Question about Kenmore 21.9 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
Ice maker making chunks of ice - Kenmore 21.9 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
2 Suggested Answers
  • 1891 Answers
SOURCE: the ice maker makes ice fine but when it is dumped
it sounds like the water valve is not shutting of when it should / and flooding the tray. . . other possible cause is temp in freezer is not low enough . should be 0 to 5 deg .in tempt . ck these/ if ice cubes are too large this is a clue that valve is letting in to much water .. **** hope this helped.. I think changing the valve first would be the best ..
Posted on Feb 10, 2010
Whirlpool bottom freezer ice maker will only make ice if I pull and then replace the ice container, why?
The ice maker works off a timer that controls the discharge of ice, water fill, etc. Right before the tray discharges ice it is heated slightly so the ice is just slippery enough to discharge the ice. Unfortunately, now and then (for us) a chunk of ice remains in the tray. This chunk prevents the blades from rotating and eventually you have a mass of new ice with the blades in the wrong position. The blades have to be in a certain position for the heater to kick in. You are stuck with cracking up the ice stuck in the tray to get the blades to rotate again. We have an Electrolux ice maker but this problem occurs periodically. The root of the problem is it's failure to heat up the ice tray adequately to discharge ALL the ice. One thing to remember is that next time this happens you have to manually break up the ice in the tray and push the timer advance button until the 2 set of blades are fully closed (hidden) and at 90 degrees. From that point on at least the ice maker can start making more ice.
Aug 23, 2014 | Refrigerators
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
My standalone ice maker is making very small amount of ice
First off, check that the water inlet line is clear.
Once on a refrigerator ice maker, the part of the water inlet hose inside the freezer ha a solid chunk of ice blocking the flow.
Aug 11, 2014 | Kenmore 51lb. Clear Ice Maker
Amana ASD2626HEB ice maker leaking into bin
either there is ice formed inside the fill tube where the water goes into the ice maker and spraying all over the place when the ice maker tries to fill, or the ice maker mold is cracked letting it leak out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Amana Refrigerators
No ice
Check whether the water is reaching the ice maker. If something is blocking its way get it cleared. Once it start taking water it should produce ice.
Apr 20, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker makes large chunks of ice about half and other half of ice is normal ice cubes
check you Ice maker is it level...if level I would check the water level you may be getting to much water in to it...
Sep 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
The bin on my ice maker forms big chunks of ice
check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice, OR cause the thaw-freeze cycle resulting in chunks. Check your door seals and thermostat, repair/replace as necessary.
May 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ice maker doesn't make ice but i have water in the door
Your machine has a dual water valve. The ice maker side coil is dead most likely. You can confirm this by loading your ice maker with a glass of water. If it chunks out a batch but fails to make anymore then that is a sure sign of a bad water valve solenoid.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 08, 2009 | Refrigerators
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Refrigerators Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
