in the drilled areas, prime and paint the exposed metal, or, cover the holes with waterproof body tape. Make sure that the motor works properly before installing the trim panel.
Nov 12, 2010 | 1992 Ford Explorer
Power window
R/V Series
  1. Raise the glass to the full up position and tape it to the door frame with fabric tape.
  2. Disconnect the negative battery cable.
  3. Remove the door trim panel.
  4. Remove the window control bolts and lay the control aside for access.
  5. Remove the regulator-to-door panel attaching bolts.
  6. Disconnect the harness from the regulator.
  7. Slide the regulator assembly rearward, disengaging the rollers from the sash panel.
A notch is provided in the sash panel to allow disengagement of the forward roller on the window regulator.
  1. Remove the regulator assembly through the access hole in the door.
CAUTION The next step must be performed when the regulator is removed from the door. The regulator lift arms are under tension from the counterbalance spring and can cause serious injury if the motor is removed without locking the sector gear in position.
  1. Drill a hole through the regulator sector gear and back plate. DO NOT drill a hole closer than 1 / 2 in. (13mm) to the edge of the sector gear or back plate. Install a pan head sheet metal tapping screw (No. 10-12× 3 / 4 in.) in the drilled hole to lock the sector gear in position.
  2. Remove the motor-to-regulator attaching screws and remove the motor from the regulator.
To install:
  1. Prior to installation, lubricate the motor drive gear and regulator sector teeth.
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the retaining screws.
  3. Remove the screw locking the sector gear in the fixed position.
  4. Reposition the motor in the door and install the wiring connector.
  5. Attach the regulator to the door.
C/K Series
  1. Disconnect the battery ground cable.
  3. Remove the water deflector by peeling it back.
  4. Disconnect the door lock rods at the module.
  5. Loosen the upper run channel bolt.
  6. Move the run channel away from the glass.
  7. Pull the wiring harness towards the door to reach the connector. Remove the boot from the wiring and disconnect the harness at the door hinge pillar.
  8. Remove the module and window assembly from the door frame by tilting it and lowering it from the door.
  9. Fold back the tab on the channel and slide the glass out.
  10. On trucks with power components, drill out the rivets from the inner handle housing.
  11. Drill out the regulator assembly rivets.
  12. Remove the regulator/motor assembly.
  1. Install a pan head sheet metal tapping screw through the sector gear and backing plate in the hole provided, to lock the sector gear in position.
  2. Drill out the motor-to-regulator attaching rivets and remove the motor from the regulator.
To install:
  2. Install the motor to the regulator. Make sure the motor and sector gear teeth mesh properly before installing the replacement attaching bolts and nuts.
  4. Reposition the motor/regulator in the door and install the wiring connector.
  6. Slide the glass out into the channel and fold over the tab.
  7. Fit the glass into the rear channel in the door, then, while pulling the channel towards the glass, fit the glass into the front run channel.
  8. Install the boot from the wiring and connect the harness at the door hinge pillar.
  9. Install the lower run channel bolt.
  10. Install the door lock rods at the module.
  11. Install the module panel screws, starting at the top left, then the top right.
  12. Install the water deflector.
  13. Tighten the upper run channel bolt.
  14. Install the trim panel on the door.
Jul 30, 2010 | 1994 Chevrolet G20
How do you remove the top of the Miele T1515 vented dryer?
hi,
Apr 12, 2010 | Miele Novotronic T220 Electric Dryer
I have bought a new door hinge for a hotpoin wd63p washer dryer but was wonderig do you have to take the front of the washing machine or the rubber
hi from uk easiest way is to turn off/remove water supply hoses disconnect power then remove top screws from rear panel(these also secure top panel if yo look ?) then lift rear of top panel slightly and pull back/then lift off you now have access to rear of front panel where door hing is secured by 2 screws from the front of panel/hing into a metal plate theaded inscrew door from plate whilst you hold plate thenremove door with hinge assy you will now see the inner plastic cover of door is secured remove this cover to access hinge screws renew hinge and whilst door is at this point might as well lift glass window and clean any **** around the edge ? reassemble in reverse to strip down hope this is clear enough for you ? good luck
Nov 04, 2009 | Hotpoint Aquarius WD63 Front Load...
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Door Hinge Replacement
remove spring that holds the rubber bellows to front of machine
peel back and fish out plate from inside cavity of machine
then refit plare and reverse process
Mar 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Miele Novotronic T1515A Electric Dryer Logo
78 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
